Author Topic: Noppo Choc Mini won't work in Windows Advanced Boot Options  (Read 1269 times)
Offline tukra
« on: Fri, 28 December 2012, 18:49:01 »
I just plugged in my new Noppoo Choc Mini 84 w/ MX Browns (Yeah Santa) and it's awesome.
Then my computer crashed for other reasons and the Windows Advanced Boot Options screen that comes up on reboot after a crash (or w/ F8) doesn't respond at all. The Noppoo works in the BIOS and in Windows and even F8 to bring up that screen but the menu itself doesn't work.
Anyone got a clue? I know they use some crazy USB controller in this to get NKRO over USB but it will be a drag to have pull out another keyboard every time my computer crashes.
Can anyone with a Choc Mini see if it works for them too? Reboot and hit F8 right after the BIOS screen, before the Windows logo comes up to see the screen I'm having trouble with.
Offline khanable
  • Keyboard Punk
Re: Noppo Choc Mini won't work in Windows Advanced Boot Options
« Reply #1 on: Sat, 29 December 2012, 18:14:23 »
Heh. I just sent mine back because my motherboard wouldn't even post with it plugged in.
Wish I could be of more help, but I found no reasonable solution to using that keyboard.
