Author Topic: hello geekhack!  (Read 3055 times)
Offline ShortStock
hello geekhack!
« on: Tue, 27 November 2012, 03:28:13 »
hello ladies and gentlemen,
dropping by to say hi!
i have owned 2 mechanical keyboards total.  the first one was the coolermaster quickfire pro (brown switches).  i got rid of that because it never agreed with my motherboard.
i currently am using Rosewill's rk-9000bri (brown switches, white body).    I am taking a risk with the usb cable based on the reviews, i am using a 90 degree mini usb cable to avoid accidentally hitting it.  and i have searched around and i recall someone mentioning that those keyboards made by rosewill that were manufactured in 2012 do not have the usb problems.
only time will tell :)
Offline Shadovved
  • King of Stickers (and GBs)
Re: hello geekhack!
« Reply #1 on: Tue, 27 November 2012, 04:00:59 »
Yeap, the newer rosewills have a more reinforced port, which should be fine :)
Welcome to GeekHack, and enjoy your stay, while your wallet doesnt :D
Offline ShortStock
Re: hello geekhack!
« Reply #2 on: Tue, 27 November 2012, 13:17:38 »
ow my wallet will stay.....  for now
Re: hello geekhack!
« Reply #3 on: Tue, 27 November 2012, 14:56:28 »
Welcome to Geekhack!
Re: hello geekhack!
« Reply #4 on: Tue, 27 November 2012, 15:20:18 »
hihi welcome to geekhack buddy
Offline hluo87
Re: hello geekhack!
« Reply #5 on: Thu, 29 November 2012, 10:20:05 »
Welcome to geekhack!
i am new too!!
Offline Vintage
Re: hello geekhack!
« Reply #6 on: Fri, 30 November 2012, 16:14:05 »
Welcome to GH!
CM QFR w/ MX Reds  | Logitech G900
Offline WhiteFireDragon
    • youtube
Re: hello geekhack!
« Reply #7 on: Sat, 01 December 2012, 05:43:15 »
I wouldn't say the problem is completely gone. The USB port is superglued down now, but the design is still the same where the mini-USB connector is soldered to the PCB. Rosewill needs to do what CM or ducky did by adding channels to hold the cable so it doesn't stress the USB port.
http://geekhack.org/index.php?topic=36106.0
