Author Topic: Strip legends off of pad-printed keycaps?  (Read 6713 times)
Offline codymaust
« on: Tue, 08 January 2013, 06:12:59 »
Is this a possibility? Looking for blank caps on a budget, and the idea popped into my head.
Would some turpentine work to strip off pad-printed legends? If so, would it harm ABS?
After some research, it seems that the following are possible options:
1) Vegetable Oil
2) Turpentine
3) Linseen Oil
4) Model plastic paint-removal products -- Chameleon, Scalemaster
5) PineSol
Looking for feedback before I ruin a perfectly good set of caps  :eek:
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Strip legends off of pad-printed keycaps?
« Reply #1 on: Tue, 08 January 2013, 11:14:51 »
Depending on the pad print (won't work with plastic based ink/paint), dot5 brake fluid works. It will just lift the paint off and does not harm plastic. Defineatly don't use anything with acetone it will melt abs literally.
Offline codymaust
« Reply #2 on: Tue, 08 January 2013, 11:40:21 »
I'll keep that in mind as well.
I think I am just going to experiment with a few of the extra WASD that came with it, depending on if the pad ink looks/feels the same
Will report back eventually, in case anybody is interested
Offline file_id
« Reply #3 on: Tue, 08 January 2013, 18:28:59 »
Don't use brake fluid. It's carcinogenic.
DS3 White YOTS (Blue)|Poker 2 (Blue,Clear)|QFR Rapid-i TKL (Brown,Blue)|QFR Rapid TKL (Blue,Red,Brown)|KBP V60 (Blue,Clear,Matias Click)|Code TKL Clear|Filco MJ2 TKL (Blue)|Filco MJ2 Ninja Beige TKL (Brown)|Novatouch
Offline codymaust
« Reply #4 on: Tue, 08 January 2013, 20:17:54 »
Thanks for the heads up!
Offline laffindude
« Reply #5 on: Wed, 09 January 2013, 14:23:17 »
Caps from? They're more likely to be laser printed than pad printed. Even if pad printed, you may not be able to remove it since there may be a UV coating.
Offline codymaust
« Reply #6 on: Wed, 09 January 2013, 19:28:42 »
Good call :|
They're from a QFR, and indeed laser printed.
Offline SmallFry
Re: Re: Strip legends off of pad-printed keycaps?
« Reply #7 on: Wed, 09 January 2013, 19:36:35 »
Good call :|
A QFR is pad printed...?
Offline codymaust
« Reply #8 on: Wed, 09 January 2013, 19:56:04 »
Good call :|
Nope, I was just mistaken
They're laser-marked
Offline SmallFry
« Reply #9 on: Wed, 09 January 2013, 20:06:11 »
I swore they were pad printed. Meh, not worried.
Offline codymaust
« Reply #10 on: Wed, 09 January 2013, 21:05:25 »
I was under that impression haha! If I had to take a guess at what pad-printed legends felt like, this would be it
Coolermaster website says "laser-marked" though
Offline esoomenona
  • Gnillort?
« Reply #11 on: Wed, 09 January 2013, 21:09:49 »
I think there is a difference between laser printed and laser etched.
Offline JackA$$
« Reply #12 on: Tue, 06 August 2013, 13:36:41 »
Hey there,
i think the K65 from Corsair is using pad printed key caps.
Some experience to make them blank?
Offline Beelzebro
« Reply #13 on: Wed, 29 January 2014, 11:15:39 »
bump. is this possible to do with kbt pure pro or poker 2 keycaps? fancy making myself some blank ones :)
« Reply #14 on: Wed, 29 January 2014, 16:03:16 »
Find someone who is an old-fashioned draftsman or artist and borrow his electric eraser. Use pink or green eraser, but be careful how you do it.
- D Trump 2026-10-24
