Author Topic: Filco Majestouch 2 Paint Issue  (Read 2057 times)
Offline Spedboy
« on: Thu, 29 November 2012, 06:17:29 »
Hey guys,
my recently bought Filco (Colour Black,tenkeyless,mx browns) is beginning to show some shine below the spacebar, right on the edge
where it becomes a 90 degree angle. Literally got this yesterday and have been washing my hands to try and avoid oils from the hands. Any other owners out there have this issue or am I just being to picky? Just kind of worried if this will happen to to the entire bottom part of the case.
Offline Turbo Slaab
Re: Filco Majestouch 2 Paint Issue
« Reply #1 on: Thu, 29 November 2012, 06:23:26 »
Wow. I've had mine for a year+ and don't have any wear marks. Maybe it's a defective unit? I'd contact whoever you got it from.....
Looking for CC's!
Offline laffindude
« Reply #2 on: Thu, 29 November 2012, 06:25:17 »
The black case is not painted. It is just bare ABS plastic. Not much you can do other than keeping your finger off of it. Do you rest your wrist on the desk when you type? If you elevate your wrist a little, you can avoid touching the corner.
Offline Spedboy
« Reply #3 on: Thu, 29 November 2012, 06:28:06 »
I try to elevate while typing but whilst playing games it's fairly hard to do. (jumping with space bar)
Offline jeroplane
« Reply #4 on: Thu, 29 November 2012, 06:32:30 »
I don't think it's shine/wear, seems like you've just got oily/moist hands. Some people have dry hands, some don't. Even if you wash your hands, it will still produce oil over time and cause the keys to become shiny.
My signature hasn't changed since 2012. I should really update it.
Offline longweight
  • philanthropist
« Reply #5 on: Thu, 29 November 2012, 06:33:41 »
Post a pic.
Offline Spedboy
« Reply #6 on: Thu, 29 November 2012, 06:36:25 »
Yeh I will tomorrow in bed reading at the moment 11.04pm in Australia :)
Offline Spedboy
« Reply #7 on: Thu, 29 November 2012, 21:35:14 »
Here is a photo of the mark itself. You can kind of see the coarseness with the camera flash on. Is this anything to be worried about, or should I let it slide. The only problem is that i actually received it on Wednesday, and don't know how this could've happened in this time. Anyone advise me on what to do from here?
« Last Edit: Thu, 29 November 2012, 21:51:50 by Spedboy »
