Author Topic: What keyboard is this?  (Read 1347 times)
Offline BlindRAGE606
  • Prince of All Saiyans
« on: Sat, 05 January 2013, 10:15:21 »
It's a Texas Instruments VPU200, the keys look spherical? It's a local seller so I might just make a quickbid just for the keys if its worth it.
DUCKY TKL MX BLACK | HHKB PRO 2 | BEAST PH&LACEWOOD
Offline jeroplane
Re: What keyboard is this?
« Reply #1 on: Sat, 05 January 2013, 10:17:07 »
Most sphericals off old boards will not fit on MX switches. Correct me if I'm wrong if anyone has information/experience with this particular unit.
My signature hasn't changed since 2012. I should really update it.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Sat, 05 January 2013, 10:25:04 »
Best case it may be some Alps board, but it could be almost anything. TI used a lot of different things back in the day and were not really consistent at all. Unless someone happen to have this, you probably won't know unless you go take a look in person or convince them to pull a keycap and take a picture for you.
