Author Topic: [Orders Closed] Phantom PCB R2  (Read 361428 times)
Offline Leewei
Re: [Collecting Orders] Phantom PCB R2
« Reply #100 on: Thu, 20 December 2012, 08:52:42 »
LOLOL hahahahaah :D
What if you had sweaty palms, mold grow mold!  :p :p
Build a cardboard case, bondo it, lacquer it.
Going to work on that now ^_^
boost! what kind of casing are you working on? =D
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline SmallFry
Re: Re: [Collecting Orders] Phantom PCB R2
« Reply #101 on: Thu, 20 December 2012, 08:58:04 »
LOLOL hahahahaah :D
Will you be releasing the files? Just curious:)
« Last Edit: Thu, 20 December 2012, 09:06:49 by SmallFry »
Offline reverkiller
« Reply #102 on: Thu, 20 December 2012, 09:25:07 »
I saw the old cardboard case idea, and thought that I would use it (at least for a little while) with some sort of covering to stop it from totally destroying under daily use). Screw Laser cutters - I'd do this the old fashioned way with scissors and exacto knifes!
Offline hluo87
« Reply #103 on: Thu, 20 December 2012, 09:55:11 »
hi bavman,
i have not received any invoice from you.....could you check? :eek:
« Reply #104 on: Thu, 20 December 2012, 10:13:36 »
This GB is not to the invoicing phase, yet. Patience. :D
Offline hluo87
« Reply #105 on: Thu, 20 December 2012, 10:17:03 »
lol~~~
Offline bavman
« Reply #106 on: Thu, 20 December 2012, 11:26:31 »
Okay so I decided that I'll stop taking orders January 2, 2013. That gives us a good 2 weeks to collect orders. I might have to extend it based on the circumstances.
Invoices will start going out after orders have closed
Also post 2 should be all up to date now.
I've been thinking of trying that cardboard idea but with plexiglass. I think it would look nice, but I need a dremel first
« Last Edit: Thu, 20 December 2012, 11:29:55 by bavman »
Offline KuhnTang
  • Game of Thrones
« Reply #107 on: Thu, 20 December 2012, 11:35:32 »
Nice, finally a GB that moves at a respectable pace.
« Reply #108 on: Thu, 20 December 2012, 11:43:45 »
Most people who want/need these have known for QUITE a while that they want/need them. Phantom is well-established.
I have been waiting to order these since I joined here, which was just after the original GB stopped accepting new orders. Finally got the plates I wanted when DanGWanG had The_Beast make up 20 of them for us.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #109 on: Thu, 20 December 2012, 11:44:11 »
Ordered!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #110 on: Thu, 20 December 2012, 11:49:31 »
LOLOL hahahahaah :D
Fiberglass would probably work better and less risk of chipping and whatnot.
Offline remmeh
« Reply #111 on: Thu, 20 December 2012, 12:43:08 »
in for one!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #112 on: Thu, 20 December 2012, 13:20:55 »
Half ass korean style. Roll out a nonslip pad and just lay it there.
SmallFry! <3
« Reply #113 on: Thu, 20 December 2012, 13:28:51 »
I kinda dig that. Maybe not use any keycaps, just type on the stems. :)
Offline TheQsanity
  • SmallFry Lovin'
« Reply #114 on: Thu, 20 December 2012, 13:33:55 »
Yea putting on keycaps are so overrated.  If cherry wanted keycaps on mx switches they would already be on them.
SmallFry! <3
Offline nebo
« Reply #115 on: Thu, 20 December 2012, 15:45:32 »
Instead they made their own font and laughed all the while. :(
How hard is it to make a decent firmware? I think I've finally decided on a layout (winkeyless with a fn button on the right part of right shift) but have never done firmware before. I know C so that's not really an issue.
Offline bavman
« Reply #116 on: Thu, 20 December 2012, 15:48:43 »
There are ready to flash firmwares for the phantom...im not sure though if you can mod them or not
« Reply #117 on: Thu, 20 December 2012, 16:04:25 »
hasu and Tranquilite (based on hasu's code) have programmable firmwares available for the Phantom, if I'm not mistaken. I think that is what TheProfosist uses for his custom layout (Tranquilite's).
Offline TheProfosist
  • Custom Layouts Only!
« Reply #118 on: Thu, 20 December 2012, 16:17:09 »
yes I use Tranquilite's for both my Phantom and HID Liberation Device. I am trying to get him to offer his services for my assembly GB so hopefully Ill hear back soon.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #119 on: Thu, 20 December 2012, 16:21:21 »
His services to do what exactly?
Filco w/ Imsto thick PBT
« Reply #120 on: Thu, 20 December 2012, 16:56:24 »
customize the firmware to somones layout like has has done for me in the past
« Reply #121 on: Thu, 20 December 2012, 17:05:11 »
hey bavman my GB thread is up for assembly could you please change the OP, thanks.
http://geekhack.org/index.php?topic=38471.0
Offline bavman
« Reply #122 on: Thu, 20 December 2012, 17:06:00 »
Already ahead of you :)
« Reply #123 on: Thu, 20 December 2012, 17:43:33 »
Wait, it's not possible to combine a layout file and generate your own, (Soarer's does this, I think?) or modify the firmware yourself (Here, I start to think about what I get when I change my menu.xml in openbox)
Offline akuJIWA
  • Lock 'N Load!
« Reply #124 on: Thu, 20 December 2012, 17:50:49 »
Will there be a groupbuy for the rest of the stuff needed? Profosist seems to do it, but I really want to do it myself to get to know about my keyboard..
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #125 on: Thu, 20 December 2012, 18:14:28 »
If there are I don't think bavman plans to lead them, or else he'd probably include them all in this GB lol (as he did with the teensy)
« Reply #126 on: Thu, 20 December 2012, 18:17:08 »
I dont know havnt even looked into it i just let him do it for me cause he had originally getto rigged layers before hazu's firmware
« Reply #127 on: Thu, 20 December 2012, 18:25:21 »
everything else for the most part you can pick up on your own and i though beast was going to do a plate GB
Offline gnubag
« Reply #128 on: Thu, 20 December 2012, 20:04:08 »
one for me.
let's see what layout i am going to make. :)
« Reply #129 on: Thu, 20 December 2012, 20:12:06 »
Updated my GB to include parts only as an option. bavman do you think you could add a checkbox to your google form to have it sent to me to build or what ever rreason i bring this up it should cut down on PMs about having me build them.
Offline duq
  • Connoisseur
« Reply #130 on: Thu, 20 December 2012, 23:54:57 »
Posted my form.
Thanks for setting this up Bavman!
Offline Ovoxo
« Reply #131 on: Fri, 21 December 2012, 00:11:29 »
In for 1. Thanks
Offline Tranquilite
« Reply #132 on: Fri, 21 December 2012, 15:38:09 »
Anyway, I just finished a guide to compiling a custom layout for phantoms using Hasu's firmware. While this probably isn't the best place to post this, I'm just going to dump it here anyway.
How to program a custom layout to your Phantom on Windows:
1.   Download and Install WinAVR http://sourceforge.net/projects/winavr/
2.   Download and extract Hasu’s tmk_keyboard firmware https://github.com/tmk/tmk_keyboard (Just click on the zip button if you don’t want to learn how to use git). This guide will be using hasu's firmware because it is the most feature rich (has multiple layers, nkro over usb, media keys, mouse keys, ect).
3.   browse to keyboard/phantom/ and open up keymap.c with your favorite text editor (WinAVR includes Programmers Notepad, which does a pretty good job).
Now the part you want to look at is this:
Code: [Select]
/* Layer 0: Default Layer
 * ANSI:
 * |Esc|   |F1 |F2 |F3 |F4 | |F5 |F6 |F7 |F8 | |F9 |F10|F11|F12| |PrS|ScL|Pau|
 * |~  |  1|  2|  3|  4|  5|  6|  7|  8|  9|  0|  -|  =|Backsp | |Ins|Hom|PgU|
 * |Tab  |  Q|  W|  E|  R|  T|  Y|  U|  I|  O|  P|  [|  ]|    \| |Del|End|PgD|
 * |Caps  |  A|  S|  D|  F|  G|  H|  J|  K|  L|  ;|  '|Return  | |???|???|???|
 * |Shift   |  Z|  X|  C|  V|  B|  N|  M|  ,|  .|  /|Shift     | |???|Up |???|
 * |Ctl|Gui|Alt|          Space                |Alt|Gui|App|Ctl| |Lef|Dow|Rig|
  KEYMAP(\
    ESC,  F1,  F2,  F3,  F4,  F5,  F6,  F7,  F8,  F9, F10,  F11,  F12,       PSCR, SLCK,  BRK, \
    GRV,   1,   2,   3,   4,   5,   6,   7,   8,   9,   0, MINS,  EQL, BSPC,  INS, HOME, PGUP, \
    TAB,   Q,   W,   E,   R,   T,   Y,   U,   I,   O,   P, LBRC, RBRC, BSLS,  DEL,  END, PGDN, \
    FN1,   A,   S,   D,   F,   G,   H,   J,   K,   L, SCLN, QUOT,       ENT,    0,    0,    0, \
    LSFT,       Z,   X,   C,   V,   B,   N,   M, COMM,  DOT, SLSH,      RSFT,   0,   UP,    0, \
    LCTL, LGUI, LALT,             SPC,                RALT, RGUI, APP, RCTL, LEFT, DOWN, RGHT),
The top half is just to give an idea of how the layout actually looks, and is not actually used. What you want to edit is the lower half which contains the actual keymap. The various key codes that you can use can be found in common/keycode.h note that you do not need to include the "KC_" as that is automatically added. Note that you can have up to 8 layers which can be added by copy and pasting more KEYMAP()s, and can be accessed by placing FN0-7 in your keymaps.
Additionally, if you want to change what your LEDs show, you can open up led.c and change either "USB_LED_CAPS_LOCK" or "USB_LED_SCROLL_LOCK" to "USB_LED_NUM_LOCK" if you want to track numlock instead.
One more thing to note. The current keymap.c is only configured for ansi layout. If you want 7bit or ISO layout, then some additional changes need to be made. For simplicity's sake, I've attached a separate keymap.c for 7-bit layout to this post. if you want to use ISO layout, then you can probably just use the 7bit layout while ignoring the extra keys. I've also attached the keymap that I am currently using so that you can have a better example of what you can do with the firmware.
4.   Now that we have our keymap the way we want it, its time to open up makefile.pjrc. Now scroll down to Build options. If you mapped any mousekeys in your layout then uncomment out "MOUSEKEY_ENABLE = yes   # Mouse keys" by deleting the "#" that is in front of the line.
if you want NKRO over usb then you can also uncomment out that line as well (note that to actually enable NKRO you need to hold both shifts and press 'n') Now save your changes.
5.   Now its time to actually compile our firmware. First rename Makefile.pjrc to just Makefile. Second, open a command prompt and browse to where your makefile is located (on windows vista and onward you can just hold shift, right click and select "Open command window here". From the command prompt, type "make" (obviously, dont include the ""s). Assuming all goes well, you should now have a compiled firmware hex with your custom layout. You can now program phantom_pjrc.hex to your teensy using the teensy loader http://www.pjrc.com/teensy/loader.html
6.   If you wish to rebuild the firmware, then from the command prompt, type "make clean" followed by "make"
Offline nebo
« Reply #133 on: Fri, 21 December 2012, 15:53:00 »
Thank you for that post. Didn't think it'd be that hard and then can easily put a super button on a FN layer if I really want one.
Offline NikoGasm
  • Platinum mad.
« Reply #134 on: Fri, 21 December 2012, 18:29:15 »
Put my order in. Excited to put together my own Phantom. :D
Offline fl0w3n
« Reply #135 on: Fri, 21 December 2012, 19:48:22 »
Question...is the only difference between a Phantom PCB + Teensy vs Filco PCB + ATmega32u4 bpiphany controller, the ability to run 1.5 mods, LED's, and the extra 5 keys above arrow?
Offline SmallFry
« Reply #136 on: Fri, 21 December 2012, 19:55:29 »
Yes, exactly. Well, also the famous Phantom Plate, but WFD had those for sale... ping him and see if he has extras?
Offline fl0w3n
« Reply #137 on: Fri, 21 December 2012, 20:08:06 »
I've got a PHANSI125 here, courtesy of jdcarpe, so I could use that.  I'd like to try Tsangan layout, though...oh well, should have bought one from Dan when he listed them.
Offline SmallFry
« Reply #138 on: Fri, 21 December 2012, 20:08:47 »
If you can find a place to cut plates for you, the plate files are on DT. I'll find them if you'd like.
Offline tmk1207
  • Yêu Màu Tím
    • Vietnam Mechanical Keyboard Club <3
« Reply #139 on: Fri, 21 December 2012, 20:10:08 »
update my address . please check a pm :D
Offline fl0w3n
« Reply #140 on: Fri, 21 December 2012, 20:11:14 »
Oh yeah?  Does it need to be CNC'd or Lasered? There's a good chance there's some facilities local to me that are capable of something like that...however I think I'd be more interested in getting some cases going :p
Offline SmallFry
« Reply #141 on: Fri, 21 December 2012, 20:20:04 »
It's a sheet metal plate. If you can find a place to cut them, you can get a plate:) I don't recall what the thickness must be... let me check here... .060 for Costar Stabilizers and .0625 for Cherry, I think.
Plate files are the second post from Litster, here.
Offline jabar
« Reply #142 on: Fri, 21 December 2012, 20:25:05 »
Do we have anyone setting up a plate GB? I think I could find such manufacturers in my area to serve those buying PCBs in this group buy (American made). Let me know if The Beast or anyone else is already working on plates now that this PCB GB is going.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Leewei
« Reply #143 on: Fri, 21 December 2012, 20:28:10 »
I talked to WFD and he said he will be making plates and to be on a lookout for them sometime soon.
Qsenn dt-35
Offline jabar
« Reply #144 on: Fri, 21 December 2012, 20:31:53 »
OK, good to know. Now to finalize a case provider without ripping those from Filco TKLs.
Phantom 7bit
Offline gliy
« Reply #145 on: Fri, 21 December 2012, 20:33:48 »
Placed my order :)
Offline SmallFry
« Reply #146 on: Fri, 21 December 2012, 20:41:29 »
PLU cases will work as well...
Offline bavman
« Reply #147 on: Fri, 21 December 2012, 20:45:25 »
I've been talking to WFD and we might include plates in this GB if everything works out
Offline WhiteFireDragon
    • youtube
« Reply #148 on: Fri, 21 December 2012, 20:49:49 »
Haven't had the chance to post much because I've been working overtime almost every day during these holiday seasons. Anyways, I'm designing new plates for these PCBs and should have time to finish them up this weekend. These plates fixes the problems in the old phantom plates. I'll post more about this later.
Offline Amarok
« Reply #149 on: Fri, 21 December 2012, 20:50:31 »
Sweet.
Realforce 87u 55g
