Author Topic: White PBT Color?  (Read 2564 times)
Offline michaellthenerd
White PBT Color?
« on: Mon, 10 December 2012, 02:18:16 »
Just a quick question guys, when you are using light/ bright colored PBT caps does the color easily stain over regular usage ? (By that I am referring to the color change over a periodic usage.)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: White PBT Color?
« Reply #1 on: Mon, 10 December 2012, 16:33:20 »
PBT is pretty resistant to such things. I have PBT caps from early 80's, clean them off and they look like new again.
Offline TotalChaos
  • Indy Game Coder
« Reply #2 on: Mon, 10 December 2012, 17:03:27 »
I have super acid hands.  I melt newspapers and magazines in under 3 minutes.
I have PBT keycaps from 1987 that still look perfect and I typed the hell out of them, dropped them on floor a few times each year, gamed on them some, etc. etc.  They are all in perfect shape.
None of the keycaps were white though.  They are all Beige.  But I donno if that matters.  I have friends with PBT keycaps from 1985 that are white or offwhite and they still look perfect.
