Author Topic: Having a bit of trouble putting the enter key back on QFR  (Read 3267 times)
Offline Preach
  • The Insane
« on: Sat, 12 January 2013, 00:49:17 »
I decided to see how to take off the enter key in order to be ready for a set of keys that are coming in and now I can't seem to put it back on.
Any help would be greatly appreciated.
QFR - Browns |
Re: Having a bit of trouble putting the enter key back on QFR
« Reply #1 on: Sat, 12 January 2013, 01:10:08 »
This is for Filco, but both use the same stabilisers:
Offline Preach
  • The Insane
« Reply #2 on: Sat, 12 January 2013, 01:14:15 »
thank you. been searching for a while with no results.
QFR - Browns |
Offline hoggy
  • * Ergonomics Moderator
« Reply #3 on: Sat, 12 January 2013, 01:15:54 »
Beaten to it.  Nevermind.
Offline Preach
  • The Insane
« Reply #4 on: Sat, 12 January 2013, 01:21:58 »
i got the key on but now it doesnt push back up unless i pull a little bit.
QFR - Browns |
Offline hoggy
« Reply #5 on: Sat, 12 January 2013, 01:26:56 »
Take it off and try again - should clear it.
Offline Preach
  • The Insane
« Reply #6 on: Sat, 12 January 2013, 01:31:42 »
found the error. i had put a white piece in backwards.
thank you everyone for helping
QFR - Browns |
« Reply #7 on: Sat, 12 January 2013, 05:44:02 »
No worries :)
Once you have done a couple of these, it becomes second nature.
Offline cobraj
« Reply #8 on: Sat, 12 January 2013, 15:56:38 »
Indeed it does.
However after only using Filco's, I managed to pull out the stabilisers of my KBT Race as it feels a lot less solid than a Filco :(
