Author Topic: HHKB Pro 2 v. SMK 85  (Read 34633 times)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« on: Thu, 27 September 2007, 02:51:46 »
Both of these keyboards blew me away. They can both stand on their own, and I would be happy to use either as my daily 'board. In the end, the HHKB wins, but not by much.
The Alps sliders on the SMK 85 are the best switches I've ever used. The HHKB's switches are in second place. The Alps are so clean, and the HHKB switches seem like they are muffled a bit and that adds a slight artafact to the action. The Alps do not do that, they are wide open, light enough to the touch and balls out loud. So why is my HHKB my favorite keyboard?
It's not because it cost a lot.
It is because of the design. The amount of thought that went into this layout is unbelievable. For Macs it just rules. Use this thing with Unix commands and it's like you have the total control of a full sized keyboard in the smallest possible number of keys. And it's quiet enough for me to use at work and school, which I could never do with the SMK 85.
I still use the SMK 85 for writing from time to time, but the Happy Hacking Keyboard Pro 2 is the best keyboard I have ever heard of, seen, used or have owned.
« Reply #1 on: Thu, 27 September 2007, 03:32:28 »
Offline xsphat
  • Enlightened
« Reply #2 on: Thu, 27 September 2007, 03:50:58 »
Quote from: Whiskey in the Jar-o
Your journey is far from over, grasshopper. Behold!
http://www.stenograph.com/productdetails.aspx?id=100001&subid=4620001&childid=&subchildid=&prodid=30070&nocall=1
That was funny. How long have you been saving that one for this kind of opportunity?
« Reply #3 on: Thu, 27 September 2007, 03:57:58 »
Quote from: xsphat
Ever since you got your HHK.  :D Let's face it, you will never go that far in your quest. :D I've looked at these things before. I am intrigued by their adjustible keyfeel, of which I still know nothing.
Offline xsphat
  • Enlightened
« Reply #4 on: Thu, 27 September 2007, 04:56:04 »
What is it for?
« Reply #5 on: Thu, 27 September 2007, 05:00:12 »
Court transcriptionists use them.  I think you need to demonstrate sustained 225 wpm to be qualified.
Offline xsphat
  • Enlightened
« Reply #6 on: Thu, 27 September 2007, 05:03:23 »
Man, I'm a writer, not a typist. I could never type that fast.
Offline xsphat
  • Enlightened
« Reply #7 on: Fri, 09 November 2007, 03:41:43 »
Well, it's been a couple months since I posted this, so where do I stand on the old SMK 85 vs. HHKB Pro 2 battle after a hundred or so hours on each?
Well, I am using the SMK 85 right now. It is just a better keyboard, that's all there is to it. It types better than the HHKB, it feels more solid and it is even more rare than the HHKB Pro 2. The SMK 85 is loud and strong. Plus, I can type faster on this than any other keyboard I own. If anyone here finds one of these with Apls sliders or Cherry blues, I think you would be mad to not pick it up.
So there you have it folks, the $50 unknown model kicks the butt of the $280 legend.
I don't really know what else to try now. I am thinking about getting something with the Cherry blue switches, since I don't own anything with them. Here is a couple options:
The iOne Scorpious M10
http://www.barrys-rigs-n-reviews.com/reviews/2007/hardware/m10key/m10key.htm
This one looks cool and is cheap, but it is a full size 'board, and I think I would ahave a hard time going back after so long of having space savers.
Option 2 is a the Cherry 1800 series:
http://www.cherrycorp.com/english/keyboards/Industrial/1800/index.htm
I'm not really sure which Cherry switches come with this one, but I have a feeling Cherry makes a model like this with the blue sliders I so desire.
Anyone know of another space saver with Cherry blue switches?
BTW, The Deck 82 key is out - read their forums, the admin posted something stating that Deck 'boards will only use the black linear MX switches, and they have no intentions of switching to the blues.
« Reply #8 on: Fri, 09 November 2007, 04:59:35 »
Quote from: xsphat
Not truly mechanical. It's rubber-dome with spring return. Linear feel only.
http://www.cherry.de/english/products/keyboards_g81-1800.htm
http://translate.google.com/translate?u=http%3A%2F%2Fwww7.ocn.ne.jp%2F%7Ehisao%2Fimage%2Fg81hbu.htm&langpair=ja%7Cen&hl=en&ie=UTF8
Offline xsphat
  • Enlightened
« Reply #9 on: Fri, 09 November 2007, 11:50:40 »
There are seveal verios of that ketyboard available. Check out my link to Cherry's USA site. It clearly states, several times, that this model comes with some variation of the MX switch.
« Reply #10 on: Fri, 09 November 2007, 16:20:28 »
Quote from: xsphat
Cherry boards usually have model numbers like:
G8X-YYYY
The YYYY part describes the form-factor. X marks the technology.
G80 - mechanical - MX switches.
G81 - semi-mechanical - rubber with spring return.
J82 - membrane cheapy. Made in China.
G83 - quiet membrane. Cheap, soft.
G84 - mechanical - ML switches.
G85 - scissor-switch. 20% larger keytops.
G86 - heavy-duty membrane. Loud, springy. 20% larger keytops. Responsive keys. Can type softly, or hammer away. I like it.
Offline xsphat
  • Enlightened
« Reply #11 on: Fri, 09 November 2007, 23:34:00 »
So are you telling me Cherry doesn't even make a keyboard with blue sliders?
« Reply #12 on: Fri, 09 November 2007, 23:50:08 »
They probably do, but the model number would definitely start with G80. Actually on that  link you posted, amongst the various G81-1800 models, there's a lone G80-1800 model (says "MX switches" next to it). Also this is definitely mechanical: http://www.cherrycorp.com/english/keyboards/Industrial/11900/index.htm . I belive that you have the option of clicky sliders, but the default is MX linear. Ask them.
Offline xsphat
  • Enlightened
« Reply #13 on: Sat, 10 November 2007, 00:03:18 »
I called Cherry this morning and got a woman's voice mail. She didn't call back, and I knew it was going to be a his is a dead end because girls generally can't stand me, so they never call me back. I'll try again next week.
« Reply #14 on: Sat, 10 November 2007, 01:01:27 »
Everybody loves iMav.
Offline xsphat
  • Enlightened
« Reply #15 on: Sat, 10 November 2007, 01:27:39 »
Offline iMav
  • geekhack creator/founder
« Reply #16 on: Sat, 10 November 2007, 06:53:48 »
Ok xsphat.  You are looking for a spacesaving, blue (high tactile) Cherry switch keyboard.  The SMK-88 is an obvious choice...but appears to be no longer available from anywhere (with the blue switches that is).  Otherwise, I think we are going to have to go do some digging.
Offline mr_sf_applet
« Reply #17 on: Sat, 10 November 2007, 09:03:57 »
Quote from: xsphat
Aside from finding something with Cherry blue switches, how about the Matias Tactile Pro 2.0 with Alps clone switches, despite the supposedly less than stellar build quality?
Or how about the SteelSeries 6G with Cherry non-clicking switches?
Offline xsphat
  • Enlightened
« Reply #18 on: Sat, 10 November 2007, 11:58:43 »
I agree with iMav, I'll just have to dig around and keep checking eBay.
I never liked the Matias, but that's a mute point, because I already have 3 keyboards with Alps sliders. I only want blue Cherry sliders because they are supposed to be really good and I want to try them.
As for the SteelSeries 6G, I've never even heard of it, but it looks cool.
I think I should just buy the iOne M10. It's not a space saver, but it's my cheapest option by far, and it got good reviews.
« Reply #19 on: Sun, 11 November 2007, 01:17:08 »
The Scorpous-M10 definitely seems the way to go if you want blue Cherry switches. You can even see a picture of a Cherry blue on the M10 at http://www.clickykeyboards.com. Do we know of any other keyboard with confirmed Cherry blue key switches?
Yeah, the SteelSeries 6G looks pretty cool. But the SteelSeries 7G, not yet released, and enhanced or bloated -- depending on your point of view -- with gaming/multimedia controls/ports, may be even coolor. I'm not even a gamer, and I find myself lusting after it. I don't have a clue, though, as to the exact type of Cherry key switches used by the 6G and 7G and where they fit into the Cherry typology.
« Reply #20 on: Sun, 11 November 2007, 01:27:55 »
Nice. Though I don't think I'd want to pay the premium for the hand-rest, as nice as it looks. Pretty certain it would have MX linear switches. It's a consiparcy I tell you. It does look a bit like a Filco, though:
http://www.diatec.co.jp/en/det.php?prod_c=448
The "Designed in Denmark" probably refers to the wrist rest and heavy duty cord.  And I think I've seen a somewhere a Japanese Cherry switch keyboard with a wrist rest like that as well.
« Reply #21 on: Sun, 11 November 2007, 01:42:34 »
Filco has this:
http://www.diatec.co.jp/en/det.php?prod_c=9
I think it's Alps though. This is its Japanese 89-key sibling:
 http://tinyurl.com/2nxcqq
« Reply #22 on: Sun, 11 November 2007, 02:10:57 »
Yep, definitely white Alps sliders on the Japanese one. I sure wouldn't mind getting a compact board with white Alps sliders, but it's almost impossible to get Filcos here, isn't it? I remember a few months back trying to find places where I could order a Filco Majestouch, with no success.
« Reply #23 on: Sun, 11 November 2007, 02:13:22 »
Quote from: mr_sf_applet
No need to tremble with anger: http://www.fdjp.com/
Offline xsphat
  • Enlightened
« Reply #24 on: Sun, 11 November 2007, 02:28:44 »
Have you used this site, Whiskey? I'd love to believe in this ...
Offline xsphat
  • Enlightened
« Reply #25 on: Sun, 11 November 2007, 02:38:09 »
That space saver by Filco looks so cool, but god knows how much that would cost to ship here. I have seen clones of it around and they all have Alps switches, so I bet that would be a really nice board.
« Reply #26 on: Sun, 11 November 2007, 02:43:34 »
Quote from: xsphat
Alas, no. But there are others like it. So I don't think the idea itself is a scam. For example, you can order a HHKP2 from amazon.co.jp via these guys:
http://jp-eshopping.com/entry/211_toprated_sellers/amazon_japan.html
Offline xsphat
  • Enlightened
« Reply #27 on: Sun, 11 November 2007, 02:51:50 »
Whiskey, you are bottomless pit of keyboard information. I'm impressed.
« Reply #28 on: Sun, 11 November 2007, 03:11:26 »
Quote from: xsphat
Oh you... :o  And I only have half-a-dozen keyboards would you believe.
Offline xsphat
  • Enlightened
« Reply #29 on: Sun, 11 November 2007, 03:14:13 »
What are they? (only the good ones)
« Reply #30 on: Sun, 11 November 2007, 03:27:40 »
That depends on your definition of good, by which, I suspect,  none of them are.
Northgate Evolution (white alps)
2 x Plum (Cherry ML)
MS Natural ergo 4000 (membrane)
MS Natural ergo Elite (membrane)
Cherry Cymotion Solar (membrane)
Acer Accufeel (ancient membrane, steel bottom)
(The keyboard on my Asus laptop probably doesn't count.)
I don't think mechanicals are my bag. I find ML's too stiff.  I can't help bottoming out on the clicky Alps, and the resulting vibration through my fingers is painful after a while. Perhaps I'd like Cherry MX more. I think they have more travel. I wouldn't mind a decent space-saver scissor-switch for my next keyboard. But then again, I have too many already. I have to stop myself from buying more. I think it's a losing strategy though, because I end up spending heaps of time reading reviews, wondering if I'd want that or other keyboard. Pretty sad really. I'd waste less time if I just got on with it and bought them.
Offline xsphat
  • Enlightened
« Reply #31 on: Sun, 11 November 2007, 03:41:24 »
Dude, I'm right there with you. But I also have keyboard moods. Like some days I pull out my other keyboards just for a different feel. My justification of this is that I am a professional writer, and I take my writing very seriously, so the keyboard is my paintbrush. I write differently on the Model M than on the HHKB Pro 2, for example, and it comes out in my voice. I would like to know if I am the only one that feels this way ...
We differ on preferences, but I respect that. I love bottoming out the keys on the SMK 85. It's thunderous and feels so powerful. My girlfriend is used to the clicky-ness, so she really doesn't even notice. Plus, I gave her my SMK 88 with black MX sliders and she started to like the clicky mechanical keyboards, to.
That's why I'm thinking about buying an M10 sometime soon. I have a feeling the Cherry blues are just gonna rock, and the 'board is fairly priced.
« Reply #32 on: Sun, 11 November 2007, 04:48:06 »
Yeah I too have keyboard moods. On the other hand, I feel like they are a diversion - just another way to procrastinate. After all some of the best stuff was written/created in pretty ****e working conditions. Speaking of which, I think that lack of a perfect office chair is all that stands between me and greatness.
« Reply #33 on: Sun, 11 November 2007, 11:42:09 »
I think you're spot on about the linear MX switches, Whiskey. Here's a picture of a 6G with a key popped open to reveal a black Cherry MX (from a review at hexus.net):
http://img.hexus.net/v2/gaming/steel/s6g_large_9.jpg
There's no reason to think that the 7G would have different key switches. (Is there a definitive listing somewhere on the web -- aside from this site's Wiki -- that associates the color of the Cherry MX switches with the key action -- linear, tactile, etc.?)
"Designed in Denmark..., produced in Taiwan" makes me wonder if the OEM relationship is with the Strong Man Enterprise Co., Ltd. (the SMK-85, SMK-88, etc.). There's currently a gaming keyboard on sale on eBay with black Cherry MX switches that bears the Strong Man label, though I don't see anything about it on the Strong Man web site:
http://cgi.ebay.com/PRO-Gaming-Keyboard-Cherry-MX-swith-7-Keys-hit-one-time_W0QQitemZ250185969828
« Reply #34 on: Sun, 11 November 2007, 12:33:13 »
...I think that lack of a perfect office chair is all that stands between me and greatness.
I've had a perfect office chair for the past 7 months, so now there's nothing standing between me and greatness except for, well, me. But at least I'm sitting here in supreme comfort as I wallow in my mediocrity.
Offline xsphat
  • Enlightened
« Reply #35 on: Sun, 11 November 2007, 12:35:34 »
Strong man enterprises is a different company. Go to thier site, they don't have a pic of the SMK 85 or the 88, and on the bottom of my 85, it say's Strong Man Electronics Co. LTD.
Those boards on the the site don't look to appealing.
« Reply #36 on: Sun, 11 November 2007, 12:56:32 »
Excuse me, but go to:
http://www.strong-man.com.tw/index_p03.htm
and compare the SMK-85 E listed there with this:
http://www.notestation.com/smk85u.htm
and now tell me that it ain't the same company.
« Reply #37 on: Sun, 11 November 2007, 13:21:38 »
Oh, and I forgot to add that Strong Man Enterprise Co., Ltd. apparently made the Matias Tactile Pro:
http://alexking.org/blog/2007/01/09/apple-keyboard-revisited#comment-53908
Don't know if they make the Tactile Pro 2.0, though.
Offline xsphat
  • Enlightened
« Reply #38 on: Sun, 11 November 2007, 17:54:33 »
What you have to realize is that the SMK 85 and 88 are actually manufactured by DS International. Just because a certain company has their name on a product doesn't mean they make it. Think of the old Dell and Gateway keyboards with buckiling springs - they were manufactured by IBM or Leximark.
« Reply #39 on: Sun, 11 November 2007, 18:05:32 »
Offline xsphat
  • Enlightened
« Reply #40 on: Sun, 11 November 2007, 18:13:30 »
Call Karl at DS Inernational, his number is on their web site.
« Reply #41 on: Sun, 11 November 2007, 18:42:50 »
I give up. And no, I'm not going to call Karl.
Offline xsphat
  • Enlightened
« Reply #42 on: Sun, 11 November 2007, 18:48:15 »
Cool. I have talked to Karl on the phone, so I know what he told me.
BTW, http://www.dsi-usa.com/input.html
As the site states, they design and manufacture OEM products.
Offline xsphat
  • Enlightened
« Reply #43 on: Sun, 11 November 2007, 19:13:16 »
Since I'm an office set-up dork, what kind of chair do you have? I have only had hand me down chairs, my current one isn't very comfortable and weighs more than my SUV. And I really like your word usage here, very nice.
« Reply #44 on: Sun, 11 November 2007, 19:36:03 »
I believe that the MX Linear spec is 50 or 60 million key presses. The click one is supposedly only 20 million. Not sure where I saw this. Most mechanical keyboards with Cherry switches advertise 50 million presses. I think that's a strong indication that the switch they use is linear. BTW, how did you find the G7 page?  It seems impossible to navigate to from their  home page.
« Reply #45 on: Sun, 11 November 2007, 19:38:16 »
Quote from: xsphat
This site is quite good for finding OEM information:
http://www.alibaba.com/
(First 4-page thread? Yay!)
Offline xsphat
  • Enlightened
« Reply #46 on: Sun, 11 November 2007, 19:58:01 »
That site looks a bit tricky to use at first glance, but I'll give it a try.
Let me ask you something - Do you know the difference between the Alps switches used in the Northgate Omnikey (white), my 1986 Apple Desktop Bus (pinkish) and the SMK 85 (Black)? They are all listed as tactile, but the Apple feels a lot different than the SMK, though it may be it's age, but they both feel great. I am wondering what the Omnikey / Avant Prime would be like compared to the SMK 85, and whether it could be better.
« Reply #47 on: Sun, 11 November 2007, 21:41:28 »
Quote from: xsphat
No idea to be honest. I suspect that alps colors are all over the place. They are probably consistent in a given time period, but not between different time periods. BTW, are they even manufactured anymore? I can' find anything on the Alps site. Seeing how practically all new mechanical boards are now using Cherry switches, I wonder if that's the case.
Offline xsphat
  • Enlightened
« Reply #48 on: Sun, 11 November 2007, 21:49:42 »
Alps still makes the switches, and I understand some keyboards still use them. I would really be sad if they stopped making Alps swtiches for keyboards.
And I have noticed that everything mechanical that's new has the black Cherry MX switches. This is a disturbance in The Force.
« Reply #49 on: Mon, 12 November 2007, 14:42:34 »
Quote from: xsphat
I just took delivery of an SMK 85 today at work. It's the silver one with black keys (I gave up looking for the all black version). Not sure if it has Alps or Strongman switches. I'll pop a key tonight when I get home and find out. But if it has black Alps sliders, I'll be able to do a direct comparison with the Avant Stellar and its white Alps sliders.
