Author Topic: GH60++ Possibilities for 65, 70 & 75% full-custom keyboard designs  (Read 90074 times)
Offline Bullveyr
Re: GH60++ Possibilities for 65, 70 & 75% full-custom keyboard designs
« Reply #50 on: Sun, 17 February 2013, 14:19:45 »
... and if breakable section, perhaps do 2x column also on the left for function or macro key like model f at style.
So if I understand that correctly with the break-lines that would also work for the 75% (6x16)?
I would like that.
Quote from: ripster;185750
Mechanical switches are mechanical.
Offline RickyJ
« Reply #51 on: Sun, 17 February 2013, 15:53:22 »
Great job so far, I'm liking it much better than my Race layout!
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #52 on: Sun, 17 February 2013, 17:19:58 »
I am going to do a version specifically for the Race case.  That will be v.3.
This is v.2 (free-standing) and is slightly too deep to fit into the Race case.  Apologies for the Sunday afternoon Potato Picture.
 - Ron | samwisekoi
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #53 on: Mon, 18 February 2013, 02:12:01 »
do you have the source files for the plate? it should be a DWG, right?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #54 on: Mon, 18 February 2013, 09:13:38 »
I do and it is.  It was based off of the Poker plate DWG file.
For v.3 I am going to:
- Remove the flanges so it can fit directly into a Race case.
- Add mounting holes to match the Race, if possible (more switches means less room for holes.)
- Revert to a multi-mount for the Caps Lock key (centered or offset.)
I will probably also make a sub-60% for a retro keyboard model that will have smaller mods and a dedicated arrow block. And possibly a flanged Poker plate to enable a free-standing Poker "Monster".
I'll put all of the design files up on the wiki, along with a build guide.  Probably this week.
 - Ron | samwisekoi
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #55 on: Mon, 18 February 2013, 09:19:32 »
that's great! thanks for sharing your work!
« Reply #56 on: Mon, 18 February 2013, 15:02:25 »
Ron inspired me to do this (40% board):
If it works, I'll see if Ron will host the drawing file for you experimenters.
« Reply #57 on: Tue, 19 February 2013, 02:26:43 »
12*4; Interesting. Are you going for this?
http://ne0.cc/laygen/
Code: [Select]
Esc::1.0  Q::1  W::1  E::1  R::1  T::1  Y::1  U::1  I::1  O::1  P::1  Bksp::1$$
Lock::1.25  A::1  S::1  D::1  F::1  G::1  H::1  J::1  K::1  L::1  Enter::1.75$$
Shift::1.75  Z::1  X::1  C::1  V::1  B::1  N::1  M::1  <,::1  Shift::1.25  Fn::1$$
Ctrl::1.25  Fn::1  Alt::1  Space::6.25  Alt::1.25  Ctrl::1.25$$
I can't go that small, but I very much want to do a Miniature Dvorak KB (13*4)
Code: [Select]
Esc::1  '::1  ,<::1  .<::1  P::1  Y::1  F::1  G::1  C::1  R::1  L::1  /::1  Bksp::1$$
Tab::1.25  A::1  O::1  E::1  U::1  I::1  D::1  H::1  T::1  N::1  S::1  Enter::1.75$$
Shift::1.75  ;::1  Q::1  J::1  K::1  X::1  B::1  M::1  W::1  V::1  Z::1  Shift::1.25$$
Ctrl::1  Fn::1.0  Alt::1.0  ::6.25  Alt::1.25   Super::1  Ctrl::1.5$$
Or maybe something a little larger (14*4)
http://i.imm.io/WI3n.png
Code: [Select]
Esc::1  '::1  ,<::1  .<::1  P::1  Y::1  F::1  G::1  C::1  R::1  L::1  /::1  =::1  Bksp::1$$
Tab::1.25  A::1  O::1  E::1  U::1  I::1  D::1  H::1  T::1  N::1  S::1  -::1  Enter::1.75$$
Shift::1.75  ;::1  Q::1  J::1  K::1  X::1  B::1  M::1  W::1  V::1  Z::1  Shift::1.25  Fn::1.00$$
Ctrl::1  Super::1  Fn::1.0  Alt::1.0  ::6.25  Alt::1.25  Meta::1.25  Ctrl::1.25
What do these plates cost? I want to make one now. I always thought using the plate as a case was the best KB design. Maybe with a panel-mount USB jack on the back or something: http://www.mouser.com/ProductDetail/Amphenol-Commercial-Products/MUSBB551042/?qs=sGAEpiMZZMulM8LPOQ%252byk6V7JFh%252bQKX34iD2mjgWOK8%3d
Ron, can you clarify exactly how the teensy is mounted in your (excellent) free-standing case? Is there a picture of the bottom you can show, or is it not wired yet?
« Last Edit: Tue, 19 February 2013, 02:35:07 by dorkvader »
« Reply #58 on: Tue, 19 February 2013, 09:54:32 »
I originally designed that layout to work with kmiller8's 40% PCB design. He included it in his layout options. That's about as small as I can get it. I wanted it to stay rectangular, and use commonly available keycap sizes. And I like a full size spacebar on my keyboards. I will probably eliminate all redundant keys, like the 2x Ctrl and Alt, in favor of others.
I really like that KB Layout Editor. Very slick and helpful!
The plates are only ~$25/ea from The_Beast. His laser guy does an awesome job cutting these. I've always liked the idea of using the plate as a "case," also. Like in the original Dox design. The Dox is what inspired my call to action on the GH60, which in turn helped motivate komar to design the PCB. I have a couple more design ideas I'm going to be prototyping like this. It will let you know if your design is usable, without the expense of having a custom PCB made.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #59 on: Tue, 19 February 2013, 12:54:14 »
V.2 (freestanding) is not wired.  This "Retro GB" has pulled all of my attention for the moment.
My current plan is to mount a small platform under the back-rear of the chassis and cut or drill a hole for the USB connection.
 - Ron | samwisekoi
« Reply #60 on: Fri, 22 February 2013, 11:44:34 »
Ron, I created an offshoot of this thread for making new designs beyond the scope of your OP.
http://geekhack.org/index.php?topic=40567.0
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #61 on: Fri, 22 February 2013, 12:23:47 »
That 40% looks great jdcarpe, really exciting. I also like the 65% where it is barely larger than a Poker/Pure but allows non function layer arrows, PgUp, PgDn, Home, and End. Fn + backspace for Delete is not very hard to do. 75% looks good for gaming, especially in games where F1-F5 can be used.
Offline JPG
  • Model F is my new passion!
« Reply #62 on: Fri, 22 February 2013, 12:42:00 »
Just a question here: Would it be "hard" to make a pcb/plate to support full backlighting? No custom keyboard supports it so I presume it's mostly because it's already hard to support multiple layouts with 1 pcb and/or a lack of interest. It's just a fancy feature most of the time, but still interesting :)
And this 65% ... /drool  ;D
Offline alaricljs
  • I be WOT'ing all day...
« Reply #63 on: Fri, 22 February 2013, 13:08:50 »
The hard part is lighting *features* making it lit isn't all that hard at all.
Filco w/ Imsto thick PBT
Offline simkev
« Reply #64 on: Sun, 03 March 2013, 12:24:37 »
I've posted a few times in various threads about a GH-custom keyboard layout larger than a GH60 but with all the reconfigurability of a GH60.  I've been calling it the GH60++, and this is its own thread.  (Apologies to any thread owners where I took things OT.)
So here is a 75% keyboard layout I like:
Theoretical 75% keyboard layout.
AFAIK, it can't be made on any PCB or plate available today.  What I envision for the GH60++ is a variety of sizes with a common core.
GH60++ 60%  5x15
GH60++ 65%  5x16
GH60++ 70%  6x15
GH60++ 75%  6x16
Here they are again in ascending size order:
GH60++ 60%  5x15
GH60++ 65%  5x16
GH60++ 70%  6x15
GH60++ 75%  6x16
So much for pretty pictures.  I can make them all day.  But to make the keyboards real we need:
 - Layouts
 - PCBs
 - Plates
 - Cases
 - Keycap Sets
All of those skills exist in this community, and right now all of them are working on other projects, especially the GH60 itself.  So this thread is for discussion of possibilities for now.  IC and GB threads will come after the GH60 is a real keyboard we can all build and type on.
One thing that is interesting to me is the possibility of a multi-use PCB for the GH 60++. This approach is used in other industries, although I've never seen it used in keyboards.  Basically it would be a 75% PCB with a couple of break-lines to enable it to be used in all four configurations.  Something like this:
GH60++ 75% PCB with break lines for 60, 65, and 70% sizes.
For now, all of the above is just a discussion-starter.  The real GH60 is the place for real work to keep happening.  I might make up some physical mock-ups and perhaps sketch a case design or two, but that is it for now.
I look forward to the comments of anyone interested in this topic!
 - Ron | samwisekoi
How do you make those keycaps layouts?
JAG ÄR LIVRÄDD FÖR ATT LEVA & JAG ÄR DÖDSRÄDD FÖR ATT DÖ
| Poker X - Ergo Clears & Red Alert 2.0 | Majestouch 2 TKL - Browns & Blue Cream Cheese |
Offline calavera
« Reply #65 on: Sun, 03 March 2013, 13:27:51 »
I'm interested in the production cost of those PCBs.
Can someone who has experience break down the cost to manufacture one PCB?
Offline Fred
« Reply #66 on: Tue, 05 March 2013, 06:25:54 »
Dat 65%. Dat 65%. The only thing i'm missing on the Pure (aside from it not being in ISO) are those arrow keys. And the programmable keys, of course.
The 75% doesn't look bad either!
« Last Edit: Tue, 05 March 2013, 06:30:15 by Fred »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #67 on: Tue, 05 March 2013, 08:43:08 »
Thank you!  :cool:
The 75% is sitting there waiting for me to finish the invoicing process for the Retro DSA group buy.  Then I'll get the Weller and camera out and finish that and post a build log.  I got as far as the populating the caseless, free-standing plate with mostly Cherry MX Brown switches, a few Reds and some white LEDs from a Race.
14981-0
75% "eRace" v.2 free-standing plate, populated.
I am considering doing the 65% using the yet-to-be started Retro Blue keycap set.  I think the combination would be an awesome homage to early IBM terminals and the honorable Selectric.
 - Ron | samwisekoi
« Last Edit: Tue, 05 March 2013, 08:45:23 by samwisekoi »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #68 on: Tue, 05 March 2013, 09:00:33 »
I'm working on this
looking forward to my DSA retro keys!
Offline DamienG
    • DamienG
« Reply #69 on: Thu, 07 March 2013, 14:10:03 »
I think that 75% is my optimal layout :) Look forward to PCB and plate availability.
[)amien
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #70 on: Thu, 07 March 2013, 18:42:25 »
I'm working on this
Dang, we should have used green for the arrows on the brown keys!
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #71 on: Wed, 13 March 2013, 19:51:05 »
Invoicing and ordering for Retro DSA is done, so I had some time to work on the GH75 today.  I have a thumb drive full of photos to process and upload for the build-log. I'll get those up after dinner tonight.
This is v.2, so I was able to do it properly, and so that anyone else will be able to replicate the process.
More in a while.
 - Ron I samwisekoi
[edit] Apparently I took 50+ high-resolution photos to get as far as the first row positive (diode) rail complete.  Lots to process before uploading. Soon! [/edit]
« Last Edit: Thu, 14 March 2013, 10:55:07 by samwisekoi »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #72 on: Thu, 14 March 2013, 18:32:32 »
Hard-Wiring How-To is being loaded to the wiki here:  http://wiki.geekhack.org/index.php?title=Hard-Wiring_How-To
15735-0
PCBs? We don't need no stinkin' PCBs!
Lots more to go, but it will all be there in the end.
 - Ron | samwisekoi
« Reply #73 on: Thu, 14 March 2013, 19:05:50 »
 - Ron | samwisekoi
Awesome!
Offline esoomenona
  • Gnillort?
« Reply #74 on: Fri, 15 March 2013, 09:34:50 »
I love you, Ron.
Offline hargon
« Reply #75 on: Mon, 18 March 2013, 10:51:52 »
Very nice, please keep us posted.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #77 on: Mon, 18 March 2013, 22:20:22 »
Just stopping by after you mentioned it in another thread.  Like those breaklines.  Totally awesome idea!
« Last Edit: Mon, 18 March 2013, 22:23:03 by metalliqaz »
Offline Skull_Angel
« Reply #78 on: Tue, 19 March 2013, 02:19:40 »
Thank you!  :cool:
 - Ron | samwisekoi
75% layout with 1.25 left-hand mods and Cherry stabilizers... I think I just wet myself... The stepped caps lock bugs me a bit, but it's not that big of an issue considering the rest of the design (I like swapping caps <> control as an MMO gamer).
« Last Edit: Tue, 19 March 2013, 02:23:00 by Skull_Angel »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #79 on: Tue, 19 March 2013, 11:31:31 »
Thanks.  The caps lock is likely to end up as an either/or placement.  I am used to the stepped caps lock on my Model M, so I add it to my other keyboards.  The GH75 v.1 allowed you to install the caps lock shifted left or centered, but I dropped that for this version.  GH75 v.3 will revert to a wide slot for your choice of placement.
 - Ron | samwisekoi
Offline esoomenona
  • Gnillort?
« Reply #80 on: Tue, 19 March 2013, 12:05:12 »
Offline sordna
« Reply #81 on: Tue, 19 March 2013, 14:41:14 »
Just noticed this thread. 5x16 (65%) would be my preferred compact keyboard... I really miss arrows on my Poker.
Although with programmable Pure Pro, Tex, and Filco MINILA coming out, there are suddenly a lot of options now!
Offline Skull_Angel
« Reply #82 on: Tue, 19 March 2013, 16:23:10 »
 - Ron | samwisekoi
Oh awesome, now I just have to start saving up and hope my GF doesn't find out how much I want to spend on one... haha
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #83 on: Thu, 21 March 2013, 19:11:48 »
More work on the board.  The matrix is complete.  I also reduced the number of LEDs.
16478-0
Hard-wired GH75 Matrix Completed
Also, more images have been prepped and uploaded to the Wiki How-To:
More image manipulation and uploading to come, then wiring the Teensy harness and adding firmware.
Enjoy!
 - Ron | samwisekoi
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #84 on: Fri, 22 March 2013, 03:11:33 »
very good job, Ron. thanks for sharing!
Offline viowastaken
« Reply #85 on: Wed, 27 March 2013, 10:20:18 »
Hopefully this project will have made even more progress by the time i need my next 75% becuase what I've just seen in this thread is just about the nicest keyboards evar! :)
Filco Majestouch Tenkeyless Cherry MX Brown with Ducky thick PBT white/grey
Offline vardhana
« Reply #86 on: Wed, 27 March 2013, 11:23:57 »
Enjoy!
 - Ron | samwisekoi
What did you use for rail? Tinned Wire?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #87 on: Wed, 27 March 2013, 20:32:03 »
Enjoy!
 - Ron | samwisekoi
Yes. 18g tinned wire.  The hard part was straightening it.  Brass rod would be cool, but I could not find any.
Offline JPG
« Reply #88 on: Wed, 27 March 2013, 21:49:40 »
Dumb question, but how do the switch "stick" to the plate?. Does it "clicks on" or is there something else to keep it in place once installed?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #89 on: Wed, 27 March 2013, 21:53:19 »
They snap right into place.  In fact they are hard to remove.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #90 on: Thu, 28 March 2013, 00:15:05 »
How easy was that for you samwisekoi?
Where did you get that plate btw??
This is all pretty amazing!
SmallFry! <3
Offline simon_C
« Reply #91 on: Thu, 28 March 2013, 16:18:19 »
read the thread dude. Its all there.
Offline DamienG
    • DamienG
« Reply #92 on: Fri, 29 March 2013, 00:03:58 »
Just realised out of scope of topic. removed.
« Last Edit: Fri, 29 March 2013, 00:27:58 by DamienG »
Offline hargon
« Reply #93 on: Tue, 02 April 2013, 03:25:23 »
How thick is the plate? I guess 1.5mm from a wquick look at the cherry switch drawings but i wanted to make sure.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #94 on: Tue, 02 April 2013, 03:31:53 »
yes, 1.5mm for MX. 1/1.2mm for Alps
« Reply #95 on: Tue, 02 April 2013, 15:35:45 »
Definitely 1.5mm or 0.06", per the spec sheet.  I have seen that some acrylic designs use much thicker material for the plate. (2mm or more)  I don't own one, so I am definitely wondering how they work.  Obviously the switch still fits, but it won't "click" into place.  Anyone have one of those?  Acrylic is much less stiff than metal, which is why the thicker material is needed.
« Last Edit: Tue, 02 April 2013, 15:41:31 by metalliqaz »
Offline domoaligato
« Reply #96 on: Fri, 17 May 2013, 14:53:41 »
Enjoy!
 - Ron | samwisekoi
could you please post a pic showing how the positive diode side (rows) and the other side (columns) connect to the teensey?
« Last Edit: Fri, 17 May 2013, 15:55:50 by domoaligato »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #97 on: Fri, 17 May 2013, 22:41:06 »
Enjoy!
 - Ron | samwisekoi
Yes.  That turned out pretty well, but I need to get a new battery and/or charger for my camera this weekend.
 - Ron I samwisekoi
Offline domoaligato
Thanks Sam !
Offline Chanc3
« Reply #99 on: Tue, 10 December 2013, 06:20:05 »
This is a great idea, looking into something similar myself, albeit with a PCB
