Author Topic: GOT MY DUCKY!!!  (Read 3471 times)
Offline amarshonarbangla
GOT MY DUCKY!!!
« on: Mon, 26 November 2012, 23:50:06 »
I got the Ducky Shine II with red LEDs and MX Blue Switches :D
I ABSOLUTELY LOVE TYPING ON THIS
Re: GOT MY DUCKY!!!
« Reply #1 on: Mon, 26 November 2012, 23:54:43 »
Same as mine - red LED and MX blue (except mine is a Shine version 1).  That was and still is my first modern mechanical keyboard.
Offline firebt
Re: GOT MY DUCKY!!!
« Reply #2 on: Tue, 27 November 2012, 14:04:53 »
Typical symptoms of a first time Ducky user.   Sounds like me.  I'm glad that you like it.   I knew you would (how could you not?)
:D
Re: GOT MY DUCKY!!!
« Reply #3 on: Wed, 28 November 2012, 15:33:31 »
The Cherry stabilizers do feel stiff. I suppose that's normal?
Offline rknize
    • metaruss
Re: GOT MY DUCKY!!!
« Reply #4 on: Wed, 28 November 2012, 15:38:01 »
A bit of lithium grease on the joints can help.  You can also mod them to make them feel a bit more like Costar stabs.
Russ
Offline firebt
Re: GOT MY DUCKY!!!
« Reply #5 on: Wed, 28 November 2012, 16:18:21 »
Wait, correct me if I'm wrong, but lithium grease has a significant amount of petroleum distillates...which are known to degrade plastic (especially ABS) rather quickly as it can penetrate the material.  I would recommend pure synthetic teflon lube, like from dupont.  You don't want any petroleum, so full synthetic.  Or I heard KG-8 has good reviews.  But yeah, my spacebar sometimes squeeks very very little on occasion.
Offline Hyde
  • White Tofu Extraordinaire
Re: GOT MY DUCKY!!!
« Reply #6 on: Wed, 28 November 2012, 16:23:37 »
Ohhhhh congrats !!!  I think the only complaint I have with Ducky is that I wish they had separate LED indicator for num/caps/scroll lock, because num lock is typically on but scroll and caps lock are typically off and it look weird having 2 keys with no lights on.
Otherwise yes Ducky seems to be the best backlit board right now  :)
Offline Kabuks
Re: GOT MY DUCKY!!!
« Reply #7 on: Wed, 28 November 2012, 17:34:02 »
Nice board! Red LED's are the way to go. :)
Re: GOT MY DUCKY!!!
« Reply #8 on: Wed, 28 November 2012, 17:51:40 »
Green are nice too (he said, with the green lights from this Ducky Shine reflecting off his face).
I have one red and one green - maybe I should bring them together ni a Christmas celebration.
