Author Topic: Filco PS2 Adaptor Not Working  (Read 4868 times)
Offline TurboDance
« on: Sun, 02 December 2012, 13:24:09 »
Hi There,
Newish member. I purchased a new Filco Tenkeyless last year from Army Group, and was stoked to eventually try using the USB to PS2 adapter for better keyboard performance.  This year I upgraded my main PC and bought a board with a PS2 jack, but am having issues with making it work. The keyboard works fine when plugged into USB, but when I put the adapter on the keyboard does not detect in Windows. My last motherboard didn't have a P/S 2 port and I can't backcheck for issues this way.
Is this an issue with many PS2 adapters, or is it possible the issue is motherboard related? All drivers are installed. It's a Gigabyte G68X-UD3H-B3
Not a huge deal but it was a bit of a letdown when I saw that this wasn't going to work easily with plug and play. Maybe somebody has some insight. Thanks guys.
Offline WRXChris
Re: Filco PS2 Adaptor Not Working
« Reply #1 on: Sun, 02 December 2012, 13:32:36 »
Hopefully your problem is that you didn't reset the computer.  USB is plug-n-play, which means that you can plug and unplug devices and they will sync/unsync automatically.  PS2 is not plug-n-play; you have to reset your computer in order for a PS2 device to sync with your motherboard.  Good luck!
Offline TurboDance
« Reply #2 on: Sun, 02 December 2012, 13:48:43 »
Just to be clear, you have to plug in the keyboard with the PS2 jack and then upon restart it then detects? It's true, I did not try that; I guess am used to plug and play. I will restart right now and report back in  :).
Offline TurboDance
« Reply #3 on: Sun, 02 December 2012, 13:54:36 »
It worked! One more free USB port, and all of the internal capabilities of the Filco unlocked. Ohhh I'm happy!
Offline TotalChaos
  • Indy Game Coder
« Reply #4 on: Sun, 02 December 2012, 14:42:50 »
PS/2 rulez da scene 4eva  :)
Offline Soarer
« Reply #5 on: Sun, 02 December 2012, 15:10:57 »
... until full-speed USB takes over :P
Offline TheShining
« Reply #6 on: Sun, 02 December 2012, 16:09:00 »
most modern mb's let you hotswap ps2 no problem.
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Filco PS2 Adaptor Not Working
« Reply #7 on: Sun, 02 December 2012, 16:12:56 »
that not what i have encountered...
most modern boards ive dealt with lately dont have PS/2
Offline daerid
    • Rossipedia
« Reply #8 on: Sun, 02 December 2012, 22:06:27 »
I've been using PS/2 since 1990, and I've never once been able to hot swap it on any board that has a ps/2 port.
Offline SmallFry
« Reply #9 on: Sun, 02 December 2012, 22:29:32 »
I hot-swapped today, but I did have a keyboard plugged into the port before I swapped. I wonder of that made a difference.
Offline TotalChaos
  • Indy Game Coder
« Reply #10 on: Mon, 03 December 2012, 01:37:06 »
Your Filco is now as good as my Rosewill.  :)
Offline daerid
    • Rossipedia
« Reply #11 on: Mon, 03 December 2012, 01:40:11 »
Absolutely. If the PS/2 port is already active, then you can hot swap. But if the port isn't activated at boot up, the mobo basically shuts it off.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #12 on: Mon, 03 December 2012, 07:56:19 »
Only mobos I've ever had that dealt with PS/2 hotswapping perfectly are in IBM systems... big surprise.
Filco w/ Imsto thick PBT
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #13 on: Mon, 03 December 2012, 16:49:45 »
I've crashed PCs from hotswapping PS/2 :P
ADB on the Mac was hotswap-aware by design (the bus was scanned during something like every 30 VBL interrupts), but the circuitry was not hotswap-safe, so you were told not to EVER hotswap Mac keyboards and mice. I did, lots of times. Never blew anything up … ;-) (I broke everything else, but never killed a Mac through hotswapping)
Bore Awards
