Author Topic: CM storm QFR CM-SGK-4000-GKCR1-UI  (Read 6033 times)
Offline vld
« on: Sat, 08 December 2012, 04:11:41 »
Wow...havent been around here in a while :)
Here's the thing...I can get this QFR, but the code puzzles me - CM-SGK-4000-GKCR1-UI
Whats UI? The key layout is identical to the US version as far as i can tell, but the keys have some additional asian characters. Would those affect me in any way? I want to get blank keycaps anyway...im just want to know if there are any differences in the way the kb itself works.
Here's a pic
**** happens
Re: CM storm QFR CM-SGK-4000-GKCR1-UI
« Reply #1 on: Sat, 08 December 2012, 04:29:30 »
Most of the first page of Google results are in Romania, so my first guess would be a Romanian layout?
But that seems way too obvious ;)
Offline vld
« Reply #2 on: Sat, 08 December 2012, 04:34:05 »
Yeah i also googled it yesterday...like i said, in the bottom right corner of the keys, there are some Asian characters...nothing to do with Romania.
**** happens
Offline fruktstund
« Reply #3 on: Sat, 08 December 2012, 04:36:36 »
Some kind of Chinese, I think. Not very knowledgeable about Chinese keyboard layouts, so I don't know which one it is specifically (IIRC there are a few variants).
Edit: Zhuyin, apparently: http://upload.wikimedia.org/wikipedia/commons/f/fa/Keyboard_layout_Zhuyin.svg
Offline vld
« Reply #4 on: Sat, 08 December 2012, 04:42:24 »
Ok...thanks for the info, but all i want to know is if the kb "works" differently in some way. In theory it shouldn't cause the language needs to be changed in the OS, I would just like some reassurance.
**** happens
Offline fruktstund
« Reply #5 on: Sat, 08 December 2012, 04:50:29 »
I'm almost 100% certain it won't work any differently than your regular US ANSI keyboard. It still sends the same keycodes for the computer to decipher and turn into the correct characters.
Offline TotalChaos
  • Indy Game Coder
« Reply #6 on: Sat, 08 December 2012, 05:50:25 »
1. You would have to press the ALT key to generate one of those cRaZy  ^-^ symbols.
2. You won't be using the right keymap on your puter OS so you won't get those chars anyway.
So it won't really "hurt" you to have those chars on there.  They are just the wrong chars for your keymap.  If you use US INTERNATIONAL keymap layout in your OS as everyone should do, then those symbols will actually be useful things like a degree symbol or Euro symbol or Yen symbol or lots of groovy European chars.
I am assuming u r one of those guys who thinks there are only 26 letters in the alphabet.  If that is true then you can get the keyboard and it will work fine for u.  You will never know what u r missing.
« Reply #7 on: Sun, 09 December 2012, 22:41:43 »
That looks exactly like the one I purchased form PChome right when they came out. I ended up selling the asian-printed keycaps to someone. I still use it sometimes. It works normally, ofcourse. It's that exact model number and everything.
My left alt no longer works. This was an issue with some of them, and I hear newer ones are good.
Totalchaos: I strongly disagree that "everyone should" use US international as their keymap. I have on use for the added characters/complexity, and using QWERTY is just silly when I already know Dvorak
Offline TotalChaos
  • Indy Game Coder
« Reply #8 on: Sun, 09 December 2012, 22:56:25 »
Obviously a Dvoraker should use a version of Dvorak with all the extra symbols on it and more.  A Colemaker should use a version of Colemak with the extra symbols and more. etc.
All I really meant was "The standard symbols supplied on standard keyboards are a ripoff because they are missing many useful symbols that are part of the ANSI standard."
Offline vld
« Reply #9 on: Mon, 10 December 2012, 02:48:39 »
Thank for the replies guys, the kb should be here tomorrow.
**** happens
Offline esoomenona
  • Gnillort?
« Reply #10 on: Mon, 10 December 2012, 22:34:49 »
If you want to make an even trade of those caps for regular ones, PM me.
Offline YMSNoms
« Reply #11 on: Tue, 11 December 2012, 14:51:52 »
Leopold FC700R
Filco Majestouch-2 Multicamo
Korean FR4-87 Lambo Orange Custom
