Author Topic: Blank keycaps for the QuickFire Rapid  (Read 5354 times)
Offline WhipeeDip
« on: Mon, 03 December 2012, 19:23:13 »
I just got my first mechanical, a QuickFire Rapid with blue switches :D
I'm in love with it. Anyways, this isn't the point.
What is a good blank keycap set for the QuickFire Rapid? Preferably with another key with a LED hole viewer thingy because the F9 key also serves as a Windows lock key with an LED.
I think  I'd want PBT, and maybe white because someone has done this and it looks really nice.
Offline SmallFry
Re: Blank keycaps for the QuickFire Rapid
« Reply #1 on: Mon, 03 December 2012, 19:36:56 »
Those look like the keys off of a Otaku Leopold.
Offline akuJIWA
  • Lock 'N Load!
« Reply #2 on: Mon, 03 December 2012, 19:48:05 »
I would recommend imsto thick grey pbt. Those looks absolutely sexy seriously. I will be getting them soon for my qfr
Edit: there are no holes for functions afaik
« Last Edit: Mon, 03 December 2012, 19:56:21 by akuJIWA »
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline durainello
    • Free cheap and fast International shipping solution to fellow Singaporean.
« Reply #3 on: Wed, 05 December 2012, 03:55:37 »
Is that the original unbranded gray case?
Offline jeroplane
« Reply #4 on: Wed, 05 December 2012, 07:28:39 »
Good eyes, looks like that's why they had to use a different space bar.
My signature hasn't changed since 2012. I should really update it.
Offline SmallFry
« Reply #5 on: Wed, 05 December 2012, 07:52:04 »
Yup. Its too bad that they didn't modify the stems. I really like the full white look, if only for those LED windows.
« Reply #6 on: Sun, 09 December 2012, 14:10:38 »
They don't come in windowed keycaps, but you should be able to see the red LED through the PBT if it's on.
Okay, just tested. With IMSTO white PBT, you can easily see the LED shine through it. It looks really great, actually. Better (over an LED) than SP white PBT.
Using my gray IMSTO Geek Hack key, I could not see the LED through the keycap at all, but the light was still visible reflected off the plate.
I already know I'll be very happy with my IMSTO PBT Dvoark sets now.
