Author Topic: looking for keyboard with turbo key functions + nkro  (Read 1701 times)
Offline chrisloup
« on: Wed, 12 December 2012, 03:45:17 »
Hi,
I'm looking for a quiet keyboard that also has turbokey functions (that are independent of the windows os repeat rate).
ie: I hold down the keys 12345678, I want it to fire 12345678 as fast as it goes.
any suggestions? is my terminology correct re the turbo key?
also:
macro programable would be nice.
should also be in standard 105 key layout (ie: no funky reposition of the \ key , or the ins/home/pgup/del/end/pgdn )
Offline FoxWolf1
  • 154
Re: looking for keyboard with turbo key functions + nkro
« Reply #1 on: Wed, 12 December 2012, 10:41:12 »
So you want:
-Ability to exceed OS repeat response rate.
-Non-clicky.
-Macro keys.
-Normal layout.
-NKRO.
The limiting factor on this one will be the "turbo mode", since it's not a super common feature...but I think you can get all of what you want with an HEC Cougar Attack X.
Offline Sinzz
« Reply #2 on: Thu, 13 December 2012, 00:21:49 »
The ducky shine that I had had turbo functions. 1-4x. I also believe it is NKRO with PS2. It has non-clicky keys available, normal layout. but no macro keys unfortunately.
Keycool 84 MX Blue | Pure Pro | HHKB Pro 2
Offline gameaholic
« Reply #3 on: Thu, 13 December 2012, 01:09:41 »
-insert joke about aging single women here-
Aside from the funny name I'd be all over that keyboard if they made a tenkeyless version.  Maybe even 60%.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline chrisloup
« Reply #4 on: Fri, 14 December 2012, 00:01:13 »
thanks for the suggestions, I'll check it out.
