Author Topic: So I bought a Model M spacesaver...what do I need for PS/2 to USB?  (Read 4291 times)
Offline blakespot
    • My (modest) keyboard gallery
I grabbed a pristine Model M spacesaver from 1987 on eBay tonight.
It's got a PS/2 connector. What is the best adapter for me to get this working via USB on my Mac? Are all adapters the same? Any recommendations?
Thanks.
bp
:: Leopold FC660C (x2), FC660M (browns), Realforce 87U, Das Keyboard (blues), Matias Tactile Pro (v1), HHKBL2, Matias Quiet Pro, Unicomp Classic 101, Focus FK-2001, Corsair Vengeance K65 (reds), Steelseries Apex 7 TKL ("browns")
:: Modest photo gallery of my keyboards
Offline rknize
    • metaruss
Re: So I bought a Model M spacesaver...what do I need for PS/2 to USB?
« Reply #1 on: Thu, 17 January 2013, 23:40:26 »
 Many of the adapters don't work.  Take a look at what clickykeyboards.com sells.  There is also a USB to SDL cable available.
Russ
Offline sleepy916
« Reply #2 on: Fri, 18 January 2013, 00:04:21 »
I saw that one on ebay too but couldn't do it. Too much for me, but really nice keyboard!
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #3 on: Fri, 18 January 2013, 02:08:47 »
I highly recommend this very specific Belkin. I've personally tested it with many M's, including M5 and M13. Works flawlessly every time. I've had one unit fail, which Belkin cheerfully replaced under warranty 4 years after I bought it.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
« Reply #4 on: Fri, 18 January 2013, 07:03:34 »
Get one of these
http://www.ebay.com/itm/280862986246?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
from orihalcon.
They are pricey, but many of us here at geekhack have used them and they work great.
Pete Hegseth:
"Trump changed the rules of engagement and untied the hands of war fighters .… We don't need burdensome rules of engagement that make it impossible for us to win these wars."
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #5 on: Fri, 18 January 2013, 07:12:35 »
nice and clean lookin' board. How much did you pay?
I use this one with my SSK: http://www.amazon.com/PS2-Keyboard-To-USB-Adapter/dp/B000BSJFJS
It's often called "bluecube"
Offline blakespot
« Reply #6 on: Fri, 18 January 2013, 09:35:38 »
Get one of these
from orihalcon.
Ordered. Thanks.
bp
Offline Hyde
  • White Tofu Extraordinaire
« Reply #7 on: Fri, 18 January 2013, 11:54:22 »
Get one of these
from orihalcon.
This look like a direct "physical" converter.  But I thought typically to convert USB to PS2 or PS2 to USB you need a keyboard with built in controller for it no?
But then it sounds like it works this way?  Or does PS2 to USB doesn't require the extra controller or something?
« Reply #8 on: Fri, 18 January 2013, 13:42:50 »
My understanding is that orihalcon builds the required circuitry into the cable.
I have 2 of these, and they have worked flawlessly for me under Windows XP and 7.
Pete Hegseth:
Offline rootwyrm
    • My Website!
« Reply #9 on: Fri, 18 January 2013, 14:01:02 »
Ahem.
Quote from: orihalcon
The PS2 to USB conversion circuit is contained within the USB plug's plastic molding and supports the FULL PS2 protocol as defined by IBM (the creators of that protocol).
Yes. It's in there. I might have to order one of these to check it out. Reason I prefer the Belkin is because it is much, much easier to swap around multiple keyboards and the only one that works with the M5-1. (None of the others work, they don't transmit the lock buttons properly.)
Offline Magnusian
« Reply #10 on: Fri, 18 January 2013, 16:13:49 »
Lucky, I wonder how I missed the listing for this one, the last one I saw on ebay went for $305 and was sniped out from under me. :(
Model M 1390120 1986  | Unicomp Customizer 104 1-Piece Keys | Franken M IBM 1390120 1987/Unicomp U4044A 2007 hybrid | CM QFR Cherry MX Greens
Offline BucklingSpring
« Reply #11 on: Sun, 20 January 2013, 12:54:50 »
Something I learned the hard way. I use a USB only KVM to share Keyboard/Video/Mouse with multiple computers. Double tapping the "Scroll Lock" is the master key to send commands to the KVM for port switching. Grrrr bad memories resurfacing.
Boards I own, click ->
Offline rootwyrm
    • My Website!
« Reply #12 on: Sun, 20 January 2013, 15:22:57 »
Hee. Other lock buttons, man. Remember that the M5-1 and M5-2 have a 4 button track ball. Left, Right, Left Lock and Right Lock. The 'Lock' buttons stay 'clicked' until you click them a second time, for clicking and dragging.
But trust me, double tap of Scroll Lock? Beats double tap Control to switch any day of the week. Yes, I had to deal with one of those. For a long time. Most miserable KVM ever.
Offline ch_123
« Reply #13 on: Tue, 22 January 2013, 14:49:58 »
I use my SSK with the Blue Cube and the Belkin PS/2-USB adapter on a regular basis - both are perfectly suitable.
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #14 on: Tue, 22 January 2013, 14:56:33 »
Another +1 for Orihalcon, his adapter has worked flawlessly across Win 7/ OSX/ Linux
http://www.ebay.com/itm/NEW-PS2-to-USB-or-RS232-Adapter-Converter-Keyboard-Barcode-Scanner-IBM-Type-M-/280839328798?pt=US_Parallel_Serial_PS_2_Cables_Adapters&hash=item416354141e
I have one of these, not the whole SDL cord. I like the IBM one  :cool:
Offline blakespot
« Reply #15 on: Tue, 22 January 2013, 21:07:55 »
Received the Model M and the USB adapter cable today. So lovely! Feels brand new, not 25 years old!
IBM Model M space saver by blakespot, on Flickr
Offline rootwyrm
    • My Website!
« Reply #16 on: Tue, 22 January 2013, 21:25:51 »
Oh holy crap!
I didn't know Orihalcon made those too! Screw +1, the man gets a +10. I have three of the DIN6 RS232 adapters - IBM DS4k/DS5k and Engenio use the DIN6 RS232 console. Had no idea that's where they were from - local SE sourced them for me a while back when I complained about how the 'official' ones dropped characters like nobody's business.
Offline sleepy916
« Reply #17 on: Wed, 23 January 2013, 17:02:14 »
Dang! after seeing it again, I should have just bidded. Very nice, I'm jealous.
