Author Topic: Replacement screws for Poker  (Read 1616 times)
« on: Wed, 16 January 2013, 16:26:12 »
Does anyone know the correct size of the screws that mount the Poker/Pure PCB to the case? If you could provide a link to where I can get some, that would also be very helpful. Specifically, I'm looking for the ones that have a "washer head."
Offline SmallFry
Re: Replacement screws for Poker
« Reply #1 on: Wed, 16 January 2013, 17:31:04 »
Any small engine shop will have thread gauges so you could have them check one you have. Then its just looking for the right ones at the hardware store or McMaster or similar:)
Offline oneproduct
  • @Ubisoft
« Reply #2 on: Wed, 16 January 2013, 19:06:44 »
#2-56 is the screw you're looking for. Here's an example of one:
http://www.amazon.com/gp/product/B000FN193Y/ref=oh_details_o04_s00_i00
This one doesn't have the washer. Also, this one is longer than the ones that come with the Poker as I needed longer screws to work with the case that I made. I don't know how long the normal ones are, but if you don't have one of your own to measure I could dig up my original ones and take a peek for you.
Layout: Colemak
Offline SmallFry
« Reply #3 on: Wed, 16 January 2013, 19:07:50 »
Well, that beats my option:)) Thanks oneproduct:)
Offline jcrouse
« Reply #4 on: Wed, 16 January 2013, 20:03:51 »
Yes 2-56 and you may find them at Lowes or home depot. I got mine at menards.
John
« Reply #5 on: Wed, 16 January 2013, 23:58:10 »
Thanks for the answers, guys. I'll see if I can find some locally before I go the online route.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #6 on: Thu, 17 January 2013, 00:01:07 »
i need some too enough for 2 poker case...
« Reply #7 on: Thu, 17 January 2013, 00:10:04 »
Mine seem to be 5/32" in length.
