Author Topic: Custom Keys for Laptops  (Read 1697 times)
Offline pyro
« on: Mon, 10 December 2012, 06:32:45 »
Is there such a thing? I'd really like a chiclet panic button on my laptop.
Offline firebt
Re: Custom Keys for Laptops
« Reply #1 on: Mon, 10 December 2012, 09:05:40 »
I'm not sure.  If there are any, I would assume that it would be mainly for Macbook Pros or Airs or some other Apple product that everyone would buy.  There would be too many specific types of keys that go on different laptops as they change the key layout pretty frequently, although that depends on the manufacturer and the model as well.
If anything, you may be able to get a cover for the whole thing that is customized so you can choose which keys say what.  Other than that, maybe if you hit up SP they can work something out for you, but you'd have to get the exact specs on the keys and perhaps send them a 3D CAD mockup?  It seems like a lot more work than expected, I know.
« Reply #2 on: Mon, 10 December 2012, 13:08:10 »
Apart from wooden ones mentioned recently, and stickers that someone recently tracked down, not really.
Offline TotalChaos
  • Indy Game Coder
« Reply #3 on: Mon, 10 December 2012, 13:38:21 »
Most ppl just use stickers.
