Author Topic: NES Controller/Rubber Dome Key CONTACTS  (Read 2359 times)
Offline bear95
« on: Tue, 25 December 2012, 13:53:50 »
So I was cleaning my nes controllers because they weren't as responsive as I wanted. Going diagonal was pretty difficult to do. So I took it apart and I was cleaning the place where the rubber dome thing touches the pcb. I was cleaning a key but then the black stuff(carbon?) came off to show a bit of copper? underneath. I stopped and tested it to make sure it worked and it did work really well but I was wondering if I should continue cleaning or not? Is the black stuff carbon(conductive) or copper oxide(non-conductive)?
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
Re: NES Controller/Rubber Dome Key CONTACTS
« Reply #1 on: Tue, 25 December 2012, 14:19:40 »
you should replace all the contacts with cherry mx switches like a tru playa
i wonder how hard it would be to get some of them in there..
Offline bear95
« Reply #2 on: Tue, 25 December 2012, 14:29:13 »
The A and B buttons feel nice as it is. I would really love replacing the d-pad with cherry switches because they're the ones causing the problems and are really icky. Height could be a problem but a bigger problem I think is getting them to fit so close together.
Offline SmallFry
« Reply #3 on: Tue, 25 December 2012, 14:43:41 »
You can solder to the pad if you can find the copper. Like this... from Ripster's Nostromo Modification.
« Last Edit: Tue, 25 December 2012, 14:45:26 by SmallFry »
Offline bear95
« Reply #4 on: Tue, 25 December 2012, 15:04:43 »
I did some measurements and the switches barely fit together. For the height, I would have to cut into the pcb in order to actually fit. It could be a possible because looking at the pcb through the light, there is nothing else that I would cut. But I'd rather not do this.
For my nes controllers I would rather stick with the rubber domes for now. BUT I'm actually considering making a gift for a teacher for doing my college recommendations. He uses a computer to teach and I have considered making a nes themed wireless controller so he doesn't have to go back and forth all the time to scroll down and zoom in/out. I'm definitely going to put in cherry switches for those.
Going back on topic. Isn't copper more conductive than carbon? I would think that having just copper would conduct electricity better than having carbon on top.
