Author Topic: loose stabilizers  (Read 3074 times)
Offline gameaholic
loose stabilizers
« on: Wed, 28 November 2012, 19:50:45 »
I got some new RGB modifiers today and the cross shaped stabilizers that go into them are pretty loose.  I managed to get them in and working fine but I was just wondering if there is some sort of trick to getting them to stay put short of gluing them in.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: loose stabilizers
« Reply #1 on: Wed, 28 November 2012, 19:57:02 »
I've had good luck with putting a small piece of tape on the stems before inserting them into stemholes(?)
Offline Caaaarrrt
« Reply #2 on: Wed, 28 November 2012, 19:58:52 »
Cutting out small squares of plastic from a plastic bag or something can also work, similar to using tape, as it makes it a tighter fit.
I have also found that the stabiliser clips from WASDKeyboards fit much better in SP keycaps than stock ones on my Filco and QFR.
« Last Edit: Wed, 28 November 2012, 20:46:54 by Caaaarrrt »
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
« Reply #3 on: Wed, 28 November 2012, 20:45:35 »
I used the plastic bag trick - worked well.  You only need about a 1cm square bit of plastic, place it over the base of the stem, then push the stabilised in thru the plastic.  The plastic folds itself around the stabiliser and makes for a tighter fit.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Wed, 28 November 2012, 20:53:46 »
Loose stabilizers are a pretty common problem, especially for SP keys. Everyone already suggested it, wrap tape or paper around the white inserts and they'll be more snug.
