Author Topic: Custom keycaps on HP Probook 4530s  (Read 11183 times)
Offline Rourke
« on: Sat, 08 December 2012, 18:48:28 »
Hello people,
I bought a HP Probook 4530s (PDF with specs) last week and installed OSX on it. Everything seems to work great, but the windows keys make it really confusing for me. So I was wondering if it is possible to replace the CTRL/FN/WINDOWS/ALT keys with the apple ones. I prefer genuine keys, but I don't mind if they are stickers, as long as they don't look too cheap.
My laptop keyboard looks like this http://i.imgur.com/lWNJh.jpg
To give you a basic idea, this is what i'd like: http://i.imgur.com/PLL7M.jpg Not the actual keys but the prints on it. As I said I don't mind stickers unless they look like this: http://i.imgur.com/BtcCH.jpg
If this seems to be doable I might change more keys to that of a macbook keyboard.
Can you guys give me some advice on this?
« Last Edit: Sat, 08 December 2012, 18:50:30 by Rourke »
Offline rayuki
  • RAAAAAAR
Re: Custom keycaps on HP Probook 4530s
« Reply #1 on: Sat, 08 December 2012, 19:16:15 »
no... you can't replace laptop keys with cherry mx keys.
Offline Rourke
« Reply #2 on: Sat, 08 December 2012, 20:23:28 »
I'm affraid you didn't understand me. I didn't mean to get the TYPE of keys in that picture. It's just to give an IDEA of how a windows keyboard got turned into an apple keyboard. I want to stick to the same keys I have in the keyboard right now ;)
« Reply #3 on: Sat, 08 December 2012, 23:11:11 »
I don't know if they are compatible, but you might look at getting an Apple notebook keyboard.  Some eBay sellers sell just the keyboard.
« Reply #4 on: Sun, 09 December 2012, 01:06:03 »
reading isn't your strength, is it.
« Reply #5 on: Sun, 09 December 2012, 03:28:13 »
Subtlety isn't your strength, is it?
Offline Rourke
« Reply #6 on: Sun, 09 December 2012, 18:02:09 »
Thanks for the suggestion. I don't think it would fit. Individual keys or good looking stickers would be the best idea I think. I just have no idea where to find that.
Offline SmallFry
« Reply #7 on: Sun, 09 December 2012, 18:04:00 »
What might work is a dry rub on sticker, not sure what they call those... Rub off the current legend with a solvent if you're ambitious and then put the new legend on.
« Reply #8 on: Sun, 09 December 2012, 18:54:49 »
No. Keyboards are almost never compatible across manufacturers. Usualy you just get a ribbon flexible membrane out, which plugs into the motherboard. The keyboard controller is on the motherboard.
You have a few options.
1. Sandpaper off the legend and try to custom paint/laser it yourself (I don't think WASDkeyboards will be able to laser it, but you can always ask, I guess)
2. Pry an actual apple key off one of their keyborads, and modify the "scissor-holding" latches on the bottom to accept the ones on your HP.
3. Get stickers.
Also, please don't break your HP, they are terrible to take apart and repair, so on behalf of all the HP repair techs, make sure you don't break it. (though the 8560p is worse, IMO) :)
« Reply #9 on: Sun, 09 December 2012, 19:07:26 »
I was thinking more of the OP getting a used or otherwise keyboard (just the keyboard) from a MacBook and swappnig the keycaps over as it looked like both use scissor switches, so hopefully those keycaps would be interchangeable.
But it looks like his Alt keys are square, and the Mac Command keys are not quite.
Offline bavman
« Reply #10 on: Sun, 09 December 2012, 19:24:20 »
Not with demik!
Offline Rourke
« Reply #11 on: Sun, 09 December 2012, 20:13:00 »
3. Get stickers.
Thanks for the suggestions. These are clear options to me.
1) Current legends are actually stickers. I think I can get them off clean without much trouble. I'll ask the people at WASDkeyboards if they can do something for me here.
2) I don't want to alter keys because i'm not good with custom work like that
3) Stickers. This would be the easiest solution, but if anyone knows a source i'd love to test it out
I'll keep it in mind. Already changed some hardware without a problem. Closely following the manual. :)
« Last Edit: Sun, 09 December 2012, 20:15:17 by Rourke »
Offline Rourke
« Reply #12 on: Sun, 09 December 2012, 20:54:33 »
I did some digging and got to this website: http://www.4keyboard.com/mac-laptop-stickers-p-218.html
It looks a lot like the picture from my initial post, but I think if I cut closely around the edges (of the key images and text) with a utility knife I can get a good result. If anyone has more suggestions I'd love to hear them.
Offline SmallFry
« Reply #13 on: Sun, 09 December 2012, 22:31:42 »
Use an X-Acto knife for more accuracy, but other than that, nada:)
Offline rayuki
  • RAAAAAAR
« Reply #14 on: Sun, 09 December 2012, 22:35:29 »
no need to be subtle i prefer bluntness lol, my bad i read it wrong. ( i have a bad habbit of posting while drunk which doesn't help)
thought he was asking to put keycaps on his laptop keyboard.
after reading it again (a few times actually) i think the sticker suggestion is probably your best option, its apple it shouldn't be impossible to find something suitable.
« Last Edit: Sun, 09 December 2012, 22:37:57 by rayuki »
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #15 on: Mon, 10 December 2012, 18:54:42 »
Okay, so the keyboard you're looking at? Is identical to the HP Envy17 keyboard. (In fact, same service part for some models. No joke.) That said: they aren't stickers on the keys. They're likely the same laser-filled PBT keys I have on mine. At least I presume it's PBT given the pebble texture and extreme resistance to shine compared to ABS.
The Windows keys feel like they're raised, but it's actually sunk some ridiculously tiny amount. I would recommend just applying stickers very carefully. Probably should remove the keyboard per service manual and clean the keys you're going to apply them to with denatured alcohol beforehand. (Or iso of at least 90%.)
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
