Author Topic: Modifications  (Read 69805 times)
Offline rknize
    • metaruss
Modifications
« on: Sat, 05 January 2013, 20:43:45 »
These are the articles that I've put together for the modifications section of the wiki:
IBM Model M
KBC Poker X
Russ
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: Modifications
« Reply #1 on: Fri, 11 January 2013, 05:13:32 »
IBM Model M
KBC Poker X
Me likey. *hat tip*
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: Modifications
« Reply #2 on: Sat, 27 April 2013, 20:20:41 »
It should be noted that laptop chicklet keys are the perfect donor plastic to fix cracked/broken barrel frames. You can add these pics to the wiki with a reference to me. (I can't do it myself as I have no wiki account)
That ground off spot is where I was testing plastic cements, just ignore it.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
