Author Topic: Cherry MX Blue modding?  (Read 8125 times)
Offline TheGrey
« on: Sun, 30 December 2012, 13:11:59 »
Dear all,
I've been using a Poker with MX blues for a while now. Whilst I love them, I want to have a lighter acutation force, but preferably with the tactile bump. And when I mean light, I mean the lightest possible.  ^-^
So I was thinking...would pulling out the spring of a MX Red and then keeping the stem and body of a Blue give me the lighest tactile bumpage?
Many thanks,  ;)
Grey
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Cherry MX Blue modding?
« Reply #1 on: Sun, 30 December 2012, 13:28:42 »
MX Reds and MX Blues have the same spring :)
Your best bet would be some custom springs.
Offline TheGrey
« Reply #2 on: Sun, 30 December 2012, 13:47:26 »
:D..so would an MX Red stem result in no more tactile or sound? I have very minimal idea of which property of the switch has which effect!
Offline kmiller8
« Reply #3 on: Sun, 30 December 2012, 14:02:27 »
reds would remove the tactility yes, as for sound, they would remove the click you hear with blues, but if you bottom out you will still hear the "thunk" from the stem hitting the bottm of the housing. So if you can type without bottoming out, the only noise you would hear would be the switch returning to the top of the housing, which would be very very minimal.
E: WASD has a nice video comparing the three major switch types.
reds would sound the same as blacks, just require less force to actuate/bottom out
« Last Edit: Sun, 30 December 2012, 14:05:13 by kmiller8 »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sun, 30 December 2012, 14:49:47 »
You will want to find yourself some 52g springs, good luck.
Offline TheGrey
« Reply #5 on: Sun, 30 December 2012, 15:03:53 »
and so the journey begins.....
Offline rekanise
« Reply #6 on: Sun, 30 December 2012, 15:06:29 »
I'm too scared to try to mod my switches in case I break it!
« Reply #7 on: Sun, 30 December 2012, 15:17:57 »
It's fairly hard to break switch when open on pcb mount. Occasionally one of the top tabs can break off if you are super rough or they are really old and brittle but that's about it. Just don't jab around inside the switch when it's open as the crosspoint leaf is easier to ruin. If you bend it up you will have to replace the switch most likely.
Offline WhiteFireDragon
    • youtube
« Reply #8 on: Mon, 31 December 2012, 19:55:18 »
MX red and blue springs are the same. Blue feels heavier because of the tactile bump. A 55g Korean spring or lower will be a lighter spring, but if you put a lighter spring in, the linear motion area of the switch will be lighter, but you'll actually feel more of the tactile part.
