Author Topic: Do you think this is safe for the laptop?  (Read 9244 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« on: Tue, 25 September 2007, 23:42:53 »
So you think this is OK for the laptop or would the heat be too much? I like the way it feels, so waht do you think?
This is some guy in Japan or something, this is the way he rolls. I found it on Flickr.
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Wed, 26 September 2007, 00:55:59 »
Might have a marginal effect on the he management, but not enough to really worry about (as long as it isn't sitting on a blanket or something that will stop it from cooling from the bottom).
