Author Topic: CG visualization of key cap color combinations  (Read 93781 times)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: CG visualization of key cap color combinations
« Reply #100 on: Fri, 01 March 2013, 09:29:04 »
Was the Toxic green posted? I thought it was going to be a heretofore unseen, startlingly bright green.
He just got samples in a day or so ago. I PM'd Daniel to see if we could get a sample (when it's finalized) so you can use your PMS system to find a match. I'll let you know what he says.
Offline Batmann
« Reply #101 on: Fri, 01 March 2013, 09:34:37 »
Toxic green is PMS 389,
since it's a custom colour we had to use pantone for the choice
and also thanks for the colour ring order, that's gonna help a lot  :)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #102 on: Fri, 01 March 2013, 09:52:57 »
I'm happy to contribute to the cause and order a ABS color ring and ship it to @Krogenar. He can then match the colors and add it to our knowledge of KEYBOARD SCIENCE!  :p
Quick question though, are the SP color rings consistent? It feels like they are a bit all over the map and change over time.
@krogenar, please PM me your address and I'll ship you the ABS ring.
No, they are not consistent.  They contain the chips that SP has in stock at the time they make the rings.  In fact, the rings I bought for Elvish and Retro did not contain any of the colors that ended up in Retro.
SP did send me the extra color samples when I requested them by color-code, but there is no guarantee you will get all the colors you want.
 - Ron | samwisekoi
Offline mashby
    • Mashby
« Reply #103 on: Fri, 01 March 2013, 10:08:30 »
So are you saying colors like RA Red may not be the same color when another batch is run, or that they are always adding and changing colors?
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #104 on: Fri, 01 March 2013, 10:47:30 »
Coated or uncoated? African or European?
Quote from: Samuel Adams
Offline Batmann
« Reply #105 on: Fri, 01 March 2013, 11:10:13 »
I used solid coated for the mockups,
Daniel arranged this with Melissa so I'm not sure what they agreed on except for 389.
Btw is coating relevant for ABS plastic?
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #106 on: Fri, 01 March 2013, 11:41:08 »
I would assume coated, this being plastic and all, but I can't be sure until I see the chips themselves. I use primarily Pantone Solid Coated, and I print mostly on extruded vinyls. Even after matching the chips to Pantone Solid Coated colors, it sounds like they would still only be approximations, since others have pointed out that the color chips differ from batch to batch. Still, it's better than just guessing.
If my color match call seems close, I'll post some photos!
Offline eth0s
  • Peace & Love
« Reply #107 on: Fri, 01 March 2013, 11:43:53 »
First, is there any way to change the color of the legends, to get an idea how double-shots would look?
Second, can you do one more?
I call it "Breakfast on Fifth Avenue", inspired by the famous jewelry store in Manhattan located at the corner of E. 57th Street and Fifth Avenue.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #108 on: Fri, 01 March 2013, 12:25:07 »
i'm at some point going to make color accurate argb shots of all of the color chips i have, but due to some nasty stuff don't have the time right now
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #109 on: Fri, 01 March 2013, 12:34:51 »
I can confirm that PMS 389C for the Toxic set is ... wow. A really intense, eye-strain inducing green! Pretty awesome that the GB organizer was able to get SP to do this. That will be one really unique-looking set. Here's the potato pic:
I shot the picture against my Model M as a color reference. PMS 389 is right at the point where it could almost pitch over into a more yellow color, but doesn't. Ballsy color to choose.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #110 on: Fri, 01 March 2013, 12:37:09 »
Always adding and changing colors to the rings.
Offline Batmann
« Reply #111 on: Fri, 01 March 2013, 14:17:14 »
Sounds good and also looks good
Offline mashby
    • Mashby
« Reply #112 on: Fri, 01 March 2013, 16:30:25 »
As long as the color names are consistent, in other words RA red is always the same, then I think having the PMS as a reference can really help. Of course it also means that this process could be never ending if they add and remove colors willy nilly.
Offline kaporkle
« Reply #113 on: Fri, 01 March 2013, 20:01:34 »
I used PMS 389 for the green and guessed on the black/charcoal (and I goofed on the front-printing in the upper right, but hopefully that's not a big deal).
Eth0s, I looked up Tiffany & Co. It's a cool idea for a color scheme. Before I hit 'go' on the HQ render, is this the level of saturation that you're after?
Offline Turkishrambo
« Reply #114 on: Fri, 01 March 2013, 20:34:16 »
ohhh man! i  want them even more now! Should post it in the GB thread!
Offline eth0s
  • Peace & Love
« Reply #115 on: Sat, 02 March 2013, 15:55:02 »
I got a WASD gamer set from Signature Plastics that was a near perfect match for Tiffany turquoise.
Here are some pics:
As you can see, Tiffany uses turquoise with black legends.  The Tiffany font is distinctive, and would be impossible to reproduce without paying $45 per keycap for Signature Plastics new legend fee.
Also Tiffany uses white as a modifier color, as you can see in the pics.
As such, the colors of a "Breakfast on Fifth Avenue" set should include turquoise, black and possibly white.
I haven't worked out what would be the best combination of colors just yet, which is why i was excited to try your modeling to see how the various color combo's look.
Now I'm thinking the alpha keys should be black-on-turquoise, and the modifier keys should be turquoise-on-black.  Maybe the only place for turquoise-on-white would be the Esc key.
Here is a pic of a keyboard with a turquoise gamer WASD cluster:
« Last Edit: Sat, 02 March 2013, 16:49:39 by eth0s »
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #116 on: Sat, 02 March 2013, 15:58:10 »
There is something masochistic about doing this for a board that has so few custom keycap options.
Are you referring to doing this for a Model M? That's exactly why it should be done... So that more key caps could be made.
The only problem with that really is, like topre, Unicomp is the only one that makes BS cap sets and they're rather slow when it comes to making new combinations.  I think they've been developing a Red Alert set for over a year now.
Offline mashby
    • Mashby
« Reply #117 on: Sat, 02 March 2013, 16:33:53 »
Those keys look fantastic.
Do you know what color code they used for that?
Offline eth0s
  • Peace & Love
« Reply #118 on: Sat, 02 March 2013, 16:48:53 »
I don't have one of those Sig Plastics color-coding ring of fobs.  http://www.keycapsdirect.com/marketplace.php
I guess I should pony up $35 and buy one from Melissa. heh.
Offline mashby
    • Mashby
« Reply #119 on: Sat, 02 March 2013, 17:35:19 »
I just bought one myself. I was just curious if you knew off hand.
Offline Jocelyn
  • 조셀린
Re: Re: CG visualization of key cap color combinations
« Reply #120 on: Sat, 02 March 2013, 17:53:43 »
Here are some pics:
Those caps are beautiful! Btw, the color has been around for almost 200 years and is Tiffany Blue not turquoise :)
Offline eth0s
  • Peace & Love
« Reply #121 on: Sat, 02 March 2013, 20:01:01 »
Here are some pics:
They are pretty awesome, it's true.  I've been thinking about running a group buy to make a whole set out of them, for more than a year.
And, lol, yeah, I know Tiffany & Co., calls it "Tiffany Blue", because I've spent more than a few dollars in their store. :))  But I didn't want any entanglements with them, so I would like to call it "Breakfast Turquoise" or "Fifth Avenue Blue", or something, lulz.  Hmm, for short I guess I could call it BreakTurq, or FAB?
So would you be interested in a whole set of BreakTurq/ FAB keycaps?  If so, what color should the modifier keys be?  BreakTurq/ FAB for the alpha keys, and Black around the outside or white?
I just realized I prolly should start my own thread about this.  Sorry if I thread-jacked a bit.  :-[
« Last Edit: Sat, 02 March 2013, 20:03:54 by eth0s »
Offline kaporkle
« Reply #122 on: Sun, 03 March 2013, 02:39:10 »
I found the RGB values for Tiffany Blue on this page:
http://blog.buyosphere.com/2012/05/tiffany-blue/
According to Matt3o's color tool, the closest match is BEY.
Like this:
Or this:
Offline pasph
« Reply #123 on: Sun, 03 March 2013, 06:23:27 »
Very different colors
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #124 on: Sun, 03 March 2013, 08:07:12 »
I've updated the tool with better calibrated colors. The closest you can get is probably BFL
http://lab.cubiq.org/wta/?img=http%3A%2F%2Fimg.photobucket.com%2Falbums%2Fv123%2FDaJuice%2FTiffanyBlue.png
preview
http://lab.cubiq.org/kbcc/#BFL,NN
edit: if you can go PBT, maybe BFV is even closer
« Last Edit: Sun, 03 March 2013, 08:24:58 by Matt3o »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #125 on: Sun, 03 March 2013, 10:56:17 »
A couple of things...
First, having bought many things Tiffany over the years, and even owned some Tiffany stock, I have to say that the inclusion of black keys violates their design ethic pretty strongly.  Go buy something.  It will come in a blue box with a white ribbon.  Your GF/Wife will be excited just to see the box.
So having the keycaps in Tiffany Blue with white or black lettering, and possibly a small touch of white with blue would much better suit the Tiffany look.  http://lab.cubiq.org/kbcc/#BFL,WA
Second, we've picked the colors for the Elvish keycaps.  Mr. Kaporkle, feel like doing something with non-Roman lettering?  We have an SVG of the Elvish legends.
See http://geekhack.org/index.php?topic=38264.0 for more details (and a bad 3D image.)
Thanks in advance!
 - Ron | samwisekoi
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #126 on: Sun, 03 March 2013, 11:14:04 »
if you release the source code I could create a realtime 3d keyboard generator :P
Offline kaporkle
« Reply #127 on: Sun, 03 March 2013, 14:36:13 »
I had not seen that before, badass. :cool:
Since this is a commercial venture I have to politely decline. :]
There isn't any code btw, rather it's all scene files.
Samwisekoi, I will shoot you a PM.
Offline mkawa
« Reply #128 on: Sun, 03 March 2013, 14:40:13 »
conveniently, one of our admins has a lot of experience in automated generation and manipulation of scene files *whistle* ;)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #129 on: Sun, 03 March 2013, 16:15:29 »
oh well... I gotta create it myself then...  >:D
Offline eth0s
  • Peace & Love
« Reply #130 on: Tue, 05 March 2013, 00:56:33 »
On Matt3o's keyboard color chooser, VBV is closer to Tiffany Blue.  Tiffany Blue is not really blue at all, it's really turquoise.  Tiffany & Co. just call it "blue" for some reason.  Either way, SP has a direct match, as I showed in my pic.  The SP WASD set in my pic is almost a perfect match for "Tiffany Blue".
Offline Jocelyn
  • 조셀린
« Reply #131 on: Tue, 05 March 2013, 01:36:53 »
Haha, they probably call it blue because many women who buy turquoise think it's expensive, nice, and luxurious, but it's not lol. When I lived in Pittsburgh, a lot of my girlfriends were like this and Tiffany & Co. probably wants to disassociate from that.
PS - I plan on messaging you in regards to your last reply to me, but I haven't had enough time yet :)
« Last Edit: Tue, 05 March 2013, 04:54:43 by Jocelyn »
Offline eth0s
  • Peace & Love
« Reply #132 on: Wed, 06 March 2013, 13:30:45 »
Hmm, well, I like turquoise, the semi-precious stone, and turquoise, the color.  IMO, any stone can look nice in a piece of jewelry, even amber.  It all depends on the skill of the jeweler.  And any stone can be expensive, when Tiffany & Co. sells it (even amber).  lulz.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #133 on: Wed, 06 March 2013, 14:00:35 »
Heads up gang, received the SP ABS color ring from Mashby today, and I'll be doing some Pantone color matching tonight when I get home. I will post some matches tonight. I'll try to find a Tiffany Blue.
Also, I was wondering ... has anyone ever considering mounting a semi-precious stone into a keycap? I'm just imagining sculpting the cap so that it has a 'setting' shape; put a little cleft somewhere on it, and then bedazzle the bejeezus out of it.
You know what, forget that, that would look ridiculous. I'm just going to splash some glue and glitter on my keycaps, maybe toss some uncooked macaroni on it and call it a day.  ^-^
LOL, other arts and crafts accessories could work -- googly eyes!
Offline eth0s
  • Peace & Love
« Reply #134 on: Thu, 07 March 2013, 00:17:42 »
LOL, I dunno if ur trolling me or not.  But that pic is still funny.
And somebody like girlDC, who is actually a jeweler, will eventually make a solid gold Darth Vader with diamond eyes.  Just wait, the $1,000 keycap is coming.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #135 on: Thu, 07 March 2013, 04:23:31 »
Nope, not trolling at all. I like the Tiffany color scheme actually. I think there should be more solid color keycap sets, if the color is striking enough.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #136 on: Fri, 08 March 2013, 11:41:16 »
Can you add color "VDA" to the tool? It is Pantone color 389 C which will be used for the Toxic set.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #137 on: Fri, 08 March 2013, 12:14:18 »
Sure. Way to go, engineering a new color and all!
So far I've got all the yellows (with one or two exceptions) matched. I'll start posting the numbers once I have more of them done.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #138 on: Fri, 08 March 2013, 13:03:55 »
please note that abs colors change from one batch to another, an ABS to Pantone convertion is almost impossible
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #139 on: Fri, 08 March 2013, 13:32:24 »
Do they change drastically? If they do, then, well then their own color rings are kinda useless too, aren't they? Unless they make new rings on a regular basis, which I would imagine would be pretty costly? I use a lot of fabrics in my work, of all different colors, and they also vary slightly from dye lot to dye lot -- but not by a huge margin. Red doesn't turn into orange or anything.
I'm assuming that the codes SP uses must indicate some sort of formula? I'm guessing the raw ABS comes in pellets of some kind, and they drop colorants by some formula into the molten plastic. Could be that the formula isn't very stringent -- a pinch of this color, a dash of that color, etc. -- but I doubt it. One RA set won't match another RA set precisely, but they'll be very close, right?
For now, I've only managed the yellows, and if I'm not 90%+ confident in the match, I indicate that in my notes. So far only one color chip has had no real Pantone match. Once I'm done I might go into some other Pantone books (uncoated) and see if there's a better match, or explore percentages of a Pantone color. I'm hoping the other colors will be easier to match.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #140 on: Fri, 08 March 2013, 13:36:08 »
Yeah, I gotta agree. But if SP was able to make a custom color for the Toxic set, maybe they can match your Tiffany blue?
Offline eth0s
  • Peace & Love
« Reply #141 on: Fri, 08 March 2013, 13:39:13 »
@ Krogenar: Are you a garmento?  lol, early in my career, I used to do arbitrations for fabric manufacturers and buyers here in NYC.
@Matt3o:  It seems like Signature Plastics can produce the same color over and over again in their ABS plastic on a reliable basis.  So I'm hoping they can reproduce the turquoise color that they produced before.  And I think it's just a coincidence that their turquoise color is almost an exact match for Tiffany Blue.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #142 on: Fri, 08 March 2013, 13:53:34 »
No, but I do work very close to the fashion district. I make custom banners and flags, so I use a lot of nylon. Arbitrations between fabric buyers and sellers? Hope they paid you a lot, LOL! ("This isn't Navy Blue, it's Black!") You have no idea how many times that color trips people up.
Quote from: eth0s
It didn't look like an exact match to me; in fact, it was pretty far off. But color is such a subjective thing that it might be good enough for the end user. The only way to get a 100% match would be to match a chip up against a Tiffany bag. And even then, the final color might be slightly different because SP would mix the color up fresh for production. When I used to silkscreen in-house we would run into the same problem. I'd mix a color up by hand (literally mixing it by adding ink, checking against a color, remixing, etc.) and after printing I'd put the ink in one of those chinese take-out containers, label it, and then if the client came back I would at least have a reference to try to match.
But I don't think that would work with molten plastic!  :D
« Last Edit: Fri, 08 March 2013, 13:55:55 by Krogenar »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #143 on: Fri, 08 March 2013, 16:20:43 »
I'm telling you what SP told me. While building my color tools I tried to tune up with SP but it turned out to be very difficult to match the colors. Also the color rings varies over time. So you can try to go close, but a perfect match won't last long. The good news anyway is that SP can match your color if you ask to.
Offline eth0s
  • Peace & Love
« Reply #144 on: Fri, 08 March 2013, 16:38:11 »
Quote from: eth0s
Well, I worked for somebody else.  It was my first real job, and I didn't get paid very well, but I learned a lot about litigation, and how people in the garment industry try to cheat each other.  It's a pretty crazy business, is all I'm willing to say.  However, there are a lot of really great people in that industry too.  There are even a few honest ones.  :p
As or SP's turquoise keycaps, it's true they are not an exact match for Tiffany Blue.  But I didn't think about trying to get an exact match, mainly b/c it seemed impracticable, and secondarily since it seemed that a slightly different, but very similar shade of turquoise would avoid copyright litigation.  I'm sure you're aware of Christian Louboutin's copyright litigation over his red soles on his women's shoes.  Louboutin has re-filed his French trademark to name a specific shade of red (Pantone 18-1663TP, “Chinese Red”) rather than the color red in general — so his claim to copyright protection seems to be limited to that exact shade of red, i.e., Pantone 18-1663TP.  The same is probably true for Tiffany Blue, but again, it's always an open legal question when dealing with this sort of thing.  Louboutin lost at the trial court level, but has won at the appellate court level.  So, while it may be an interesting hypothetical, to see if one can duplicate Tiffany Blue in plastic, it may cause more problems than it's worth, if one actually tried to sell it.  However, despite the foregoing, I would love to know the exact Panatone color name and number for Tiffany Blue, if you can figure it out.
Offline kaporkle
« Reply #145 on: Fri, 08 March 2013, 22:26:55 »
I hope you don't mind eth0s, I took a little bit of liberty with the scheme taking into account what samwisekoi mentioned.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #146 on: Fri, 08 March 2013, 23:07:57 »
Years ago, I had a 486DX4 laptop with an in-case trackball; I also had a hematite sphere the same size.  I'll let you join the dots.
Overton130, Box Pale Blues.
Offline eth0s
  • Peace & Love
« Reply #147 on: Sun, 10 March 2013, 19:03:03 »
Hey thanks!
That looks really great!  I guess white-on-turquoise is probably the best looking combination.  Although, I wouldn't mind seeing black-on-turquoise as well, on a black keyboard.  But only if you feel like doing another rendering, lol.
Offline kaporkle
« Reply #148 on: Tue, 12 March 2013, 00:39:49 »
I don't know about you but I like it. :}
Offline Badwrench
  • ummmm.....I forgot
« Reply #149 on: Tue, 12 March 2013, 19:40:26 »
One more for me?
