Author Topic: Phantom Keyboard  (Read 3020 times)
Offline inteli722
Phantom Keyboard
« on: Fri, 14 December 2012, 22:49:03 »
Can somebody please tell me WTF this is? A quick Google search has only resulted in me finding that Phantom Lapboard (which doesn't look like it's what people are talking about). It seems like it's highly wanted among modders...
Maybe it IS actually a phantom...
Waiting for: Phantom Plate
Offline Larken
Re: Phantom Keyboard
« Reply #1 on: Fri, 14 December 2012, 22:54:37 »
that's because it's a fully custom, programmable keyboard project built from the ground up by geekhackers. see this thread for more info.
http://geekhack.org/index.php?topic=23572.0
| Ergodox #1 | Ergodox #2 |
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Fri, 14 December 2012, 22:55:13 »
Not at all.  It's a community developed cherry mx based pcb that's engineered to fit in a filco tkl case and have full programability of keys.  In fact, there was an IC started today for a second round that has a lot of information about what it does and how to make it do it.
Offline WhiteFireDragon
    • youtube
« Reply #3 on: Sat, 15 December 2012, 01:32:17 »
Main summary points of a phantom keyboard that other TKL keyboards don't have, is:
1) the ability to choose your own layout between ANSI/ISO, or bottom row modifier/spacebar size
2) programmable
3) the ability to change out or modify switches without desoldering
« Reply #4 on: Sat, 15 December 2012, 02:50:50 »
the phantom PCB also supported a very odd layout where the spacebar was split into many keys, and there are no gaps in the function row
This is what the plate looked like
(Interestingly enough, the image for te 7bit phantom on the DT wiki is incorrect: The F# row is wrong on it.)
Offline TheProfosist
  • Custom Layouts Only!
Re: Re: Phantom Keyboard
« Reply #5 on: Sat, 15 December 2012, 02:53:54 »
that image is 7bit custom plate i think im the only one that got those standard 7bit have reverse iso left shift
Offline inteli722
« Reply #6 on: Sat, 15 December 2012, 08:28:49 »
Ah. Thanks. That's better to know what it is.
« Reply #7 on: Mon, 17 December 2012, 00:46:41 »
Argh, you're right. There appear to be NO correct images of the 7bit plate on the DT wiki and the pictures they do have are both wrong and inconsistent.
If someone had a spare 7bit plate (or two) they might consider updating the DT wiki with the correct information.
« Last Edit: Mon, 17 December 2012, 02:34:15 by dorkvader »
« Reply #8 on: Mon, 17 December 2012, 01:21:09 »
BTW I do still have 2 original 7bit Custom Plates if anyone is interested.
