Author Topic: Brown switches for BlackWidow Tournament Edition  (Read 2985 times)
Offline Smeagol_RP
  • your ad here
    • Steam
« on: Mon, 03 December 2012, 06:51:50 »
Hey guys, I was wonder if I can replace the blue switches for the brown switches, so i wrote an email for QWERkeys and they sent me this picture about the models.
Does anybody know what part number exactly "fits" in this keyboard?
Edit: Well, according to DeskthorityWiki:
  • MX1A-xyNN no diode, plate mount (no fixing pins)
  • MX1A-xyDN with diode, plate mount (no fixing pins)
  • MX1A-xyNW no diode, PCB mount (with fixing pins)
  • MX1A-xyDW with diode, PCB mount (with fixing pins)
Okay it's plate mounted. Now I need to know, with or without diode?  What's the difference?:-X
« Last Edit: Mon, 03 December 2012, 11:27:47 by Smeagol_RP »
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline Hyde
  • White Tofu Extraordinaire
Re: Brown switches for BlackWidow Tournament Edition
« Reply #1 on: Mon, 03 December 2012, 13:52:10 »
Sounds easier if you just buy this http://www.razerzone.com/gaming-keyboards-keypads/razer-blackwidow-tournament-stealth-edition/
As for the diode thing I'm not sure, I always thought all MX Brown switches are all the same?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Mon, 03 December 2012, 14:09:29 »
The switches are the same, however you can purchase switches with or without a diode pre-installed.  You can always put a diode in it if you end of needing that.
Filco w/ Imsto thick PBT
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #3 on: Mon, 03 December 2012, 14:45:14 »
I read something about n-key rollover. In that case better buy all with diode.
Thanks.
Damn it  :'( And I searched about that after the announcement of the BWU 2013 Stealth. Well, thanks for the link, I think I'll stick with this for a while even not liking the mx blues.  :(
