Author Topic: Where do I find a 30g-45g mushy rubberdome keyboard?  (Read 14425 times)
Offline TotalChaos
  • Indy Game Coder
« on: Thu, 20 December 2012, 16:11:13 »
I keep reading msgs from zillions of ppl claiming that their rubberdome is like "typing on a sponge" or "typing on soggy oatmeal" or "I like typing on a cloud of mousetraps, I want to feel a sharp *KABAM* with every key I press, typing on my rubberdome feels like typing on my girlfriend's boobs its horrible."  WTF?!?
I have never typed on such a rubberdome.  Every rubberdome I ever typed on has all of its force up at the top.  After applying 60g to 100g of force one collapses the dome, whereupon resistance falls to 5g until you collide with the bottom of the keyboard in a nerve-irritating, tendon-jarring crash.  Its about as healthy as driving your car into a brickwall.   :eek:
Bring on the smushy keyboards!
And don't bother mentioning Topre keyboards.  Topre keyboards don't work on PS/2 which means they do not work.  I will not pay money for a known defective product.
If someone can recommend me a MushBoard 2000(tm) that does not waste deskspace with giant blobs of plastic sticking out (like Das, Cherry, Topre) and has all its keys (not HHKB or 60% layouts) and in some sort of US Layout and has a properly functioning keyboard controller that works on ubiquitous PS/2 then I will happily buy one and try it out.  Even multiple different ones.
Doing it for Keyboard Science!  Thanx!  :)
Offline TheQsanity
  • SmallFry Lovin'
Re: Where do I find a 30g-45g mushy rubberdome keyboard?
« Reply #1 on: Thu, 20 December 2012, 16:15:39 »
New rubber domes are nice. logitech G15... something like that is cheap on ebay. Those are supposed to be good rubber domes.
Keytronic
Rubber domes feel lighter than blacks for me but most of them seem to have a bump.
only when they are cheap and get worn, do they feel bad to me. Logitech is one of my favorite rubber domes. The HP stock keyboards are pretty nice. Though they come in large varieties.
SmallFry! <3
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Thu, 20 December 2012, 16:19:31 »
40 cN? Goldtouch! But it's not that mushy. MS Natural Ergo 4k or modern Dell QuietKey are on the mushier side.
Obvious troll is obvious?
Offline lazerpointer
  • ya gotta stay phresh
i type, therefore i geekhack
Offline TotalChaos
  • Indy Game Coder
« Reply #4 on: Thu, 20 December 2012, 16:28:46 »
http://www.amazon.com/NEEWER%C2%AE-Portable-Flexible-Silicone-Keyboard/dp/B00092Q210/ref=sr_1_3?ie=UTF8&qid=1356041990&sr=8-3&keywords=flexible+keyboard
Try this. It's under 20 bucks lol! (Attachment Link)
  I read reviews of that one before and ppl said the keys were very hard to press and only registered right in the center of the key and that the whole thing was just really annoying.
Offline TotalChaos
  • Indy Game Coder
« Reply #5 on: Thu, 20 December 2012, 16:31:58 »
I don't suppose there is a list somewhere of rubberdome keyboards with force graphs or nickelometer tests at least?
So I can have some vague idea what I am getting into?
Offline TheQsanity
  • SmallFry Lovin'
« Reply #6 on: Thu, 20 December 2012, 16:35:09 »
I dont thiink they care enough. They just pump em out along with computers. sometimes their computers are poorly described also.
SmallFry! <3
Offline davkol
« Reply #7 on: Thu, 20 December 2012, 16:41:09 »
I have measured about 50 RD keyboards with a ghetto rip-o-meter, and there were some lists with results of others in the now-gone GH wiki. But it's not really worth it, because RD changes its hardness with time, and different series of the same keyboard model may feel different, the feel is affected by key travel, and at last but not least, most RD keyboards are rated at about 60–65 cN anyway.
« Reply #8 on: Thu, 20 December 2012, 16:47:22 »
I saw a picture once on GH, where a guy was cutting out 2mm sections of surgical tubing and using those as o-rings. I was kind of joking about the flexible keyboard. I highly recommend you try red switches with the surgical tubing mod --- this is the only thing I can think of that would suite your needs (I have seen your posts, and it is clear you need something which will be easy on your fingertips.... something with only resistance, and no "walls".)
Offline TotalChaos
  • Indy Game Coder
« Reply #9 on: Thu, 20 December 2012, 17:23:05 »
Yeah!  If I can find some 10A surgical tubing or even 10a nonsurgical tubing would be ok with me  :p
How was he cutting them at exactly 2mm each?
I found rubber tubes before... but I couldn't figure out how to cut them at exactly 2mm each time.  If I am off a bit due to human error then each key will feel different... not what I want.
That was what got me into looking at rubber sheets of a specified thickness.  The thickness is machine controlled so all keys will feel the same.  I will have human error cutting out the squares with my laser papercutter but that is ok as I have been told that it won't make any difference to the feel if one square O-ring is a little bigger than another.
At least the difference would be minimal.
I have purchased 3 cherry reds so far.  For testing out various experiments.  One I will keep as an "Unmodified reference board" while I make all sorts of changes to the other 2 boards.
  Exactly!  You "get it"!.   If I just had a cherry red switch with 12mm spring the spring resistance would get so high that it would just be impossible for me to crash into the steel plate and I would be so happy and could allegedly start writing code again, instead of just being limited to a few forum msgs here and there.  A long spring would provide me with resistance only, no walls.
« Reply #10 on: Thu, 20 December 2012, 19:25:49 »
Good luck finding that keyboard man.... I'm highly doubting that kind of thing will ever exist, sadly. I am just gonna eyeball the tubing when I get mine. Gonna try it on my QFR. Look on Amazon - there's plenty of hella cheap rubber tubing of all sorts.
Offline TotalChaos
  • Indy Game Coder
« Reply #11 on: Thu, 20 December 2012, 20:02:00 »
@flip
All the rubber tubing on Amazon that fits is harder than WASD O-rings.
« Reply #12 on: Thu, 20 December 2012, 20:48:04 »
If you look for the surgical tubing that's "natural amber" colored --- THAT's the good ol' stretchy elastic stuff. I use one of those tubes for my vaporizer all the time and I can tell you for sure, it's freaking elastic as heck, and probably will work perfectly. I'm gonna step it up and order the tubing today. I'll have a review on the mod soon.
Offline TotalChaos
  • Indy Game Coder
« Reply #13 on: Thu, 20 December 2012, 21:23:49 »
Yeah that was the only one out of all the zillionz listed that I liked enough to write down in my keyboard file.
It is 35a so its a bit softer than WASD O-rings.
I got my sizes mixed up so I was thinking it wouldn't work but now that I refreshed the DRAM in my brain it seems like it should work just fine.
  Can't wait to read it.  :)
Offline tobydeemer
« Reply #14 on: Thu, 20 December 2012, 21:45:41 »
Just a quick chime in-
A coworker has one of these: http://www.ebay.com/itm/Sun-Microsystems-Unix-Type-6-USB-Keyboard-3201273-01-/360360491480?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D13902%26meid%3D4303399564696272516%26pid%3D100011%26prg%3D1095%26rk%3D5%26sd%3D320545612331%26
...and it's the mushiest thing I've ever typed on. It's kinda like a soft, almost linear rubber dome that doesn't bottom out hard. Actuation effort was very low, as was tactility.
But again, as others have mentioned, dome boards are rather inconsistent, particularly as they get older.
// SGI AT101 // SIIG Minitouch  // 87 & 93 & Terminal 122 Model M // Poker II Brown // CMS QFS Gateron Green // Alps GlidePoint Rackmount // DataGeneral 6311 Acer // ...annnnd some other randoms... //
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #15 on: Thu, 20 December 2012, 21:54:22 »
If you want to feel real mush, find a REALLY used old BTC foam and foil. F*cking awful. Otherwise just go and find the cheapest crap like these and I am sure you will find one sooner than later.
Offline daerid
    • Rossipedia
« Reply #16 on: Thu, 20 December 2012, 23:11:29 »
LOL. Somebody's mad.
« Reply #17 on: Fri, 21 December 2012, 07:57:49 »
I definitely echo this sentiment. MS Natural 4000 is definitely mushy.
Offline Niomosy
« Reply #18 on: Fri, 21 December 2012, 12:30:29 »
It's mushy but could use less force on the keys.
Offline daerid
    • Rossipedia
« Reply #19 on: Fri, 21 December 2012, 12:36:15 »
Amen. I have a Nat 4k in my closet, and the other day I pressed on a few keys for the heck of it... dear lord how could I ever have thought that that keyboard was decent.
Offline nar
« Reply #20 on: Fri, 21 December 2012, 12:48:33 »
If you really want PS/2, why not just get a PS/2 Topre? Plenty of them out there :p, I'm typing this to you on a Topre connected to my PS/2 port right now.
But if you want a rubberdome, why not try those old Dell Quiet Touch keyboards, the ones that came out right after the mechanical ones were phased out. I hear those ones are actually pretty good, that is if you can find one in good condition.
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline vun
  • Just one more thing
« Reply #21 on: Fri, 21 December 2012, 13:49:12 »
I still love mine, though that's purely down to the shape rather than the keys. I haven't tried a whole lot of rubberdomes, but the 4k is by far the worst I've ever tried when it comes to key feel.
Offline TotalChaos
  • Indy Game Coder
« Reply #22 on: Fri, 21 December 2012, 20:48:57 »
The only PS/2 Topre keyboards that exist in some form of US Layout are all missing multiple (that means more than one) important keys.  Rendering the keyboard useless to me.
The whole reason I buy a keyboard is for the keys.
If a PS/2 Topre keyboard does not have the keys then it is devoid of value.
Offline Polymer
« Reply #23 on: Fri, 21 December 2012, 22:14:08 »
You're way too worried about PS2....Besides the fact that you believe you need it..there isn't actually a good reason mentioned..not even once...
Offline Niomosy
« Reply #24 on: Fri, 21 December 2012, 22:41:38 »
There are plenty of rubber domes out there that are much worse.  I wish MS would make one with MX reds and give a toggle to switch the zoom to scroll.... or someone else release something similar.  Sadly, I don't see that happening.
Offline TotalChaos
  • Indy Game Coder
« Reply #25 on: Fri, 21 December 2012, 23:12:43 »
I googled around for MS Natural 4000 force graphs.  Couldn't find one.  Does one exist somewhere?
There does not seem to be any way of removing that giant wrist rest?
That wrist rest is a deal breaker for me as it sits right where my mouse goes.
I am not a fan of split keyboards anyway.  I typed on some kind of "ergo" keyboard that looked similar to the MS Natural 4000 but it was mostly white as I recall.  It was back around 2000-2004 time frame.  It was definitely not ergonomic.  The keys were very painful as it took a lot of force to overcome the rubberdome and them *BAM* u smacked into the PCB.  Also I found the split to be very uncomfortable.   I wouldn't mind a small split with small angle or no angle.
Any other keyboards as mushy as MS Natural 4000?  Even mushier would be better :)  And less force too :)
Preferably just a keyboard, not an entire dashboard  :p
Offline Polymer
« Reply #26 on: Fri, 21 December 2012, 23:37:20 »
And still no response on the PS2...
But so I'm contributing...
Lenovo Sk-8825
Low actuation force and when it bottoms, it is mushy...Good amount of travel and when you hit bottom from there it still pushes in a bit more so you're not hitting a hard bottom.
« Last Edit: Fri, 21 December 2012, 23:53:06 by Polymer »
Offline tufty
« Reply #27 on: Sat, 22 December 2012, 15:08:22 »
Seems to me that most of your problems are to do with the way you type; if you're bottoming out, then yes, you're going to have a "smack" as you hit bottom, and yes, it's going to be unpleasant.  I know, I do it too.
I would suggest that a better solution than "buying random horrible keyboards in case they feel slightly less harsh at the bottom end of the stroke", which seems rather a case of cutting off your nose to spite your face, would be to o-ring one of your existing mechanicals.  Or force yourself to type less hard, but that's gonna be real difficult to do.
Offline TotalChaos
  • Indy Game Coder
« Reply #28 on: Sat, 22 December 2012, 18:30:09 »
I just did that (the O-ring, not cutting off my nose :)  and its 10x better this way!  WOW!  :eek:
Yeah I had no idea it would be so hard to undo years of muscle memory training.  :'(   I mean... dam....  I might even give up on reds in a few months and get lubed cherry blacks.
« Reply #29 on: Sat, 22 December 2012, 18:54:36 »
O-rings are really wonderful.
I don't think that you will find a mushy rubber dome board. You always have to press hard enough to collapse the dome.
A couple of years ago, I bought a Cherry MY board from someone here (can't remember who, sorry) and he had modded it somehow by removing springs or leaves or something.
Anyway, it was not too terrible although it was ridiculously light, probably 10-20 grams, but I couldn't use it.
I kept the caps (the only real reason I bought it) and tossed the board.
Maybe you should look for a Cherry MY board and do that mod to it .......
- D Trump 2026-10-24
Offline daerid
    • Rossipedia
« Reply #30 on: Sat, 22 December 2012, 20:17:21 »
I couldn't stand O-rings on my MX Browns (felt so wrong... like nails on a chalkboard).
But I just realized that somewhere along the way I started adjusting my typing to the board I'm currently typing on (right now I'm on my MJ2 w/ Browns, and I'm barely bottoming out).
On my Topre boards, I pretty much bottom out all the time, but it's nice because of the soft landing. I might try giving the o-rings another shot on my Blues.
Offline Polymer
« Reply #31 on: Sat, 22 December 2012, 20:36:37 »
If you don't bottom out there is no benefit from having o-rings....You certainly wouldn't want very thick o-rings because that'll only change the travel you're used to.  If anything you'd want very thin ones that will just cushion it those few times you bottom..
Offline daerid
    • Rossipedia
« Reply #32 on: Sat, 22 December 2012, 20:48:09 »
yeah, i'm pretty sure I have a pack of 40A-R or 50A-R... maybe should pick up some 40A-L and see how I like them.
Offline Polymer
« Reply #33 on: Sat, 22 December 2012, 23:32:14 »
I'm not sure why you would consider o-rings to begin with if you're not really bottoming out.
To be honest, I don't see how people type their fastest without botttoming out...I don't think I've ever seen a reasonably fast typist (100+) not bottom out while typing at that speed but I certainly can be wrong.  I think people have a very idealistic view on how, in theory, it would be great not to bottom but most people do...
Offline TotalChaos
  • Indy Game Coder
« Reply #34 on: Sun, 23 December 2012, 00:03:21 »
You are right!
Its only when I type fast that I bottom out 100% of the time.
When I go slow and concentrate then I can avoid bottoming out say 50%.
There just is not enough travel for me to avoid bottoming out.
I can't believe its the 21st century and all keyboards still have a teensy weensy little amount of travel (4mm) just like they did back in the 20th century, before mp3s, before the internet, before BBSes, before touchtone phones.  What have keyboard companies actually been doing all this time?
The rest of the world has been advancing in technology while keyboards have gotten stuck.
Offline daerid
    • Rossipedia
« Reply #35 on: Sun, 23 December 2012, 01:29:20 »
Well, have you ever tried typing on a keyboard with no travel? It sucks. Talk about crashing your fingers. You get zero tactility, so you have no feed back as to whether you're hitting the right key, and you hit the keys harder  as a result, causing your fingers to hurt after 5 minutes.
While things like these may be "cool" as a novelty, they suck for actual use. Turns out the 20th century hit on some pretty good tech when it comes to keyboards. Keyboard companies have tried all sorts of new advances, but they never sell, because it's damned near impossible to improve on the basic keyboard tech (not saying you can't improve layout).
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #36 on: Sun, 23 December 2012, 03:55:40 »
How do you work that out as being defective? Do they claim it works via PS/2 and include a PS/2 plug or adaptor? Not sure how many modern computers even still have PS/2 ports in them, I've not had a computer with one in for God only knows how long.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline vun
« Reply #37 on: Sun, 23 December 2012, 07:37:44 »
I've had PS/2 ports on all my motherboards, but I wouldn't say the lack of PS/2 makes a keyboard defective as it's not a requirement to be a keyboard at all. My old WYSE board uses some weird RJ11 connector, it doesn't work with my computer but that doesn't make it defective.
But apparently any keyboard that doesn't cater to his specific needs is either defective or an ancient relic that needs to get with the times and start using 10mm travel switches.
« Reply #38 on: Sun, 23 December 2012, 07:51:10 »
Defective is a term used most commonly to state that something is broken or does not do as it claims it will do. So basically the correct word in this case to use would be compatible. Unless of course Topre keyboards claim they are PS/2 compatible and they really are not, that would be defective. However it is in no way a defect just because it lacks such a feature. /me gets off soapbox.
Offline Polymer
« Reply #39 on: Sun, 23 December 2012, 08:23:43 »
What I think is funny is he doesn't even have a particular reason for it.  Sure, technically PS2 has some very minute advantages but they're not likely to be noticed by anyone..not to mention PS2 is eventually going to go bye bye...`
« Reply #40 on: Sun, 23 December 2012, 09:12:08 »
Since I am not a gamer, I am indifferent to the minute speed advantages of the PS2 over the USB.
Although almost all of my motherboards have had the socket (including one with a single socket color-coded half purple and half green) I don't like them much.
As you know, if you read my posts, I hate almost all plug/socket situations (with the exception of the power cord on a MacBook) because they are fraught with weaknesses.
A PS2 socket that has been used many times does get very loose and weak.
Full-sized USB connections seem fairly sturdy (although the small ones don't) and the ability to hot-plug is huge, for those of us who experiment regularly.
Although I am sometimes a traditionalist, I am happy to move to the USB plug at the cable-to-computer connection point.
« Reply #41 on: Sun, 23 December 2012, 09:14:34 »
I have never found any issues using USB connections for keyboards when gaming, same goes for mouse. I do not see why it would be an issue to the majority unless they are in some really hardcore gaming league where needing to press the entire keyboard at one time is an issue or something, I can't see what the problem is.
Offline Polymer
« Reply #42 on: Sun, 23 December 2012, 09:47:00 »
The difference is so minute it is basically a nothing....and even less than a nothing if you aren't gaming.  Not that I'd even consider using Topre's for gaming...
Offline vun
« Reply #43 on: Sun, 23 December 2012, 10:10:11 »
Even if you prefer PS/2 over USB there is not enough of a difference between them to be a deciding factor for most people. If you can use PS/2 you can use USB and most likely not notice any difference whatsoever.
Offline TotalChaos
  • Indy Game Coder
« Reply #44 on: Sun, 23 December 2012, 12:24:56 »
PS/2 is universal and works everywhere.
USB1.1 is not universal.  It only works on devices with a USB 1.1 port.
Millions of electronic devices in the world have a PS/2 port but no USB 1.1 port.  These devices require a PS/2 keyboard because USB keyboards cannot connect to them.  You cannot connect a Topre keyboard to a PS/2 port with any adapter.
Millions of electronic devices in the world have a USB 1.1 port but no PS/2 port.  So what?  You can still plug your PS/2 keyboard into your USB 1.1 port with a $10.00 adapter or  a $5.00 adapter or a $3.00 adapter.
Also it is completely ludicrous to pay $300.00 for a keyboard that is so badly designed that it lacks basic features that countless other $5.00, $10.00, $15.00, $40.00, $45.00, $55.00, $90.00 keyboards have.  Why is it that every keyboard company in the whole world can figure out how to make a keyboard work on both PS/2 and USB, except Topre?
Why does a $40.00 Rosewill work on PS/2 and USB but not a $300.00 Topre?
Why does a $44.99 Ducky work on PS/2 and USB but not a $300.00 Topre?
Why does a $90.00 CM QFR work on PS/2 and USB but not a $300.00 Topre?
Is it because Ducky, Rosewill, and CoolerMaster are real keyboard companies and Topre is not?
Is paying $300.00 for a set of rubber domes not supplying enough profit to Topre to hire some high school kid to fix their controller?  How is it that countless other keyboard companies make and sell rubberdome keyboards for $20.00 and less and stay in business?  What is that $280.00 of profit paying for?  It sure isn't paying for one single computer programmer to fix their controller.
Can we now please go back to the actual topic, which is about mushy rubberdomes not made by Topre?
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #45 on: Sun, 23 December 2012, 13:15:55 »
You are basically trolling topre users by calling them defective which is completely false, no where is topre advertising ps2 on products like the 87U. Who cares if the controller doesn't support an adapter? You've done this are several posts on geek hack too since you joined; You have talked similar lies about the Topre and HHKB. Because of this i think it is completely valid we call you out on your bull$h!t in your topic.
If compatibility is your reason for PS/2, USB has been on computers for 15 years. Whatever computer you are using that doesn't have usb ports is not worthy of a modern mechanical keyboard.
If NKRO is your reason for PS/2 then you are a sucker. Needing NKRO is all in your head; its a placebo . 6KRO is all you need; it's fact.
Offline tufty
« Reply #46 on: Sun, 23 December 2012, 13:54:15 »
And, as has been pointed out previously, even without device-specific drivers, doing NKRO is not a problem for USB *except* in the case where you're using boot protocol.  Need NKRO for entering a set of boot parameters (about the only time you're likely to be restricted to boot protocol on a keyboard)?  No, thought not.
As for USB itself, there's nothing requiring a keyboard to use 1.1, or, even /low speed/ 1.1.  Full speed USB 1.1 would allow somewhere upwards of 150,000 keyboard packets per second.  I doubt our friend can type that fast.
Offline daerid
    • Rossipedia
« Reply #47 on: Sun, 23 December 2012, 13:57:12 »
Because they made  a conscious decision to not support PS/2, something that you seem incapable of grasping.
And in the current day and age, I'd argue that USB is actually available on MORE devices than PS2, by a large margin. I've never seen a phone with a PS2 port, but there are hundreds of millions of phones out there with USB ports.
« Last Edit: Sun, 23 December 2012, 13:58:54 by daerid »
Offline vun
« Reply #48 on: Sun, 23 December 2012, 16:21:22 »
Target market.
Do I really need to elaborate?
Offline Polymer
« Reply #49 on: Sun, 23 December 2012, 18:28:23 »
It is because they choose not to.  It obviously isn't hard..it isn't that they can't, they obviously see it as completely unnecessary.  I'm sure you'd agree that is why even if you don't agree with the decision.
The weird thing is, you're sticking to this purely based on some ideology.  You can't possibly buy a keyboard that doesn't support PS2 even though there isn't a real reason why you want PS2.  Do you have some weird machine that you'd want to buy a HHKB for but can't because it doesn't have USB ports? That would be odd...or some ancient gaming machine that can't handle USB keyboards properly?  I don't really get it..
There are some advantages to PS2..but they're almost insignificant...this compared to the convenience of USB....I'm not saying don't use PS2..but you seriously harp on about it on this forum like it there is some serious flaw...the only flaw I see is the logic in getting caught up in that...
It is definitely near the bottom if not the bottom of the list of features I'd care about on a keyboard....
