Author Topic: Replacement keycaps for CM Trigger  (Read 8004 times)
Offline TAdams
  • Professional Lurker
« on: Sun, 30 December 2012, 19:54:05 »
Hello,
 I am curious about the availability of replacement keycaps for the Trigger keyboards. I looked through the CM Store "parts" area but was unable to locate anything.
Thank you.
i want to unsee that - eyebleach plz!
Offline CM-Rajiv
  • CM Storm Rep
  • * Moderator
Re: Replacement keycaps for CM Trigger
« Reply #1 on: Tue, 12 February 2013, 18:44:01 »
Which ones are you looking for specifically? I can get more details from my CM Store reps ..
Cooler Master USA - CM Storm Marketing Team - [CM Storm Trigger CherryMX Green Switch]
Offline TAdams
« Reply #2 on: Sun, 14 April 2013, 23:48:10 »
Actually, the entire set would be a relatively easy way to order. My apologies for the late response!
Offline TAdams
« Reply #3 on: Sun, 15 September 2013, 15:32:25 »
Can no longer read the word "Shift" on left shift key. The "A", "D", "S", and "Q" have rough edges around the letters.
edit: Image attached.
35819-0
« Last Edit: Tue, 17 September 2013, 20:39:52 by TAdams »
« Reply #4 on: Sat, 21 September 2013, 02:06:55 »
As you have more than 60 posts, someone here might have swapped all caps out on their Trigger and may be looking to unload the default keycaps - you might try a WTB thread in classifieds.
