Author Topic: Steelseries 6gV2 Red Switch Problem  (Read 7722 times)
Offline laskjpg
« on: Sun, 09 December 2012, 18:56:32 »
So I recently purchased a Steelseries 6gV2 Red Switch, and it worked great. However, I stupidly tried removing one of the switches without realizing that these switches are soldered. The switch looks fine, but I think I messed up the internal because I lifted it partially off of the board. Any suggestions on how to fix it??
Offline TheProfosist
  • Custom Layouts Only!
Re: Steelseries 6gV2 Red Switch Problem
« Reply #1 on: Sun, 09 December 2012, 18:58:27 »
Replace the switch?
Offline laskjpg
« Reply #2 on: Sun, 09 December 2012, 19:00:38 »
I'm not sure if it's an internal problem. I'll try and switch it later this week.
« Reply #3 on: Sun, 09 December 2012, 19:08:50 »
Cherry MX switches can be disassembled (carefully) and reassembled, so it would depend on how much damage was done.
The only way to be completely sure it to replace the entire switch.
Offline laskjpg
« Reply #4 on: Sun, 09 December 2012, 19:12:21 »
If I were to desolder the cherry mx switch, how would I resolder it back together?
Re: Re: Steelseries 6gV2 Red Switch Problem
« Reply #5 on: Sun, 09 December 2012, 19:14:52 »
by using solder.
Offline SmallFry
« Reply #6 on: Sun, 09 December 2012, 19:15:31 »
I'm not sure if you damaged the PCB with ripping out the switch though...
Offline laskjpg
« Reply #7 on: Sun, 09 December 2012, 19:17:04 »
yeah that's what i'm scared of... hopefully i didn't and i could just replace the switch.
« Reply #8 on: Sun, 09 December 2012, 19:17:23 »
Yes please picture us so we can help you more/batter
Offline laskjpg
« Reply #9 on: Sun, 09 December 2012, 19:19:31 »
I would, except i don't know how to take apart the 6gV2 apart. I removed the screws in the back but it's still stuck on the top and bottom. I don't want to just pry it open... All i could show you is the switch, which looks perfectly normal
« Reply #10 on: Sun, 09 December 2012, 20:41:13 »
The existing switch could be broken beyond reasonable repair.
You would need to replace it with a new switch (probably of the same type e.g. Cherry MX blue).
Offline TotalChaos
  • Indy Game Coder
« Reply #11 on: Sun, 09 December 2012, 21:41:04 »
Is there such a thing as a keyboard that has cherry switches, but they are not soldered?
« Reply #12 on: Sun, 09 December 2012, 21:42:58 »
nope it wouldnt work
Offline YMSNoms
« Reply #13 on: Mon, 10 December 2012, 15:30:45 »
I thought they did have a solderless cherry mx board, or is my interpratation of solderless switch changes wrong?
Leopold FC700R
Filco Majestouch-2 Multicamo
Korean FR4-87 Lambo Orange Custom
Offline vun
  • Just one more thing
« Reply #14 on: Mon, 10 December 2012, 15:38:12 »
Maybe you're thinking of plate mounted switches where you can open them up without having to desolder them.
« Reply #15 on: Mon, 10 December 2012, 15:54:35 »
thats what im thinking hes thinking of
Offline TotalChaos
  • Indy Game Coder
« Reply #16 on: Mon, 10 December 2012, 16:28:02 »
Is there a list somewhere of "keyboards with plate mounted switches which do not have to be unsoldered to open the switch and lube the spring"?
What is the name of such type of keyboard?
ezmod?
ezlube?
uberkewl?
Offline vun
« Reply #17 on: Mon, 10 December 2012, 16:46:21 »
ezmod?
ezlube?
uberkewl?
The only way to open plate mounted switches without unsoldering every time is unsoldering all the switches once to replace the plate with a custom one and resolder them.
As far as I know there are no boards that come with a plate like that.
Offline royb3
« Reply #18 on: Sun, 20 January 2013, 09:08:45 »
Opening up the keyboard is quite easy, just use a butter knife if you don't want to mess up your nails. I opened mine several times, i even have painted the plastic cover with white acrylic paint.
If you need to, i can upload a picture of where all clips are positioned.
