Author Topic: Need help with keycaps  (Read 3148 times)
Offline bazemk1979
« on: Wed, 02 January 2013, 21:31:33 »
Hey guys just saw DS cherry board G81 and been thinking to give offer for it, here is the dilema, I already ordered rosewill 104 board and would not mind to have DS keycaps for it.
So here i will post the pic of the board and which keycaps will I need to make it complete.
i remember there was GB for people with cherry boards keycaps, it was the bottom row modifiers + space bar, but I know I will need the 0 on the numpad and maeby something more?
Just want to get rough idea of how many keycaps will I need to find and if its not worth it I'll just order the white on black from SP they have it available to be purchased + I think I'll like the Black DS with white legends for the Rosewill to match the white logo. Here is the pic of the G81 HUBUS
Offline bazemk1979
Re: Need help with keycaps
« Reply #1 on: Wed, 02 January 2013, 23:53:38 »
wow no reply?
Offline esoomenona
  • Gnillort?
« Reply #2 on: Wed, 02 January 2013, 23:56:05 »
You'll need a Moogle and if you want the numpad, a 2x 0 and a 2x +, and if it matters a lot to you a - in the correct profile.
Offline bazemk1979
« Reply #3 on: Thu, 03 January 2013, 00:14:31 »
Ok just to make sure, cause I'm confused a lil bit here, so this is what I need.
-Moogle kit
-2x 0
-2x +
How about page up, page down, ins, home, print screen, scroll lock pause. Will they fit on the rosewill in the same rows, or I will have to end up scatering them around just to make them fit in the proper row even though function wont = to whats printed on the key?
Does SP sells just keys you need, or just full sets? If I stand correct CHERRY G81-7000HUBUS-2 stands for doubleshots keycaps right?
« Last Edit: Thu, 03 January 2013, 00:16:54 by bazemk1979 »
Offline esoomenona
  • Gnillort?
« Reply #4 on: Thu, 03 January 2013, 08:16:08 »
Yes, those are what you'll need. The other keys you mentioned will fit. The Del, End, and PgDn will be a little taller than what you might be used to looking at being that they're actually R4 (the row profile of the top two [tallest] rows instead of R3 as they would be on a Rosewill, but it's really not bad at all. I have them like that on my board.
Someone else will have to help you with the Cherry product code deciphering.
Offline bazemk1979
« Reply #5 on: Thu, 03 January 2013, 09:21:37 »
cool thanks buddy, I do believe any Cherry board that starts with H stands for double shots
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Fri, 04 January 2013, 11:33:05 »
You would be better off getting Cherry G80-8113, or 8200 and grab cheap G81-8000 for the function, nav and ANSI enter and 1.5 \| if needed. That is the quickest path to a nice full Cherry doubleshot set. Forget those SP keys, when you can have the real thing all Cherry 100%.
