Author Topic: Dye sub vs Engraved !?  (Read 4113 times)
Offline michaellthenerd
« on: Mon, 07 January 2013, 21:43:36 »
I really like both but im conflicted as to which one i should buy from qtan's if only i could have both... Can anyone please explain the main difference between the two besides their obvious look difference ? :-\
Offline jeroplane
Re: Dye sub vs Engraved !?
« Reply #1 on: Mon, 07 January 2013, 22:13:04 »
You will be able to feel the engraving under your fingertips when you type. On the other hand, the top of dye-sub keys feel completely flat. The general consensus around here is that dye-sub PBTs are the best-feeling and also the most durable.
Go with dye-sub, you will not regret it.
« Last Edit: Mon, 07 January 2013, 22:22:20 by jeroplane »
My signature hasn't changed since 2012. I should really update it.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Mon, 07 January 2013, 22:20:09 »
I'd go with dye sub.
Personally I haven't really try yet but I suspect engraved keys will get dirty in the long run.  Like having finger grease build up in those engraved grooves.
Also like jeroplane said, with engraved key you'll feel where the writings are, where as dye sub it's perfectly flat.
Offline Loligagger
« Reply #4 on: Tue, 08 January 2013, 01:39:29 »
I can barely feel the letters on my engraved caps. Just go with whatever you think looks best.
« Reply #5 on: Tue, 08 January 2013, 10:16:20 »
I would only ever get black engraved if I go engraved again.  Dirt shows well with engraved keycaps.
Offline linkz
« Reply #6 on: Tue, 08 January 2013, 10:35:40 »
Type with chopsticks to avoid having dirts get trapped in the engraved keycaps.
Offline reverkiller
« Reply #7 on: Tue, 08 January 2013, 10:54:28 »
« Reply #8 on: Tue, 08 January 2013, 21:21:35 »
Thanks for the feedback guys I think I am going to pursue dye sub keycaps!  :)
