Author Topic: Request for a Logo  (Read 7757 times)
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
Request for a Logo
« on: Fri, 30 November 2012, 04:16:56 »
Hello everyone!
I don't know if I'm in the good place or not (if not can someone please move my topic in the good section)
I would like to request a logo (or whatever you want to call it ^^) with the autobot symbol (I would like to have it in red but only managed to find it in black :s) and "Primus Prime" around it (as Primus Prime is my name in the Video game I'm playing)
If possible I would like it to have "no background" (or transparent background) which means I can use it to put on pictures (as JIL makes for exemple) and you will still see everything of the picture (except where the logo is of course).
I'm sorry if I was not clear in what I asked,
thanks a lot for that!!!!
Offline damorgue
    • Personal portfolio
Re: Request for a Logo
« Reply #1 on: Fri, 30 November 2012, 04:34:46 »
I was bored and had photoshop open anyways. Cleaned it up to maintain some detail.
Offline JSaintS
    • JSaintS
« Reply #2 on: Fri, 30 November 2012, 04:42:23 »
thank you a lot!!!!!
can you put Primus Prime around this one :
I hope I'm not asking too much!
Anyway thank you!
Offline damorgue
« Reply #3 on: Fri, 30 November 2012, 04:45:02 »
Where do you want it? "Around" isn't very specific. Arced? Above? Beneath? Following the perimeter of the logo?
Offline JSaintS
    • JSaintS
« Reply #4 on: Fri, 30 November 2012, 04:46:45 »
I would like around (under) but what do you mean by following the perimeter of the logo? :D
Offline damorgue
« Reply #5 on: Fri, 30 November 2012, 04:49:57 »
Nvm, you probably don't want it then. Font?
Offline JSaintS
    • JSaintS
« Reply #6 on: Fri, 30 November 2012, 04:51:19 »
aouch ^^ don't know something simple, I don't want anything fancy :)
Offline damorgue
« Reply #7 on: Fri, 30 November 2012, 04:51:59 »
Offline JSaintS
    • JSaintS
« Reply #8 on: Fri, 30 November 2012, 04:54:05 »
awesome!
thanks a lot Damorgue! If I can do anything for you just let me know :D
Offline damorgue
« Reply #9 on: Fri, 30 November 2012, 05:06:18 »
No problemo, as I said, I had it open anyways.
