Author Topic: Mouse Mod  (Read 2410 times)
Offline colorcutclarity
Mouse Mod
« on: Fri, 21 December 2012, 05:47:14 »
Was hoping to get some advice from people who like to mod crap. If I were to move a sensor from one mouse and put it into another, IE. ZOWIE sensor into a Steelseries Ikari - would that be possible? I really like the ZOWIE sensors and the Ikari shell but the sensor in the ikari has a liftoff distance that is not ideal for me.
Thanks in advance.
Offline jeroplane
Re: Mouse Mod
« Reply #1 on: Fri, 21 December 2012, 07:42:04 »
There's no reason why it wouldn't. You'd just have to move parts around to make it fit in the case and make the buttons line up with the switches.
My signature hasn't changed since 2012. I should really update it.
Offline simkev
Re: Mouse Mod
« Reply #2 on: Wed, 26 December 2012, 06:20:14 »
Just do it, dont forget to post the result.
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
