Author Topic: Question about the black on beige moogle kit  (Read 2824 times)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« on: Tue, 11 December 2012, 21:59:47 »
Will letting the sp space bar sit in the sun eventually make that space bar match the white of the black on white Cherry keys? Has anyone tried this?
Offline inlikeflynn
  • file not found
Re: Question about the black on beige moogle kit
« Reply #1 on: Tue, 11 December 2012, 22:07:26 »
maybe if it sits there for years :|
one from a CCnG set is a better match if your set is slightly yellowed
The light gray one from WASD is a better match if your set has very little yellowing.
but if its a brand new set, nothing matches it perfectly
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #2 on: Tue, 11 December 2012, 22:59:11 »
Yah I use a WASD light grey spacebar myself.  It's less pointy as well.
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #3 on: Tue, 11 December 2012, 23:34:44 »
Oh I didn't realize yellowing takes so long o.o
I think I will look into wasd. Thanks for the info guys :)
