Author Topic: Custom cases for QFR?  (Read 2833 times)
Offline Preach
  • The Insane
« on: Thu, 17 January 2013, 00:02:00 »
Just wondering if there are custom cases for the QFR like there are for the poker, etc ?
Would be nice to get a different case instead of the branding and rubbery texture (although I don't mind the rubbery texture)
QFR - Browns |
Re: Custom cases for QFR?
« Reply #1 on: Thu, 17 January 2013, 00:16:53 »
It is rumoured that brandless cases will be available direct from CoolerMaster at some stage.
Offline Preach
  • The Insane
« Reply #2 on: Thu, 17 January 2013, 00:23:42 »
Have people made their own cases before? If so how hard would it be?
QFR - Browns |
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #3 on: Thu, 17 January 2013, 00:27:21 »
i believe they are similar to filco cases, not 100% though.
Feng has made some acrylic ones for sale.(was below 50usd if i remember correctly)
He also has some aluminium ones which are about 300usd
Vortex(company) made some aluminium cases as well for 150usd or something, but there were loads of complains about it.
Offline vun
  • Just one more thing
« Reply #4 on: Thu, 17 January 2013, 00:30:34 »
A lot of the Filco cases will fit the QFR, although I don't think the Vortex alu cases fit. Not quite sure, though, so if you're seriously wanting one I suggest looking through the thread for them here on the forum.
Offline rknize
    • metaruss
« Reply #5 on: Thu, 17 January 2013, 00:32:27 »
Filco and QFR are almost exactly the same.  They have the same plate design and the same modular controller PCB between the nav keys.  The only difference is that the Filco has two internal screws to attach the plate to the bottom, while the QFR does not.  In short, any case that will fit a Filco will fit a QFR.
Russ
Offline rknize
    • metaruss
« Reply #6 on: Thu, 17 January 2013, 00:33:53 »
Here is my post on the topic.  I really need to put this in the Wiki:
http://geekhack.org/index.php?topic=37432.msg714145#msg714145
Russ
Offline Preach
  • The Insane
« Reply #7 on: Thu, 17 January 2013, 00:41:24 »
Thanks for the info guys. I appreciate it
QFR - Browns |
