Author Topic: PBT Nordic &  (Read 4329 times)
Offline Jaffa
PBT Nordic &
« on: Sat, 12 January 2013, 06:52:09 »
Hey. Right know i'm using CM storm Quick Fire Rapid Red.
I like it a lot and this is my first mechanical keyboard.
I got the Nordic one (Denmark).
I have 2 questions!
1: I want full PBT keycaps for it, where?
2:  What I have noticed with this keyboard is, If I push very slow and soft on one of the keycaps it's
feel's like it scratch or hitting something. It only happen when I push from the corner/side's of the cap's. Is it
something that is normal with mechanical keyboard/red switches? It annoys me a lot. It also happens when I play.
But not all the buttons do. Don't get me wrong I really like this keyboard.
Best Regards.
Cm Storm Quickfire Rapid Red Switch
Offline volatilecoffee
  • Formerly ybnrmalatall
  • I don't feel any certain way.
Re: PBT Nordic &
« Reply #1 on: Sat, 12 January 2013, 07:36:56 »
That noise is fairly common with reds due to the type of switch
I use blues as I like them much more (Quickfire TK) with a mess load of custom keycaps :P
but you will either get used to it or get a different switched board
Idk about where to get PBT type caps but I usually just get whatever is colorful xD Unless they are TOO plastic and cheap feeling I am solid
Linear gang needs to rise up against the tactile hipsters.
Offline phetto
  • HHKB JP
PBT Nordic &
« Reply #2 on: Sat, 12 January 2013, 07:39:11 »
You can order engraved PBT sets with Danish layout from Sweden at www.maxfps.se
Offline Jaffa
Re: PBT Nordic &
« Reply #3 on: Sat, 12 January 2013, 12:24:08 »
Well O-Ring help? I just buy the blue ones last day.
Offline Jaffa
Re: PBT Nordic &
« Reply #4 on: Sat, 12 January 2013, 12:25:29 »
But I don't think for only TKL board's! You have to buy for the full version board!
Maybe i'm wrong?
Offline Jaffa
Re: PBT Nordic &
« Reply #5 on: Sat, 12 January 2013, 12:49:52 »
Do all MX Red switch sound/feel like that? I'm talking about Leo, Filco, Ducky....
Offline Johan
Re: PBT Nordic &
« Reply #6 on: Sat, 12 January 2013, 16:36:11 »
Maybe i'm wrong?
Wrong! Its for a non TKL board but the keys are the same, You just don't use the tenkey keys.
Uh, stuff.
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
Re: PBT Nordic &
« Reply #7 on: Sat, 12 January 2013, 16:38:28 »
if it helps, i'd just like to add that having PBT for the primary 34 letters/punctuation is the most important, after having used some cherry PBT on those keys for a while
you don't really use the other keys anywhere near as much, or at least the texture isn't nearly as important on those
Re: PBT Nordic &
« Reply #8 on: Sat, 12 January 2013, 18:07:52 »
