Author Topic: °Parashop° Closed indefinitely  (Read 113341 times)
Offline Poom
  • Trade Count: (0)
Re: °Paranoid° ALPS keycaps and cables that go BOING, whuaaat?
« Reply #250 on: Thu, 27 June 2013, 15:04:30 »
hey I saw your post a long long while ago and couldnt find you since you just posted on the beast wood shop.
do you do custom lightning cables?? I need longer ones.
how much does shipping costs to switzerland? I am also interested in other usb cables too.
Offline Paranoid
  • Trade Count: (0)
« Reply #251 on: Thu, 27 June 2013, 15:12:10 »
Hi Poom,
At the moment I don't offer lightning cables. If there would be enough interest I can definitely look into that. Shipping to Switzerland is not so expensive: €4 under 100gr and €7 above 100gr.
Cheers!
Offline Poom
  • Trade Count: (0)
« Reply #252 on: Thu, 27 June 2013, 15:28:16 »
Hi Poom,
Cheers!
hey, yep not a problem, i figure it isnt so straight forward since there is something with the controller and stuff too right?
woot that is definitely affordable, great that i found you again  :D, i knew i saw a  cable guy based in europe somewhere before.
Offline randompony
  • Trade Count: (0)
« Reply #253 on: Thu, 27 June 2013, 16:22:38 »
hi,
does anybody know how thick the cables are (specifically for the filco tkl)? and how long the strain relief is from the ring inside?
I want to build a tray with the keyboard embedded and need to decide if I want to order (when the orders are live again) with the strain relief or not.
Offline Paranoid
  • Trade Count: (0)
« Reply #254 on: Fri, 28 June 2013, 01:12:28 »
Well I read something about that as well, but I don't believe our Chinese friends actually use those since I've seen just the connectors somewhere before. Can't remember where at the moment. I should try this out to be sure of course, but I don't have an ios device :) I'll try it out during the summer. Remind me if I forget :p
hi,
If anyone should know it would be me I guess :D the diameter of the cable varies. I have several different cables depending on what sleeve is used and if the cable is for usb or for internal keyboard components. I goes from 3-5mm in cable thickness, and you can add rougly 0,5-1mm to that when the sleeving is on. For the strain relief I'd have to measure when I'm home. I think it was about 3cm but you can pretty much cut it to size although it's a little tricky to cut it straight because of the rubber.
Offline randompony
  • Trade Count: (0)
« Reply #255 on: Fri, 28 June 2013, 01:35:47 »
hi,
hmm..
the problem is that I can't cut the strain relief when it is on the cable without damaging the sleeve :(
thanks though
Offline Paranoid
  • Trade Count: (0)
« Reply #256 on: Fri, 28 June 2013, 01:51:31 »
Yes I know, I was saying I could cut it to size before I put it on the cable if you know what length it should be :)
Offline Latin00032
  • Trade Count: (0)
« Reply #257 on: Sat, 29 June 2013, 23:53:06 »
Got some additions to the sleeves. Three extra colors of MDPC and some colored Paracord:
With this and all the components back in stock I could finally make an interesting request for an Ergodox kit:
That's all for now :)
What color is that paracord in the bottom right corner of the picture? It's the one that has the blue, grey, and white. What's it called?
Offline Paranoid
  • Trade Count: (0)
« Reply #258 on: Sun, 30 June 2013, 05:59:29 »
Sorry Latin, no time right now. Vacation mode is on! :D See you guys in a couple of weeks!
Offline deSheol
  • Trade Count: (0)
  • Thorpe
« Reply #259 on: Sun, 30 June 2013, 06:01:47 »
 :( Looks like I have to get a cable somewhere else.
Offline Paranoid
  • Trade Count: (0)
« Reply #260 on: Sun, 30 June 2013, 08:24:15 »
It's messed up that the cable still didn't arrive. I couldn't make a new cable before I left but when I'm back I'll make you another one regardless.
Offline Coumbaya
  • Trade Count: (0)
« Reply #261 on: Sun, 30 June 2013, 12:00:33 »
I'd buy a full red alps cap, or a double-sleeved micro usb to usb, if you ever make one of those, Paranoid.  :)
Filco MJ2, Browns, Skull Squadron Ducky Shine III, Browns, Granite Unknown, White Alps & trackpad 1390132 & 1391402 Model M
Offline Paranoid
  • Trade Count: (0)
« Reply #262 on: Mon, 08 July 2013, 01:09:46 »
hi Coumbaya, I can make those if you want me to ;) I'll be sure to contact you when I'm back from vacation :)
Offline Coumbaya
  • Trade Count: (0)
« Reply #263 on: Mon, 15 July 2013, 03:34:26 »
That would be nice, I try to give each of my boards at least a little bit of love lol. The Alps one and the model M are the only ones without custom stuff on them.
(PS: I still haven't finished soldering the cable... :-[ )
Offline GoatMaster
  • Formerly Franatic89
  • Trade Count: (0)
« Reply #264 on: Wed, 21 August 2013, 14:23:37 »
i want to order some cables ! when can i do it again?
Offline Paranoid
  • Trade Count: (0)
Re: °Paranoid shop° Premium cables and caps
« Reply #265 on: Wed, 28 August 2013, 02:40:38 »
Hi Franatic, I'm still pretty busy at the moment. Order forms will be up in about two weeks I think when things slow down for me :)
Offline Paranoid
  • Trade Count: (0)
« Reply #266 on: Mon, 23 September 2013, 12:57:01 »
Hi again people! It's been quite a while but I'm slowly rolling back into business now.
To start things off I have five nice cables to offer already done for you at a cheaper price in some nice bright colors that might match your board/keyset or that will just brighten your day!
Your pick, first come first serve.
A: 130cm, Freedom Paracord, Silver USB-A to Silver Mini-USB with black housings. Sold
B: 130cm, Explode Paracord, Silver USB-A to Silver Mini-USB with black housings. Sold
C: 90cm, Dragonfly Paracord, Silver USB-A to Silver Mini-USB with black housings. Sold
D: 150cm, Cotton Candy Paracord, Silver USB-A to Silver Mini-USB with black housings. Sold
E: 180cm, Purple Paracord, Silver USB-A to Silver Mini-USB with black housings. Sale pending
I also have two fullsized Filco female Mini-USB cables in black Paracord from a previous batch. Price = €7/piece.[/color]
Order form will be back up in the upcoming days. Information will be provided in a next post.
« Last Edit: Wed, 02 October 2013, 10:20:43 by Paranoid »
Offline TLSC.wipeOut
  • Trade Count: (0)
  • "Who dares, wins"
Re: °Parashop° Pre-made cables for sale! Order form almost live!
« Reply #267 on: Mon, 23 September 2013, 13:20:45 »
I'm pretty excited for your shop to be back up =) glws!
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline Paranoid
  • Trade Count: (0)
« Reply #268 on: Tue, 24 September 2013, 13:25:09 »
Good news everyone! The order forms are complete and live!
Some information:
- OP has been reformed and adjusted with the sleeve in stock
- For this run I won't be ordering extra sleeve since I have an overflow of sleeve stock as we speak.
- MDPC sleeving is from now on without additional cost!
- General pricing is lowered!
- Custom request are still possible, but only via PM
- Cable making will only happen during the weekend. Combining this with a fulltime job and household proved to be rather stressful. Besides that, administration and packaging/shipping can still occur during the week.
Order Forms
Check the OP for the order form status.
« Last Edit: Sat, 12 October 2013, 13:45:27 by Paranoid »
Offline saturnotaku
  • Trade Count: (0)
« Reply #269 on: Fri, 27 September 2013, 10:33:37 »
Just ordered a pair of Black Widow 120mm cables. I have a special project that I'm working on for my Poker 2. The easy bits have been ordered, but I have some trickier items that I need to procure.
Offline Paranoid
  • Trade Count: (0)
Re: °Parashop° Order form live!
« Reply #270 on: Fri, 04 October 2013, 12:43:09 »
Just some pictures of work from the last weeks. Some from before the break :)
Offline GoatMaster
  • Trade Count: (0)
« Reply #271 on: Fri, 04 October 2013, 15:02:07 »
I know these cables ;)
Good work, I love them!
Offline Paranoid
  • Trade Count: (0)
« Reply #272 on: Sat, 05 October 2013, 02:03:57 »
Thanks Franatic89 :) I hope they have found a nice home with you ;)
Offline acidtrip69
  • Trade Count: (0)
Re: °Parashop° The place for cables! // Order form live!
« Reply #273 on: Sat, 05 October 2013, 12:45:44 »
hello i just bought a cable. I can't wait to get it. ^_^
Offline wcallen
  • Trade Count: (0)
« Reply #274 on: Sat, 05 October 2013, 20:49:11 »
wooooo, so cool
Offline hindsight
  • Trade Count: (0)
« Reply #275 on: Mon, 07 October 2013, 18:24:57 »
Just submitted an order form for a cable, and now I'm looking forward to the day I have the pleasure of using it!
Offline xandr
  • Trade Count: (0)
« Reply #276 on: Tue, 08 October 2013, 11:12:14 »
Do you have right-angled mini-usb connectors?
Sprit 60% w/MX Clear in DuckMini V2 case | Matias Quiet Pro (office)
Offline saturnotaku
  • Trade Count: (0)
« Reply #277 on: Tue, 08 October 2013, 12:17:48 »
I think I know who those belong to.  ;D
Offline Paranoid
  • Trade Count: (0)
« Reply #278 on: Wed, 09 October 2013, 12:58:01 »
Wow! Seems like the reply notification isn't working properly :D didn't see any of the replices in my email. I've received the new orders, I will contact the unanswered orders still today.
I have angled mini-usb connectors, but I am currently out of stock on those. Which way they are angled to depends on how the female connector is positioned on your keyboard. If the wide part of the connector is at the bottom, your cable will go left. If it's on the top side, it will go right. Let me know if you want to order a cable with that connector and I will restock those.
And you are correct sir ;) Let me know when you have received them :)
Offline acidtrip69
  • Trade Count: (0)
« Reply #279 on: Wed, 09 October 2013, 14:10:22 »
How long does it to make a cable ? i was wondering what your avg time making a cable. i know all the cables are not the same, but what would you say is your time spent making cables ?
Offline Paranoid
  • Trade Count: (0)
« Reply #280 on: Wed, 09 October 2013, 15:11:11 »
That really depends on the type of cable, connectors, sleeving, prepared items, custom requests etc. I don't document this so I can't really say how long it takes on average. I have some cables where I really work 5 times longer on than others though or even more (long curled cable for example)
Offline acidtrip69
  • Trade Count: (0)
Re: °Parashop° The place for cables! // On hold
« Reply #281 on: Sun, 13 October 2013, 14:55:42 »
can you please post some pics of what you have been working on lately. ^_^ plz
Offline bMind
  • Trade Count: (0)
« Reply #282 on: Sun, 03 November 2013, 03:43:47 »
Ohhh..I can't stress how much I want your cable.. :D
in flames we trust..
Offline terran5992
  • Trade Count: (0)
  • One With The Cup Rubber
« Reply #283 on: Sun, 03 November 2013, 04:00:13 »
Aww i would have really wanted to buy one
Offline Ryan Uber
  • Trade Count: (0)
« Reply #284 on: Tue, 05 November 2013, 00:14:15 »
5 reasons to buy from Paranoid if he is accepting orders:
- Very personable. If the guy lived nearby, I'd buy him a beer for sure.
- Thorough answers. So much less frustration when someone spends the 2 minutes to reply rather than typing 2 words and just hitting send.
- Prompt replies. Always within a day he got back to me.
- Honest. He gave me realistic estimates on when he could have things done, which I appreciate far more than over-promising and under-delivering.
- Awesome quality. Everything arrived as ordered, works perfectly, and is very well-made.
Paranoid is the real deal.
Thanks, buddy.
« Last Edit: Tue, 05 November 2013, 00:26:13 by Ryan Uber »
Offline Tony@HK
  • Trade Count: (0)
« Reply #285 on: Tue, 05 November 2013, 00:28:44 »
I'm so looking forward to my babes in the near future!
Offline Paranoid
  • Trade Count: (0)
« Reply #286 on: Tue, 05 November 2013, 07:31:17 »
Well, I'm currently still working on orders but my guess is that I will be taking orders again within a month or so. I will definitely post this here so if you still want a nice cable, you can order them then :)
Thanks, buddy.
Wow thanks for that awesome review Ryan! I'm very glad you liked everything overall. I try to be as helpful and informative as I can. It takes up a lot of time though but to me it makes a big difference on what kind of a service I'm offering. Don't take that one day response time too serious please. It can vary from time to time :D
Coming soon Tony! :)
Offline bMind
  • Trade Count: (0)
« Reply #287 on: Tue, 05 November 2013, 08:12:28 »
No rush, it's worth to wait for the good things :)
Offline Paranoid
  • Trade Count: (0)
« Reply #288 on: Sun, 17 November 2013, 05:19:11 »
Haven't posted in a while.
To keep you entertained, here is some of my latest work :)
Also, keep an eye out for my next post today or tomorrow, a bunch of pre-made cables will be ready for sale!
« Last Edit: Sun, 17 November 2013, 05:21:35 by Paranoid »
Offline deSheol
  • Trade Count: (0)
  • Thorpe
« Reply #289 on: Sun, 17 November 2013, 05:28:52 »
Amazing as always!
Offline catbuster
  • Trade Count: (0)
  • Fusion is Future
« Reply #290 on: Sun, 17 November 2013, 07:17:24 »
Wow very nice sleeving skills! Waiting for orders to open  :'(
Poker 2 (black) 60% mx red
Offline Paranoid
  • Trade Count: (0)
« Reply #291 on: Sun, 17 November 2013, 07:24:50 »
Amazing as always!
Thanks dude :) always appreciate your nice comments ;)
Thanks cat! Not quire sure when orders will be opening again. Working on some exciting stuff ^^ But I'm thinking I'll open it shortly before Christmas still.
Offline bMind
  • Trade Count: (0)
« Reply #292 on: Sun, 17 November 2013, 07:52:07 »
Your work and dedication is amazing :) Thanks for doing this man!
And yes, I'm also waiting for the orders to open :D
Offline Paranoid
  • Trade Count: (0)
« Reply #293 on: Sun, 17 November 2013, 08:19:43 »
Alright, Christmas came early this year ;) Here we have another batch of pre-made: cables!
MDPC:
These are sleeved with a thicker cable so they are really sturdy.
MDPC-1: MDPC-X Toxic Green, USB-A to Mini-USB, 75cm
Price = €12 - SOLD
MDPC-2: MDPC-X Red, USB-A to Mini-USB, 95cm
Price = €13 - SOLD
MDPC-3: MDPC-X Titanium Grey MKII, USB-A to Mini-USB, 115cm
Price = €14 - SOLD
Paracord:
Para-1: Paracord Neon Lime, USB-A to Mini-USB, 105cm
Price = €14
Para-2: Paracord Flame, USB-A to Mini-USB, 165cm
Price = €15
Para-3: Paracord Golden Rod, USB-A to Mini-USB, 145cm
Price = €15
Para-4: Paracord Explode, USB-A to Micro-USB, 30cm
Price = €7
Para-5: Paracord Candy Cane, USB-A to Micro-USB, Curly cable about 25cm in rest, approximately 70-90cm when stretched.
Price = €20
Packs:
Pack-1: Paracord Little Black Pink
Cable 1: USB-A to Mini-USB, 130cm
Cable 2: USB-A to Micro-USB, 65cm
Price = €25
Pack-2: Paracord Holly Jolly Christmas
Cable 1: USB-A to Mini-USB, 80cm
Cable 2: USB-A to Micro-USB, 40cm
Price = €20 - SOLD
Filco:
Detachable Female Mini-USB for fullsized Filco. Now you'll be able to disconnect or change cables easily!
Female part is about 6cm outside of the case.
Price = €7
One sold, one still available.
Shipping:
Shipping prices under 100gr (two cables average):
EU: €4
WW: €5
Tracking: + €5
Shipping prices above 100gr: +€3
Payment:
Payment can be made via Bank transfer (EU) or Paypal. In case of Paypal the usual Paypal fees will be added on the invoice.
First come first serve! Only counts when replied in the thread so everyone can see!
Purchase of multiple items is allowed.
This sale is offered on GH and DT.
Have a nice day/evening!
Your buddy,
Paranoid
« Last Edit: Sun, 17 November 2013, 15:20:23 by Paranoid »
Offline raxer
  • Trade Count: (0)
Re: °Parashop° Cable sale is here!
« Reply #294 on: Sun, 17 November 2013, 09:05:03 »
Hey, I'll take the MDPC-3 and a detachable cable for the filco.
Edit: Oh wait, the detachable does not work with the TKL right?
Offline Paranoid
  • Trade Count: (0)
« Reply #295 on: Sun, 17 November 2013, 09:11:44 »
No, these are for a fullsized Filco. They are a bit too long for a TKL I'm afraid.
Offline raxer
  • Trade Count: (0)
« Reply #296 on: Sun, 17 November 2013, 09:13:41 »
In that case I only take the MDPC-3. Thank you for quick response.
Online HendyZone
  • HHKB Elite
  • Trade Count: (0)
    • MechanicalKeyboards.co.id
« Reply #297 on: Sun, 17 November 2013, 09:23:31 »
I'll take these man
Thanks ^_^
Offline Paranoid
  • Trade Count: (0)
« Reply #298 on: Sun, 17 November 2013, 09:31:44 »
Alright, it's yours! PM is on the way
I'll take these man
Thanks ^_^
Fantastic! PM is on the way
Offline Paranoid
  • Trade Count: (0)
« Reply #299 on: Tue, 19 November 2013, 09:23:54 »
The MDPC cables are sold, but the Paracord cables are missing some love!
