Author Topic: RE: Marquardt MiniErgo with Cherry Switches?  (Read 4496 times)
Offline TheGrey
« on: Mon, 03 December 2012, 09:52:27 »
Hi all :)
I should be receiving this soon.
I know that this uses Marquardt clear switches, but is it possible to swap them out for delicious cherry mx switches?
FYI, here' a historic geekhack post on the Marquardt mini ergo from lam47:  http://geekhack.org/index.php?topic=5395.0
I ask, because I have no idea and have little intention on destroying this stealth fighter plane of a keyboard!  :))
thanks,
TheGrey
« Last Edit: Mon, 03 December 2012, 09:55:59 by TheGrey »
Offline SmallFry
Re: RE: Marquardt MiniErgo with Cherry Switches?
« Reply #1 on: Mon, 03 December 2012, 10:00:40 »
Cool! Never knew that existed. I'm not sure if the pin spacing is the same. Do you have an MX switch on hand?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Mon, 03 December 2012, 10:14:28 »
Pics in that thread you linked indicate that they are not a match for the MX pin locations.
Filco w/ Imsto thick PBT
Offline TheGrey
« Reply #3 on: Mon, 03 December 2012, 10:36:41 »
Aww hell no :(  Otherwise any hope for other types of switches? I am really new...like out of the womb new...is there a way to mod anything to get any other types of switches to work?
Also, I would love to know how you can tell that cherries cannot fix in them.
Thanks!  :)
Offline alaricljs
« Reply #4 on: Mon, 03 December 2012, 10:42:43 »
Compare this diagram to the pics of the PCB bottom:
The easiest way to tell since we don't have any measurements from your board is the Y dimension offset of the pins on MX switches, your PCB has no Y offset on either set of pins (diode or switch).
That pic is from the Cherry datasheet.
Offline TheGrey
« Reply #5 on: Mon, 03 December 2012, 10:58:32 »
thanks! So is there any hope for any other switches? it seems that Marquardt no longer makes this types of linear switches. tbh I would love to add some tactile switches to it but maybe i'm asking too much!
Offline alaricljs
« Reply #6 on: Mon, 03 December 2012, 11:21:48 »
Just checked the bottom of an Alps, leads are too closely spaced compared to the Marquardt.
I can't think of anything else readily available.
Offline TheGrey
« Reply #7 on: Mon, 03 December 2012, 11:33:00 »
aww shucks! thanks anyway for your insight. any other ideas would be really appreciated.
Offline TheGrey
« Reply #8 on: Thu, 06 December 2012, 10:46:27 »
I've got an idea...would swapping out the internals of the marquandt switchs with a cherrys internals work out? Also, as I am a complete noob, I ask....would this also provide me a longer life of the switch?!
Cheers  :)
Offline alaricljs
« Reply #9 on: Thu, 06 December 2012, 10:48:55 »
They are completely different designs, no cross compatibility at all aside from perhaps the spring.
Offline TheGrey
« Reply #10 on: Thu, 06 December 2012, 11:11:00 »
lol...i think I should just be content with the keboard then!  :D
