Author Topic: PBT Key Caps on an ISO board  (Read 3513 times)
Offline Mysteric
  • Formerly 'Mackem'
« on: Sun, 09 December 2012, 08:06:42 »
What is the best way to go about this? I have a Filco TKL UK ISO layout and I want some white engraved PBT keycaps but obviously the PBT caps are USA layout. Which keys would I have to replace and how would I go about it to get them to match (Font face, size etc.)
Thanks.
Offline dirge
Re: PBT Key Caps on an ISO board
« Reply #1 on: Sun, 09 December 2012, 08:54:19 »
Only PBT I've heard of were the ducky / denmark I think it was sets.  Not sure if they ever appeared or just vaporware.
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #2 on: Thu, 13 December 2012, 11:52:19 »
Hmm, I found them, but the blank ones will cost me almost £65 altogether. It seems like it's worth it due to them lasting longer etc.
I need to get some o-rings as well but dunno which ones to get for my MX Browns. I want something that will dampen the bottoming out sound, any ideas?
Offline dirge
« Reply #3 on: Fri, 14 December 2012, 02:16:37 »
I think wasdkeyboards is your best bet.
Offline Chau
  • .5 Korean, .25 Vietnamese, .25 Chinese, Oz accent
« Reply #4 on: Fri, 14 December 2012, 02:25:17 »
Try imsto for o rings
Offline Mysteric
  • Formerly 'Mackem'
« Reply #5 on: Sat, 15 December 2012, 11:11:59 »
Yeah, but what kind of thickness should I go for with the o-rings for my browns?
Offline dirge
« Reply #6 on: Sat, 15 December 2012, 11:25:21 »
Depends on how much travel reduction and dampening you want.  Just go for thin ones to start with.
