Author Topic: My poor catleap :(  (Read 3615 times)
Offline bavman
My poor catleap :(
« on: Wed, 02 January 2013, 16:52:21 »
My backlighting died on my catleap today. Or something....
Is this fixable? Sometimes if i tap on my desk while I'm typing it'll momentarily come on (the left side thats darker) for a fraction of a second.....any ideas?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: My poor catleap :(
« Reply #1 on: Wed, 02 January 2013, 17:00:22 »
Test with different cable, different gpu? It's totally white or can you see image faintly?
Offline bavman
« Reply #2 on: Wed, 02 January 2013, 17:03:11 »
No the image is completely fine. It displays everything normally...but the backlighting seems to have died on the left side
« Reply #3 on: Wed, 02 January 2013, 17:07:29 »
Oh, different issue then. I saw the white screen... so just probably some led going out. Simple enough repair maybe, depending on how accessible things are inside. But I would replace all the led if you do so it has the same. You don't want to end up with mix of warm and cool 'white' led.
Offline bavman
« Reply #4 on: Wed, 02 January 2013, 17:08:59 »
I'll try opening it and looking. I didn't know you can replace individual leds in the monitor
« Reply #5 on: Wed, 02 January 2013, 17:12:27 »
led backlight, they are usually just a strip of led. Some have the 'x-mas lights' effect where it burn out and the rest don't work. They really shouldn't chain them that way but... they do.
Offline bavman
« Reply #6 on: Wed, 02 January 2013, 20:10:46 »
Lysol you were right. Took me about 30 minutes to take it apart. There are 2 strips of led lights at the bottom each with a plug for power. One of the plugs is completely deattached from the led PCB. I have no idea how it happened but the pins are extremely thin, like a fraction of a mm. I have no idea how I'm going to solder them back together....my soldering iron is way to big for that. I need to find a super fine one or someone to do it for me
« Reply #7 on: Wed, 02 January 2013, 20:14:50 »
Maybe some soldering tweezers? If you don't want to chance it I would look for a tv repair. They should be familiar with it by now.
Offline bavman
« Reply #8 on: Wed, 02 January 2013, 21:43:19 »
The thought of paying someone close to $100 to fix something I can do my self bothers me. Anyways, I went to radio shack and picked up this little guy:
http://www.radioshack.com/product/index.jsp?productId=4314833
It came with a bunch of really small tips, but soldering that connector back on there was a huge pita.
Thanks for the help lysol!
« Last Edit: Wed, 02 January 2013, 21:50:12 by bavman »
Offline esoomenona
  • Gnillort?
« Reply #9 on: Wed, 02 January 2013, 23:11:02 »
So it's working fine now?
Offline bavman
« Reply #10 on: Thu, 03 January 2013, 00:30:55 »
Yup :D
It had gotten even worse than that picture in the OP. I'm guessing when I had taken the picture not all power was lost to the left side
« Last Edit: Thu, 03 January 2013, 00:32:31 by bavman »
Offline esoomenona
  • Gnillort?
« Reply #11 on: Thu, 03 January 2013, 00:32:29 »
Yay! Good work, guys.
Offline chewyfruitloop
« Reply #12 on: Thu, 03 January 2013, 05:12:02 »
you sometimes find that heat + vibration over time can work stuff out of the socket, especially if it wasn't in there properly to start with
glad this only cost you time to fix  :D
das blue, mac chicklet, old mac clear hair catcher
