Author Topic: I believe there's a problem with my keyboard.  (Read 2394 times)
Offline Finwens
« on: Wed, 05 December 2012, 17:57:13 »
Hello Geekhackers. I have owned a steelseries 6gv2 with MX Black switches for four months now, and I believe there's some kind of problem going on. It's registering two key strokes when I only pressed once. This was happening on the first days as I was adjusting with the black switches, but I think it's happening more often now, especially the O key, as I often types yaddayadda.coom.
Is this a problem with the keyboard or is it me? Did a quick search on google and didn't find anything about it.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: I believe there's a problem with my keyboard.
« Reply #1 on: Wed, 05 December 2012, 18:07:15 »
Probably a faulty switch, often referred to as chatter. I would just swap it with something relatively useless like scroll lock if you don't have any spare and don't want to order a new one. It will require soldering to fix it. Alternately if you are not comfortable with repairing it, see about any warranty.
Offline Finwens
« Reply #2 on: Wed, 05 December 2012, 18:13:59 »
Meh, I think I can live with it. I'm not comfortable with repairing it myself AND the warranty is a problem to me. I live in Brazil and it would took me about four months to send it back and receive it back. If it gets worse and with more switches, I'll just buy a Filco keyboard or something better than steelseries. Didn't make proper research about mech. keyboards and I regret a little bit the mx black and the keyboard itself ):
« Reply #3 on: Wed, 05 December 2012, 18:19:08 »
I see, maybe look around for any electronics repair shops, guitar shops, etc that will likely have someone that is expireinced with soldering to fix it for you. While SS wouldn't be my first choice mostly due to the layout issues they don't seem to be terrible either quality wise. Defective switch can end up in any brand keyboard.
Offline Finwens
« Reply #4 on: Wed, 05 December 2012, 18:25:13 »
I'll see if it happens with other switches or gets worse with the O. I'm a bit afraid that they could fu... up my keyboard, lol.
« Reply #5 on: Wed, 05 December 2012, 18:34:12 »
If it is faulty and you return it, they should give you a new one.
Offline Finwens
« Reply #6 on: Wed, 05 December 2012, 18:39:10 »
Like I said, I will stick with it unless it happens to other keys or get worse with the O.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #7 on: Wed, 05 December 2012, 18:45:01 »
Imported keyboard and besides, Steelseries has no warranty at our country.
Anyway, as people said, it's unfortunately a faulty switch, something that can happen with any brand since it's Cherry who produces them. Just like what happens with some bad OMRON switches as well on lots of brands such as Logitech, Steelseries, Thermaltake, Corsair, Razer, Mionix...
It's something unavoidable, as most companies don't test properly their keyboards before sending them and it's Cherry's fault, not really Steelseries..
What you can really do next time is either buy a keyboard from a company with a good quality assurance control (like FILCO), buy a keyboard from a company that officially sells their keyboard in Brazil and has warranty over here (such as Thermaltake or Cooler Master) or buy a keyboard with a PCB Mount, so it's a lot easier to remove the switches (such as the PLUM 96).
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline Finwens
« Reply #8 on: Wed, 05 December 2012, 19:01:58 »
Hello there fellow brazilian. Yes, we have no steelseries support here so I would have to send it back.
Anyway, thanks for the replies guys.
