Author Topic: Quick question about Cherry keycaps  (Read 2612 times)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« on: Fri, 30 November 2012, 12:18:59 »
Do they make space bars that fit modern keyboards? If so, on which models?
Modern spacebar meaning 6.25 with a centered stem slot
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Re: Quick question about Cherry keycaps
« Reply #1 on: Fri, 30 November 2012, 12:20:23 »
7-unit spacebars fit on some 'modern' keyboards (mostly Korean customs).  Otherwise, all their 6.25-unit spacebars have non-symmetrical stem placements, so they won't fit on anything unless you mod the stems.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #2 on: Fri, 30 November 2012, 12:24:12 »
Ah I see, thanks for the info
