Author Topic: Black Vinyl-dyed Model M  (Read 10813 times)
Offline Mikecase00
    • http://www.mikecase.net
« on: Mon, 15 October 2007, 15:56:07 »
I've completed dying my Model-M black and thought I'd share it with the rest of the geek-hack keyboard nuts.  It went pretty well, although I had to hunt around a while to find some Plastikote vinyl dye rather than the ubiquitous Duplicolor vinyl paint.  The results look good so far, but I want to wear test it for a while to see how the dye holds up.
Here's a shot of the finished product
Here's the whole story http://mikecase.net/ModelM/Black-USB-ModelM-Keyboard-Mod-3.html
IBM Model M 1391401 (dyed black) w/ keys from M-13
IBM M-13 Trackpoint (naturally black)
IBM Model M 1392934 SpaceSaver
Several plain IBM 1391401 Ms
Epson Equity Q203A
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Mon, 15 October 2007, 16:08:27 »
Looks very nice Mike.  Are you planning on doing the keycaps at all?  I'd really like to know how they hold up with the Plastikote product.
Thanks for the update.
Offline Mikecase00
« Reply #2 on: Mon, 15 October 2007, 18:05:30 »
Quote from: iMav
I was thinking about painting the original set of key caps black so I could swap in a das-keyboard style look when the mood struck me.  I'll probably get to that in the next few weeks when I get around to dying the ps/2 cable.  Truth be told, I've got several M's and this first one was kind of a tester.
Epson Equity Q203A
Offline Bluemercury
« Reply #3 on: Fri, 30 November 2007, 08:48:28 »
Dam that looks nice, i was considering painting my model m5-2 too.....what kind of paint are you using? did you use air brushing?
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
Offline Mikecase00
« Reply #4 on: Fri, 30 November 2007, 16:24:14 »
Thanks
I used Plasti-kote Vinyl Color spray paint  (as can be seen in the article on my website ;-)
I did a lot of reading about what was best to use, and it looks like the Plasti-Kote stuff gets good reviews while the much more widely available Dupli-Color vinyl paint apparently doesn't hold up as well.  So far my board is holding up great to hours of daily abuse.  The only complaint I have is I wish it were slightly less glossy.
As for putting it on, I just sprayed it from the can.  It's important not to put on thick coats.  I think I put on about 5 thin coats which helps prevent runs and bubbles.  Pretty easy to do really.  Make sure your board is clean first though, a good scrub down with some rubbing alcohol will help the dye adhere better.
Epson Equity Q203A
Offline victheslik
« Reply #5 on: Fri, 30 November 2007, 21:50:21 »
« Last Edit: Sun, 26 November 2023, 22:04:27 by victheslik »
"The only antidote to mental suffering is physical pain. " Karl Marx
A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
Offline fkeidjn
« Reply #6 on: Sat, 01 December 2007, 00:06:55 »
Or you lacquer the keytops instead.  You know what I mean?
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #7 on: Sat, 01 December 2007, 01:21:28 »
Urushi!
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #8 on: Sat, 01 December 2007, 01:38:14 »
Quote from: ashort
Urushi!
ショー
