Author Topic: Taking off CM QFR case  (Read 3637 times)
Offline akuJIWA
  • Lock 'N Load!
« on: Mon, 31 December 2012, 21:59:24 »
Are there any guide to taking apart the CM QFR case? I have been trying to use the search function and couldn't find it. I was thinking to spray paint the case, harvest the switch and get ready for phantom.
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline alaricljs
  • I be WOT'ing all day...
Re: Taking off CM QFR case
« Reply #1 on: Mon, 31 December 2012, 22:00:47 »
Search up taking apart a Filco, same basic idea.  Might even beat you to it.
Litster did a vid...
« Last Edit: Mon, 31 December 2012, 22:02:36 by alaricljs »
Filco w/ Imsto thick PBT
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Mon, 31 December 2012, 22:02:58 »
Offline akuJIWA
  • Lock 'N Load!
« Reply #3 on: Mon, 31 December 2012, 22:21:43 »
Thanks good bros! Time to have fun!
quit
Offline t2russo
« Reply #4 on: Mon, 31 December 2012, 23:26:23 »
I'm glad other people are gonna be converting QFR's!  I'll be putting my silver branded with blues under the knife and hopefully converting it to ergo-clears.  Of course I also had to order a backup all-black QFR in greens so I don't have to rush the conversion... yeah, that's how I'm gonna justify it.
« Reply #5 on: Tue, 01 January 2013, 03:42:38 »
The QFR is a good base for modding because it is cheap (leaving more cash for the extras), but also reasonable quality.
