Author Topic: Similar Look  (Read 1671 times)
Offline dachef
Similar Look
« on: Sun, 06 January 2013, 00:06:20 »
I'm for a cheap keyboard that looks same as this Ducky Keyboard* BUT it can be a regular keyboard.  I could be either mechanical or a regular keyboard.  The cheaper the better.  I looking for a price range under $75.  Since I'm looking for a regular keyboard I was hoping to spend as less as $20.  The key features I'm looking for is same key layout and important it has to be the same size and frame.  Thanks in advance for the help!
http://tigerimports.net/sunshop/index.php?l=product_detail&p=11456
Re: Similar Look
« Reply #1 on: Sun, 06 January 2013, 03:09:18 »
Do you want mechanical or rubber dome?
The Ducky you have linked is just standard ISO tenkey layout - so you are spoiled for choice really.  If you are saying that you would prefer to spend at most $20, then you would almost certainly be looking at rubber dome.
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
Re: Similar Look
« Reply #2 on: Sun, 06 January 2013, 04:29:18 »
I think they mean they would like to spend at least $20 less than $75? If not, rubber dome it will be, unless a Rosewill comes up for cheap again soon.
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline uJalled
  • Shrimp cracker enthusiast
Re: Similar Look
« Reply #3 on: Sun, 06 January 2013, 10:02:18 »
Sometimes the CM QFR is out for an excellent price, you might want to check these keyboards out: as a general rule of thumb, blue +brown switches are better for typing and red+black switches are better for gaming), though personally I don't believe in it
http://www.amazon.com/Storm-QuickFire-Rapid-Mechanical-SGK-4000-GKCL1-US/dp/B0068INSUM/ref=sr_1_1?ie=UTF8&qid=1357488074&sr=8-1&keywords=coolermaster+keyboard
Offline uJalled
Re: Similar Look
« Reply #4 on: Sun, 06 January 2013, 10:03:02 »
The blue switch is more in your price range though
