Author Topic: Tilde troubles...  (Read 2526 times)
Offline SmallFry
Tilde troubles...
« on: Sun, 02 December 2012, 15:01:17 »
I cleaned up my G80-1800 and now my Tilde wont work. I haven't hit it with a meter yet, but didn't know if inlikeflynn/other 1800 enthusiasts would have any weird quirks that happen occasionally. The Tilde is the only key does not work.
Offline esoomenona
  • Gnillort?
Re: Tilde troubles...
« Reply #1 on: Thu, 06 December 2012, 17:22:05 »
Let's be honest. What are you going to use that key for?
Offline xDezor
« Reply #2 on: Thu, 06 December 2012, 17:25:18 »
I use the ~ key once every round in Counter-Strike: Source to pop up the console window (So I can see the damage given/taken that round). I'm not sure what he uses it for, but it definitely has it's uses.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #3 on: Thu, 06 December 2012, 17:27:49 »
Linux shortcut for "home".  Important key.
Can't imagine why one would use the grave key, however.
 - Ron | samwisekoi
« Reply #4 on: Thu, 06 December 2012, 19:07:44 »
To execute commands at a Unix prompt as sub-processes e.g. echo `date` will run the date command and echo the output.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #5 on: Thu, 06 December 2012, 19:30:36 »
Or right.  BASH.  Jeez; soggy brain today.
 - Ron | samwisekoi
Offline esoomenona
  • Gnillort?
« Reply #6 on: Thu, 06 December 2012, 20:19:39 »
You guys, I was joking... SF needs some help.
Offline SmallFry
« Reply #7 on: Thu, 06 December 2012, 22:10:45 »
I think its fixed... I'll report if anything else goes wonky.
Offline salmo
    • messmore.org
« Reply #8 on: Thu, 06 December 2012, 22:24:19 »
You can always use the (preferred since POSIX adopted the Korn shell-isms) $(date) vs `date`.  But it would also mess with m4 open-close `' style quoting.
It's funny how characters that were not important to English typists were defined to become important (~, `, @, *, etc.) just because they were on the keyboard, so got used for something.
Offline TotalChaos
  • Indy Game Coder
« Reply #9 on: Fri, 07 December 2012, 08:37:17 »
AmigaDOS works the same way.
