Author Topic: Quick Intel HD graphics question  (Read 3037 times)
Offline tipo33
  • "Ski"
« on: Sun, 09 December 2012, 18:47:58 »
Wil the Intel HD Graphics on low end sandy brige cpus output 2560x1440?
KM4COL    R.I.P.  SmallFry
Offline TheProfosist
  • Custom Layouts Only!
Re: Quick Intel HD graphics question
« Reply #1 on: Sun, 09 December 2012, 18:52:41 »
Idk about sady i know ivy will. Look up intel HD 2000 and 3000
Offline tipo33
  • "Ski"
« Reply #2 on: Sun, 09 December 2012, 19:02:31 »
Thee chip I'm looking at doesn't ave 2000 or 3000 it has the base one.  A google search brings up every Intel Graphics ever made.
« Reply #3 on: Sun, 09 December 2012, 19:02:57 »
Whats the cpu
Offline tipo33
  • "Ski"
« Reply #4 on: Sun, 09 December 2012, 19:24:58 »
Offline bavman
« Reply #5 on: Sun, 09 December 2012, 19:29:37 »
It also depends on the display, some monitors even though you have HDMI, will not support 1440p over HDMI, they'll require you to use dual-link dvi or DP instead.
What mobo/outputs do you have?
« Last Edit: Sun, 09 December 2012, 19:31:17 by bavman »
Offline tipo33
  • "Ski"
« Reply #6 on: Sun, 09 December 2012, 19:38:58 »
HP zr2740w It only has dual-link DVI and DisplayPort.
« Reply #7 on: Sun, 09 December 2012, 19:43:31 »
Yea idk about that one looksed up the proc on intels site and max res was not listed.
Offline tipo33
  • "Ski"
« Reply #8 on: Sun, 09 December 2012, 19:45:53 »
Yhea, I checked on Intel's site and Wikepedia,  but it wasn't listed anywhere.  My google search was useless...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Sun, 09 December 2012, 21:04:07 »
    Display Port: 2500x1600
    HDMI/DVI/VGA: 1920x1200
Sorry can't find the cpu spec sheet on intel site anymore that give this info, but I know it to be correct. I have Pentium G620 on Zotac H67 and that is the case for me.
« Last Edit: Sun, 09 December 2012, 21:06:38 by lysol »
Re: Re: Quick Intel HD graphics question
« Reply #10 on: Sun, 09 December 2012, 21:38:54 »
yea it used to say but not anymores. Thanks lysol!
Offline tipo33
  • "Ski"
« Reply #11 on: Sun, 09 December 2012, 23:39:59 »
Thanks for all the quik replies, but I decided to go with a descrite GPU.  Will post picks of the build when it's done!
