Author Topic: Hi from Italy!  (Read 2929 times)
Offline djmattm
Hi from Italy!
« on: Tue, 08 January 2013, 10:57:44 »
Hi guys, just discovered this great forum!
For now i just have a simple basic keyboard, but in the next future i'll surely buy a mechanical one!
Razer BlackWidow Tournament Stealth Edition
Offline JPG
  • Model F is my new passion!
Re: Hi from Italy!
« Reply #1 on: Tue, 08 January 2013, 10:59:11 »
Hi there,
You can remove the surely from you post. You WILL have a mechanical keyboard  :p
Offline FabsSpeed
Re: Hi from Italy!
« Reply #2 on: Tue, 08 January 2013, 12:43:13 »
Hello ... enjoy the forum !
| Wanted: KMAC  & KMAC 1.2, 356 Mini, 456 GT |
Re: Hi from Italy!
« Reply #3 on: Tue, 08 January 2013, 21:36:14 »
Welcome to Geekhack!
Any ideas yet which keyboard you might like?
Offline keyboardlover
Re: Hi from Italy!
« Reply #4 on: Tue, 08 January 2013, 21:38:49 »
Benvenuto a Geekhack!
Offline djmattm
Re: Hi from Italy!
« Reply #5 on: Wed, 09 January 2013, 06:31:27 »
I'm not sure yet, i don't write much but i videogame so i'm looking at keyboards with black/red switches, but the budget is really really tight as i'm a college student so the cheaper the better, any suggestions?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Hi from Italy!
« Reply #6 on: Wed, 09 January 2013, 08:10:35 »
go for a CM quickfire, they are reasonably priced for a mech keyboard and you can find it in ITA layout too.
Ciao e benvenuto!
Re: Hi from Italy!
« Reply #7 on: Wed, 09 January 2013, 19:36:38 »
If you do mostly play games, then linear (blacks/reds) would be a better choice to start with.
As Matt3o suggested, a CoolerMaster Quickfire Rapid would be a good place to start - relatively cheap, but surprisingly high quality (I have one with blacks).
Offline djmattm
Re: Hi from Italy!
« Reply #8 on: Fri, 11 January 2013, 12:53:58 »
I just bought the Razer BlackWidow Tournament Stealth Edition, it's on sale on the Razer site for just 52 euros!
Re: Hi from Italy!
« Reply #9 on: Sat, 12 January 2013, 00:22:55 »
That should get you started :)
Let us know what you think of it after a couple of weeks.
