Author Topic: HHKB+WaterField  (Read 2405 times)
Offline BlindRAGE606
  • Prince of All Saiyans
HHKB+WaterField
« on: Sat, 22 December 2012, 12:25:29 »
I know that the more expensive variant of WF's cases such as the "Keyboard Sleeve" do fit the HHKB, but how about the cheaper "Keyboard Socket"?
Feel free to post pics of your HHKB w/ your WF Sleeve!
DUCKY TKL MX BLACK | HHKB PRO 2 | BEAST PH&LACEWOOD
Offline limmy
Re: HHKB+WaterField
« Reply #1 on: Sat, 22 December 2012, 13:32:43 »
Be careful when you put Topre keyboards in a bag.
You could possibly ruin rubber dome underneath a key when it is depressed for a long time. It is less of an issue for Cherry switches which use springs, but it would certainly cause problems on rubber dome keyboards.
Re: HHKB+WaterField
« Reply #2 on: Sat, 22 December 2012, 16:56:17 »
I've read conflicting stuff upon more research, so I just ordered a gun sock to keep it in. Hopefully it works out.
Offline reaper
Re: HHKB+WaterField
« Reply #3 on: Sat, 22 December 2012, 17:05:33 »
Their customer service is top notch..  I gotta say.  :)
Din Eli
Re: HHKB+WaterField
« Reply #4 on: Sat, 22 December 2012, 17:11:46 »
Looks sharp, I have seen those pics floating around on the net. Is that yours reaper, missing your logo?
Also, are those keys constantly compressed when in the bag... and has it damaged the keys?
Offline reaper
Re: HHKB+WaterField
« Reply #5 on: Sat, 22 December 2012, 17:13:55 »
Thanks and yeah, that's mine and the fitting is a little tight in the beginning but then it stretches out (leather).  It touches the keycaps but doesn't press down on them so no problem there.
Din Eli
Offline Steamboat
Re: HHKB+WaterField
« Reply #6 on: Wed, 07 August 2013, 13:09:01 »
Which gun sock from Amazon fits the HHKB or Poker 2 best?
I was looking these for my Poker 2 just because they were so cheap...
http://www.amazon.com/Allen-Company-Knit-Handguns-14-Inch/dp/B0013LM2P6/ref=pd_sim_sg_1
http://www.amazon.com/VISM-NcStar-Discreet-Pistol-Case/dp/B003OBK7NW/ref=pd_sbs_sg_3
